Playground 2026
If you are using a Nightly release, try upgrading to a version higher than hrev59825 as there was a change introduced in that version that added audio over HDMI/DP support to the HDA driver that caused issues with existing HD Audio devices.
Audio actually still works but if you have a video card with audio support over the HDMI/DP port in your system it seems default to that upon updating and you need to switch to your normal HD Audio device in Media preferences. It also overrode the output/input mixer settings for all devices with the HDMI/DP one, showing HDMI <NULL> due to limitations of the HDA driver.
It was reverted in hrev59826. I logged a ticket about it as I experienced issues with it, link to the ticket here: Making sure you're not a bot!
Thank you so much - this was the problem. :smiley:
After ugrading, I have audio back.
It seems the upgrade changed my ES version to 10.0.4, so I got confused over missing features.
After re-installing 11.2, it works nicely (the CPU fan still spins up though).
Hi. I’ve been playing with jack2 and a DAW I’m working. Jack seems to be working well, still a lot to go on the daw.
Speed Dreams v2.3.0
Blender 5.2 LTS
SuperTuxKart running at 22FPS on almost 4k resolution using a custom virtio-gpu OpenGL driver.
With @3dEyes fixes for glib2 epiphany is stable and usable again, webkit_gtk got on update to it’s latest release too, so big thanks there!
With these changes (and another fix from @3dEyes for CDS on GTK4) this one is getting to a pretty good working condition.
MiniBrowser from GTK4 is able to show webpages fine (YT crashes, but those are issues for later). Updated the recipes for the local GTK4 applications and those are up and running again. :smiley:
Another addition done with the webkit_gtk4 port, Epiphany 50.4 build with GTK4 up and running :slight_smile:
LibreCAD 2.2.1.5
QCAD 3.32.9.0
I got Vireo (gnome email client) to build. Still need to work on building gnome keyring or seahorse, as it won’t save my password for my account.
Still working on getting a keyring working. I have found a workaround to not saving my password though.
Had troubles with crashes in Tuba related to login, maybe some related? (if not just ignore) :slight_smile:
PS, nice work!
Please work.. please! :grinning_face_with_smiling_eyes:
Compile finished but won’t start.. damn :anguished_face:
Holy smoke, it works!! :nerd_face:
So, LibreCAD, QCAD and FreeCAD ?!
Now that having choices.
Freecad seems to need a bit work.. panels and toolbars won’t move, app crashes if I go app settings.
But I can open freecad files and edit them.
Librecad opens file dialogs behind app for some reason.
Qcad is missing print review icons.
Playing around with Qt6-6.11.2 atm, so I’m holding off on testing there (for now). :slight_smile: but great work already!
I got built shiboken2 for freecad, but i am probably going to lose my mind with pyside2.. it just doesn’t want to get compiled.. aarrgh! :angry:
Mesa 26.2.2 (see: RadeonGFX/Nvidia-Haiku/Mesa-Zink/Mesa-NVK projects):
There is pyside6 already in haikuports repository, maybe you could have a look there?
