What is the current state (or “general feel”) of haiku on macbooks, iMacs, mac mini etc. that run on the intel hardware platform?
I think this may be an avenue we could invest a bit in to perhaps support this area better since Apple will soonish, in the next couple of years, abandon OS support for the intel platform. haiku would then be in a good position to take over many of these machines and stop them from becoming e-waste.
As MacOS updates make the early generations of Intel Macs slow down tremendously giving them a second life with Haiku would be great. Just as the G4 and G5 Macs are exciting machines again with MorphOS the old hardware can benefit greatly from a well thought out OS alternative such as Haiku.
I think Haiku works great on the two I’ve tried. A lot of them use integrated Intel HD graphics. (vesa river on my Intel HD 4000, but supposedly is supported?)
I think it is a great avenue. They’re easy to come by, and cheaply so if it’s older stuff, and they use limited hardware. Meaning you know exactly the devices you’d need drivers for as there aren’t a lot of configurations. And not that Haiku has better software availability than out of date OS X, but a lot of software developers have been only supporting the last 3 versions of macOS. (Which itself is stupid, because no revolutionary software changes from Catalina to Monterey) So pretty much any pre-2015 mac users will start running into trouble, without OpenCore.
It seems like wi-fi and sound are the biggest issues, and trackpad usability for the laptops.
I’ve had mixed success. I have a Macbook Pro 2012 pre retina and a Mac Mini 2012 (basically same hardware generation, very similar chipsets) and Macbook will kernel panic on boot about when the desktop loads and before Tracker appears. Mac Mini will happily boot, but only if the bootloader is on a USB stick. When it boots, it seems fine. Both are on VESA I think.
I think that, too. But as a matter of facts, Macs have a number of custom components that make it extremely difficult.
First thing first, SPI. All MacBooks from 2015 onwards up until the last Intel model marketed in 2020 have the keyboard, the TouchBar (if any), the ambient light sensor and the trackpad connected to the SPI bus. Some MacBook Air might be different but I never tried a model between 2015 and 2020. A few early models of the new generation reportedly have the keyboard and the trackpad connected via USB as well, though.
This looks the first roadblocker.
The second one is WiFi, for those models with a Broadcom chipset there’s little hope, I think.
I don’t remember if there are models produced since 2015 that have an Atheros chipset.
The third one is audio. I never managed to get the built in loudspeakers work, only the mini jack worked for me.
Although the intel GPU should be supported I never managed to get it work (so no brightness control) on the models I’ve tried.
iMac and Mini may have chances to play better with Haiku but the lack of a working Bluetooth stack may be another obstacle.
FWIW: FreeBSD has a driver for the majority of the aforementioned hardware.
My main Haiku machine is a 2012 MacBook Pro. What is your configuration?
I know what you mean about the Mac mini, if you are interested, there is a way to make it bootable without the usb drive. It involves moving 4-5 files from one folder to another.
Well I managed to boot without rEFInd. I first installed a windows 10 boot camp (no license needed because I was getting rid of it anyway). Then I booted the Haiku thumb drive. Then I formatted the ntfs boot camp drive, and installed Haiku to it. Then I copied the loose files (Deskbar, haiku_loader.bios_ia32,
kernel_x86_64, runtime_loader, Tracker) from the booted usb drive to the Haiku install drive.
I think there was something else I copied from the usb to there Haiku partition, not sure if it was necessary though. (Something in data maybe). Anyone can let me know if they are stumped there. Then I could boot from the regular Mac boot select menu. It’s listed as “Windows”. Idk if it’s OSX doing that or if it’s something else.
EDIT: It was the platform loaders folder, in the data folder. I think I just copied the data folder over.
This is from this topic about installing on a macbook pro.. I forgot about the Windows boot camp part. I don’t know if it is necessary if Haiku is your only system. Definitely needed it I think for dualbooting with OS X. Probably related to the ESP blessing thing that OS X uses.
I forget where /data/platform_loaders is, but whatever files that were in there enabled me to boot without thumb drive. This was repeatable because I had to re-do it.
I got three mac minis now, two 2012 and one 2014 model.
The first 2012 model i found didn’t manage to start the kernel
Looking at it, it might be neat to have an installation guide geared for macs on the site to explain how to interact with the firmware (for example, which key to hold to get the boot loader selection, to get into a recovery to format the disk etc.)
