Computers compatible with Haiku (v3)
Introductory notes…
A while back, the now obsoleted Computer Compatibility List (OLD!) thread was started, and is now seriously out of date, which led me to start a new effort in February with the Computer compatibility list (old thread) thread. And up to now, I’ve been storing the new responses to a simple Google page called “Hardware List for Haiku” which I don’t think anyone can effectively see or use that well, and if people are taking the time to test and contribute, it’d be nice if they can see their efforts.
Where to find submitted hardware
New hardware that comes in from the add Haiku hardware form is instantly submitted to the hardware spreadsheet, and updates are also shared in this thread.
To view the list of submitted hardware, please visit:
The haiku-computer-list on GitHub
Text files containing submitted hardware are available on GitHub.
The Haiku Computer List page
The Haiku Computer List is a simple site, with categories for each hardware type.
How to add new hardware…
A simple way to add new hardware is simply to use this Google Form, which guides you through several questions about your experience with Haiku.
Or, if you’re uncomfortable with using Google Forms, please paste and use the template below, then add whatever info you need over the sample info pasted below:
Model: (for example, Leafbook Autumn Series 5 or DeskBar Skyscraper 4000)
Rating: Works very well (nearly everything works) – or fairly well (some components work, but some do not), poorly (Haiku barely makes it through startup or only the bare essentials work), or does not work
Version: Haiku Nightly: 64-bit (hrev: for example, h52300)
Startup media: USB storage media (USB 3), Internal SSD or hard drive (imaged or installed)
Started with: Legacy BIOS/CSM and UEFI
Boot options: Did not try Haiku boot options
CPU: Intel Core i7-620M (@ 2.66-GHz; 3.33 GHz with TurboBoost), 4MB L3 cache
GPU: Intel Graphics Media Accelerator HD (Integrated/Discrete) / NVIDIA NVS 3100M graphics with 512MB gDDR3 (Dedicated)
Sound cards: Intel HDA Controller
Networking cards: Broadcom 4312G 802.11b/g WiFi Adapter
USB types: USB 2.0/legacy ports, USB 3.0
Webcams: Webcam does not work
Memory: 8 GB DDR3 PC3-10600 SDRAM (1333 MHz)
CPU manufacturer: Intel
Share on GitHub: Yes
SD cards: No, SD reader does not work
Sound status: Sound works
Networking status: Ethernet and Wifi work
Graphics status: Graphics work natively/out of the box
Power status: Battery appears, and PowerStatus reports percentage fine
Restarting: Works fine
Additional notes: Anything you’d like to add about the computer, such as tips or tricks for others in the Haiku community
Contributor: Your name here
Contribution date: 09/28/2018 12:00
List of computers copied to top (February 2018 - November 29, 2018):
This top post, as of December 1, 2018, is no longer being updated, as it was becoming harder to edit. To view hardware submitted after December 1, please see either the haiku-computer-list on GitHub or the Haiku Computer List. Thank you.
Desktops/workstations:
Apple Mac Mini (A1176, 2007 model Core2Duo)
Version: Haiku R1 Beta 1 (64-bit)
Rating: Good (nearly everything works; e.g. the display, audio, ports, peripherals work, but no Wifi)
Startup medium: Internal SSD or hard drive (imaged or installed)
Started with: EFI on (no legacy/CSM support is available on this machine)
Tried boot options
Memory: 1gig
CPU: 2ghz Core2Duo
Additional notes (multi-line):
  • Had to use safe video mode to get it to boot past the splash screen.
  • Ethernet and WiFi both appear to work (I’m using ethernet and it works, wifi is listing networks so assuming it’s working).
  • Haven’t been able to test sound so it may or may not work yet.
    Contribution date: 11/19/2018 16:08:09
Acer Aspire R3600
Rating: Excellent (everything works… except maybe the camera or fingerprint reader)
Version: Nightly 32-bit (hrev51795)
Started with: Internal SSD or hard drive (imaged or installed)
Startup mode: Legacy/BIOS
Boot options: Used (for info, see the guide)
Memory: 1800 MB
Processor: Intel Atom 1,60 GHz
Network cards: Atheros AR5BXB63
Additional notes: (None)
Contributor name: Jens
Dell Inspiron 531
Started from: Legacy BIOS
Boot options: I didn’t know there were boot options
Memory: 4GB
CPU: Athlon 64 X2 3800+
GPU: Nvidia GeForce 8400 GS
Sound card: Nvidia MPC61 HD Audio (rev a2)
Networking card: Nvidia MCP61 Ethernet (rev a2)
Contributor: Anonymous contributor
HP DC7800SFF (Small Form Factor)
Startup medium: USB flash drive
Memory: 1.5 GB (worked fine, also tried with 2 gigs, also worked fine)
CPU: Intel core 2 duo q6600
GPU: SAPPHIRE AMD RADEON HD5450
Sound card: Integrated HP (internal)
Networking cards: None
Additional notes: Opengl may not work when booting from usb, but after I installed, ppsspp worked perfectly
Lenovo ThinkCentre E63z
Version: Haiku Nightly: 32-bit 52547
Startup media: USB flash drive
Boot options: Did not try boot options
Memory: 4GB
CPU: Intel Core i3-4005U (1.7GHz)
GPU: Integrated HD4000
Sound card: Integrated Lenovo
Networking cards: (Didn’t test WiFi)
  • Ethernet works.
  • There is a weird issue with Lenovo mice where they’d randomly turn off in haiku os.
  • No 3D rendering.
  • Wrong screen resolution is detected at boot
  • I’d like to thank my school, AlMurooj School AbuDhabi for providing me both the ThinkCentre E63z I filled out earlier (so credit them on that too plz) and the E73
    Contribution date: 11/26/2018 7:15:01
    Contributor: AlMurooj School AbuDhabi
Lenovo ThinkCentre E73
USB flash drive
Memory: 4GB
CPU: Core i3 4160 @ 3.6 GHz
Networking cards: None (wireless)
  • Worked like a charm, tho the error with the Lenovo mice did persist.
  • One slight problem is that the display would sometimes change to 8bit colour when booting and when exiting full screen applications.
    Contribution date: 11/26/2018 7:23:57
Lenovo (model?)
Version: Nightly 32-bit (Unlisted hrev - September 2018)
Memory: 4 (GB)
Processor: Unknown
Network cards: Unknown
Contributor name: Anonymous contributor
Mobile workstations:
Apple MacBook Pro 15" 2.2GHz Mid-2007 (MacBookPro3,1)
Version: Haiku R1 Beta 1 (32-bit)
Rating: Somewhat okay (i.e. the display works, but there’s no sound or mouse)
Startup media: Internal SSD or hard drive (imaged or installed)
Started with: I do not know what this means
Boot options: Tried boot options
Memory: 6GB
CPU: Intel Core 2 Duo 2.2GHz (probably T7500 “Merom”)
GPU: NVIDIA GeForce 8600M GT with 128MB
  • Does not boot Haiku from USB, you need to use a DVD drive or extract the disk and use another computer to install Haiku onto it. In my case, I must have screwed the boot loader stuff by having two SSDs with multiple partitions, so I ended up using a secondary SSD with an Haiku R1/Beta 1 32bit install image (written using dd) to boot the system (by pressing ALT and then choosing Windows) and the main drive to hold the partitions for both macOS and Haiku.
  • Sometimes, it requires two or three attempts before booting successfully, and turning on or off some boot options may help, but I could not find a pattern that would work every single time. Sometimes, the boot process seems to be frozen at the first icon, until I take out the cable of a USB mouse, then it boots.
  • It uses VESA Graphics on the full internal display resolution and Wifi works OK.
  • Sometimes, though, it looses wifi connection and can only get back online by rebooting the system.
  • Audio output did not work in the beta, but if you update to a recent (64bit) nightly build, you can get loud audio output on earphones or external speakers.
  • The internal trackpad seems to be a bit ““nervous””, clicking in small targets may be a challenge, and there is no secondary button nor scroll. Using an external USB mouse worked perfectly.
  • There is no iSight camera, but I believe the internal microphone works.
  • Keyboard layout for my language (Portuguese) is a work in progress, as there are some keys that need to be reconfigured.
  • There is no keyboard backlight. The system is very stable overall.
  • I did see a few kernel panics occasionally, but I have been able to work for long hours without any problems.
    Contribution date: 11/29/2018 8:40:23
    Contributor: Victor Domingos
Dell Latitude D500
Startup media: Built-in (internal) optical drive (CD/DVD media)
Memory: 1GB
CPU: Pentium M @ 1.3Ghz
GPU: intel 855 GM
Sound card: Intel AC97
Networking cards: Intel PRO/Wireless 2100
Additional notes: In order to get it to boot to desktop you need to enable failsafe graphics on the boot options. Sound does not seem to work.
Contribution date: 11/27/2018 1:44:00
HP OMEN by HP 15-ce000
Started with: EFI on (by choice)
Memory: 16 GB
CPU: Intel® Core™ i7-7700HQ CPU @ 2.80GHz
GPU: Nvidia GeForce GTX 1060 with Max-Q Design/PCIe/SSE2
Sound card: Intel Corporation CM238 HD Audio Controller
Networking cards: Realtek Semiconductor Co., Ltd. Device b822
  • On first boot everything OK, but after first update, every time I hotplugged a standard USB mouse or a Wacom tablet, I got a kernel panic.
  • Both webcams (common and infra-red) didn’t work.
  • Screen works in native resolution (1920x1080) but I don’t know if it works in 120 Hz or just 60 Hz.
  • Wi-Fi card wasn’t detected, but Ethernet worked.
  • Screen brightness didn’t work. Speakers and audio jacks worked.
  • Bluetooth and SD card reader wasn’t tested.
  • Contribution date: 11/28/2018 19:10:35
ThinkPad T440P (Quad-core i7, 16GB of RAM, GeForce GT 730)
Contributor: Xylobol (xylo on the forums)
USB flash drive, Internal SSD or hard drive (imaged or installed)
Started with EFI on (by choice)
Memory: 16GB DDR3
CPU: Intel Core i7-4600M
GPU: NVIDIA GeForce GT 730M
Sound card: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller
Networking cards: Intel Corporation Wireless 7260
  • Wireless gets stuck on ‘Connecting’ after closing and opening the lid. A restart fixes it, but that’s not opimal, so I’ll provide any debugging help that’s needed for developers.
  • Right click does not work with the stock touchpad.
  • Also, I have not tested the DVD drive.
  • Contribution date: 11/19/2018 17:26:13
Laptops, notebooks, and netbooks:
Acer Aspire One D269
Memory: 1 GB
Boot options: Not used/discovered (for info, see the user guide)
Startup medium: External SSD or hard drive
Acer aspire one d270
Startup medium: USB flash drive, Internal SSD or hard drive (imaged or installed)
Memory: 2GB
CPU: Intel atom
GPU: Intel
asus x554la xo1236h
Memory: 4GB
CPU: Intel i3-5005u 2.0GHz
GPU: Intel HD Graphics 5500
Networking cards: Atheros AR956X
Contributor: Aksenov
asus x554la xo1236h
Memory: 4GB
Networking card: Atheros AR956X
ASUS U50A
Version: Nightly 64-bit (hrev51498)
Boot options: Not used/undiscovered (for info, see the guide)
Additional notes: Everything works (sound, wifi, video)
Contributor name: Kevin Adams
Dell Latitude E6400
Version: Nightly 64-bit (hrev51798)
Started with: EFI (by choice), from USB flash drive
Memory: 4 GB
Processor: 2.26GHz Intel Core 2 Duo P8400
GPU: Nvidia Quadro NVS 160M
Sound card: Intel
Network cards: Intel Wireless WiFi Link 4965AGN (802.11a/g/n)
Contributor name: Peter
Dell Inspiron 15-3565
Started with: Legacy BIOS, from USB flash drive
Memory: 12GB DDR4
CPU: AMD E2-7th Gen
GPU: AMD Radeon R2-7th Gen
Wifi card: Intel 3165
Additional notes: Webcam & Trackpad’s right-click is the only apparent non functional device.
Contributor name: N. T. Crotser
fujitsu lifebook c1410
Rating: Kind of works (gets to the Desktop, but barely; half of things or greater don’t work)
Memory: 2.5GB
CPU: Intel T5500
GPU: Intel GMA950
Sound card: RealTek ALC260
Networking card: Intel Pro/Wireless 3945ABG
Additional notes: Boot option VESA mode, No WiFi, No Audio, No keyboard. Only Ethernet is working.
HP Pavilion G6
Networking card: Ethernet: RTL8101/2/6E PCI Express Fast Ethernet controller; Wireless: RT5390 Wireless 802.11n 1T/1R PCIe
Additional notes: Wireless device ralinkwifi shows up in Networking preferences. Can’t connect, no wireless networks found. My other laptops, other wireless devices connect fine w/R1/Beta1. FreeBSD shows driver working since 2013. Wifi on this laptop is working in OpenBSD, sorry, I don’t run FreeBSD at this time, working on it soon. Works great so far.
Contributor: bullfrog
Fujitsu LifeBook A512
Rating: Excellent (everything works… except maybe the camera )
Started from: Legacy BIOS / EFI
Memory: 4GB
CPU: Intel Core i3-3110M
GPU: Intel HD Graphics 4000
Networking card: Intel N 6205
Contributor: hor410
Lenovo R61
Memory: 4 (GB)
CPU: Intel T7300 Core 2 Duo
GPU: Intel PM965
Networking card: Intel PRO Wireless 3945ABG
Lenovo X1 Carbon 3rd Generation
Started from: I do not know what this (BIOS/EFI) means
Memory: 8GB
CPU: Intel Core i5
GPU: Intel
Lenovo x140e Type 20BL-S00900
Memory: 8GB
CPU: AMD A4-5000
GPU: Radeon HD 8330
Sound card: HD Audio - Realtek ALC3202
Wifi card: Intel 7260AC FRU:04W3814
Startup medium: Internal SSD or hard drive (imaged or installed); USB media
Started from: No, legacy BIOS
Additional notes: Comes with a Windows 8 Pro license embedded useually, use this to update the BIOS, so you can install the upgraded wifi card that works with Haiku. USB bot works, installing to SATA SSD/HDD works. Except for ACPI Buttons/backlight control etc… 100% functional once the wifi is swapped. Browsers are usable but a little laggy, native and QT apps run well though on this 1.5Ghz quad core.
Contributor name: cb88
Lenovo x131e
Memory: 8GB
CPU: AMD E2-1800 1.7Ghz dual core
GPU: Radeon HD 7340
Wifi card: Realtek RTL8188CE (works with UEFI only must disable CSM)
Started from: Yes, I started with EFI on (by choice)
Additional notes: The WiFi is the catching point on this one, it only ever worked for me with CSM disabled in the BIOS. the x140e + upgraded BIOS + swapped to intel wifi is a much better laptop. If you get one of these cheap it’s nice though only a dual core. Also I’ve ran 16GB of ram in these, the x140e probably supports 32GB.
Lenovo ThinkPad X220
Started from: EFI (by choice)
Memory: 8GB
CPU: i5-2520M
GPU: Intel HD3000
Sound card: Conexant 20672
Contributor: Bartek
Lenovo Thinkpad x200s
Rating: Excellent (everything works… except maybe the camera or fingerprint reader) Version: Nightly 64-bit (Unlisted hrev - February 2018)
Additional notes: Pick the 1280x800 version, the 1440 have graphics glitches
Contributor name: miqlas
Lenovo ThinkPad X230
Memory: 8gb
CPU: Intel Core i7-3520M
Networking cards: Intel 7-Series HD Audio, Intel Wireless-AC 7260
Additional notes: The wireless card in this machine is not a stock one, however, the stock Wifi was also Intel, and also worked just fine. I’m really surprised at how well this machine works, I’m really only missing out on the fingerprint reader and the camera. Both legacy and EFI boot just fine on this hardware, I just use EFI as everything else on this machine is also EFI.
Lenovo ThinkPad E550
Memory: 8GB
CPU: i3-5005U
GPU: Intel HD 5500
Sound card: Conexant HDA
Networking card: Intel Dual Band 7265D
Additional notes: Might need to warm reboot (from another OS) to get working HDA. WiFi works great; BIOS has a way to disable XHCI and fall back to UHCI. Legacy BIOS boot works also.
Contributor: waddlesplash
Lenovo X61s
Memory: 8GB
CPU: 1.4ghz Core 2 Duo LV L7300
GPU: Intel X3100
Networking card: Intel Pro Wireless 4965
Contributor: Knez
Lenovo X220
Memory: 16GB
CPU: 2.5Ghz Intel Core i5 2520M
GPU: Intel HD Graphics 3000
Sound card: Intel HD Audio
Networking card: Atheros AR9280
Additional notes: Everything works except sound.
Contributor: Knez
Toshiba satellite L655 PSK1EE
Memory: 3GB
CPU: Core i3 350M
GPU: Intel HD graphics 1st gen (ironlake)
Sound card: Toshiba integrated
Networking cards: BCM 4313 wi-fi
Additional notes: Sound didn’t work at all and when outputting to an external display via the VGA port, the video signal is very fuzzy
Contribution date: 11/25/2018 12:44:17
Toshiba satellite L300 11G
Version: Haiku Nightly: 32-bit (hrev52547)
Startup media: USB flash drive, Internal SSD or hard drive (imaged or installed)
Memory: 3GB
CPU: Intel Pentium T2370
GPU: Intel integrated GMA
Networking cards: Realtek RTL8187B
Additional notes: (multiple lines):
  • Wi-fi didn’t work, webcam didn’t work, and keyboard macros didn’t work (and a phone modem was present but wasn’t detected by the OS, but who uses dialup anyways lol).
  • Otherwise a great machine if you don’t mind the WiFi (and yes, I have tried installing the proprietary WiFi drivers).
    Contribution date: 11/25/2018 13:04:35
Tablets/convertibles:
Microsoft Surface Pro 4
Started from: EFI (no legacy/CSM support is available on this machine)
Memory: 8GB
CPU: Intel Core i5-6300U
GPU: Intel HD Graphics 520
Additional notes: Wi-Fi, Bluetooth, touch, pen, ACPI and NVMe Controller (SSD) don’t work. Requires ‘enable serial debug output’ (weird timing issue) and ‘failsafe graphics mode’ enabled to boot. You need to increase font sizes to be able to see anything on the screen.
Contributor: ksiazkowicz
Servers:
HP Z2 Small Form Factor G4 Workstation
Startup options: Yes, I tried this
Memory: 16 GB
CPU: Intel Xeon E-2176G Processor
GPU: Intel UHD Graphics P630
Sound card: Conexant CX20632 5.1 HD Audio
Networking cards: Intel Ethernet Server I350-T2 2 Port 1 GB , Intel Wireless-AC 9560 (2x2) MU-MIMO
Additional notes: Use fail-safe video driver
Contributor: cocobean
Custom machines (and/or boards):
Custom built machine, board, or Intel NUC, etc. (HomeBrew)
Version: Nightly 64-bit (hrev52394)
Rating: Somewhat okay (i.e. the display works, but there’s no sound or mouse) Startup medium: USB flash drive
Boot options: Yes, I tried this
Memory: 8 GB
CPU: Ryzen 5 2400G
GPU: Radeon RX Vega 11
Additional notes: Only 4GB usable. Only VESA graphics. USB problems
Memory: 16 GB
CPU: AMD A8-5600K
GPU: AMD Radeon RX560
Networking card: Realtek Network
Additional notes: Network speed too slow. VESA needed due to Ultrawide display. No sound through DP
Asrock Fata1ity gaming/ITX board
CPU: Ryzen 1700x
GPU: Vega FE
Memory: 16GB ram
Additional notes: only boots with 4GB limit enabled in bootloader + failsafe video, its rediculously fast though for a Haiku box. Built in Wifi works as it’s a compatible intel chipset, ethernet works.
Contributor: cb88
COCO T100
Memory: 32GB RAM
CPU: AMD Ryzen Threadripper 2950X
GPU: nVidia Quadro FX 5500
Sound card: Realtek ALC1220 Audio
Networking cards: Intel AC 8265 Wifi, Intel I211AT Gb LAN, AQUANTIA AQC107 10Gb LAN
Additional notes: Use fail-safe VESA driver for modern video cards. Some X399 motherboards have 10Gb LAN hardware requiring driver support.
Contributor: COCOBEAN
Intel NUC
Startup medium: USB flash drive, External SSD or hard drive
Memory: 8 GB
CPU: Intel i3
GPU: Intel 620
Thin clients:
HP t5720
Haiku version: Haiku R1 Beta 1
CPU: Transmeta Efficieon
Memory: 1GB
Additional notes: it can boot Haiku from USB and do simple tasks, web browsing is possible but is pushing it, Netsurf would be fine for this PC. If you use a CF to IDE adapter you can upgrade the storage of this PC easily or put an IDE HDD/SSD in it. I would lean toward an HDD as it will survive disk swapping better. It is very low power… I intend to use it as an always on IRC box.
Contributor: cb88
VM sessions:
VMware Fusion
Haiku version: Haiku R1 Beta 1 (64-bit)
VM client: VMware Fusion
Contribution date: 11/26/2018 17:44:40
Contributor: Not listed
Unknown VM client
Haiku version: February 2018 (Nightly 64-bit)
Boot options: Not used/undiscovered (for options, see the guide)
VM client: Unknown (host submitted as a HP Pavilion laptop)
Additional comments: I ran Haiku inside a virtual machine with 1 out of 8 CPUs and 1024 gb ram
Where did the old list go?
The old computer compatibility list, with machines dating before Beta 1 was released, is in its original thread. All models contributed to that list have been placed in the last post of that thread and it should be locked.
To the contributor of the Acer Aspire One D269 info via the form, thank you! It should be added to the list above.
There’s one legacy (alpha 4) contribution which was shared on the form; I’ve updated the form and removed alpha 4 as an option as it is no longer supported by Haiku and is very old (although users are still free to submit whatever they want under Other). As such, this listing will not be listed up top with the recent hardware as “Haiku Vintage (Alpha 4)” was selected:
Model: Dell Optiplex GX 280
Startup medium: USB (external) optical drive (CD/DVD media)
Additional notes: Only needs a suitable video card to get something on screen. The rest all works.
Note to contributor: Thanks for your addition. Please give a recent Nightly or the Beta a try on your Optiplex, both of which still have a 32-bit edition.
waddlesplash has a list of computers tested with the beta… see here : https://docs.google.com/spreadsheets/d/14lcdmBJ6N2-oxYNCW0ndVS8IdepCCXv6zG5VVdxWxKE/edit?usp=sharing
Also according to the following Intel NUC hardware works well (avoid high end Vega graphics models for now) Hardware for build
Just to summarize my own personal Hardware:
Lenovo x131e (filled out the form so removed description here).
Lenovo x140e (ditto)
Asrock Fata1ity gaming/ITX board + Ryzen 1700x + Vega FE + 16GB ram = only boots with 4GB limit enabled in bootloader + failsafe video, its rediculously fast though for a Haiku box. Built in Wifi works as it’s a compatible intel chipset, ethernet works.
HP T5720 this is actually a thin client with a Transmeta Efficieon + 1GB ram it can boot Haiku from USB and do simple tasks, web browsing is possible but is pushing it, Netsurf would be fine for this PC. If you use a CF to IDE adapter you can upgrade the storage of this PC easily or put an IDE HDD/SSD in it. I would lean toward an HDD as it will survive disk swapping better. It is very low power… I intend to use it as an always on IRC box.
Thank you @cb88 for your info! I’ve added both models to the main list above and should add them to the hardware site soon.
Now this is really exciting to see:
And I do wonder… now that I know there’s an official effort happening (I didn’t know this was here up until now), I wonder if I should redirect everyone to the list by @waddlesplash and/or merge the ‘R1 beta’ contributions listed above to that list? Hopefully, you guys will let me know! :smiley:
In any case, coolness! Glad to see more hardware is being tested with Haiku. :slight_smile:
Thanks @cocobean for your contribution to the listing; it’s been added to the list above.
I’ve tested USB and HDD boot on both those but not USB CD boot though I’m sure it would work… I must have selected the wrong radio button, would be nice if they were checkboxs.
Added new hardware via form to top post under custom configurations (again, thanks to the contributor):
Custom machines/boards:
Memory: 8 GB
CPU: Ryzen 5 2400G
Memory: 16 GB
CPU: AMD A8-5600K
Noted; I’ve changed this to internal HD/SSD and USB media (and have also added checkboxes to that section of the form). :slight_smile:
@cb88, I’ve added in the two models you mentioned in an earlier post. Thanks for adding them! (I’d kindly ask though to please mention the Haiku version and your rating in the future, as I guessed for both: r1beta1, rating: good).
Added new hardware via form to top post under laptops (again, thank you to the contributor):
Wanted to also add that if any of the Haiku devs/admins, (such as @humdinger, @waddlesplash, @PulkoMandy, etc.) would like to view the latest submitted data or merge it with any other databases, the entries for the compatibility list are stored nicely in a spreadsheet here.
No the HP T5720 fully works… its just a low end machine relative to modern standards mainly in that it only supports 1GB max of ram.
Changed rating in the top list for the t5720 as ‘excellent’.
Added new hardware via form to top post under tablets (again, thank you to the contributor):
The Radeon HD 5450 works ok with an HP dc7800
@kenan1099, thanks for the info… but what version of Haiku was this with? How does the rest of the machine do with Haiku?
Thank you to Bartek and also the anonymous contributor for contributing your hardware to the list. It’s been added to the main post above.
Thank you for your contribution to the Haiku hardware list!
Thank you @Knez and @Aksenov for your contributions to the Haiku hardware list!
Memory: 4GB
