I made a video producer add-on for a media kit that uses a video stream from any IP camera.
This allows you to use your smartphone with the DroidCam application as a webcam in Haiku.
Ingenius!
Will the add-on be included with a standard Haiku install, or will it be a 3rd party addition?
Wow! For reals, this is a much needed improvement for Haiku
WD-40 for prezident!
I don’t know yet as there are several problems:
Would it make sense to submit a patch to Gerrit nevertheless, maybe other devs have ideas for a solution or pick it up in the future?
In MediaKit Default Theme BTextParameter was not implemented. I added support for them and this is what I got:
Does this require any new libraries, or just existing ones (FFmpeg)? If only existing ones, then I’d vote that we include this within Haiku itself.
Nothing else. Only the system libraries and ffmpeg (avformat, avcodec, avutil, swscale).
looks really really good
What a great projekt, Gerasim. Hope the Haiku team will this one include in Beta 3!
Very good.
Btw. do you use the free DroidCam dev. edition or the 5.-Euro Pro Version of DroidCam?
The addon works with any similar application. At the moment I’m using IP Webcam - https://play.google.com/store/apps/details?id=com.pas.webcam&hl=ru&gl=US. More features, more settings. Works much better than DroidCam.
PS: And yes, I used the free version of DroidCam.
In theory would it work with an ordinary IP Cam?
Yes, of course. I checked on rtsp streams - it works fine.
Very impressive, hello Gerasim, nice to see your picture!
Is the IP-add-on working?
Will it be in Haiku Beta 3?
Great work, it will have a great push to Haiku popularity.
Sound is working for me in Telegram by now! It is not! working in Windows 10!
Now Video would be a great step forward because of Corona too.
Your work is so extremely important for Haiku popularity!
The Haiku Inc. should give you a big, big bonus!
This is real Marketing! Make it work, make it visible, makle it usable!
Very cool! I had a camera working on USB some time ago. This looks better.
