Wait, what’s your graphics card? I googled the model you specified, and even looked for data on gpu.userbenchmark.com but I couldn’t find results. Is it some custom chip?
Sorry for mistake!
I have radeon hd 6400.
Sweet! That means my integrated GPU (Skylake, Intel HD 530) can do better than those frame rates. Hopefully not too long in the future I will be able to boot Haiku on my PC and try some of these games on bare metal.
No, Haiku doesn’t have accelerated drivers… yet (we hope soon, but we’ve been hoping that for awhile now). What GPU you have doesn’t really come into the picture (except Vesa vs accelerated 2D driver might make a little difference).
So, it will render at however fast your CPU can software render it.
3.9 GHz, DDR4 @3000MHz. Still much better than the old graphics card, so it should be good enough.
Astromenace!
Thank you!
Where can we download these games for Haiku? Will they be in the Haiku Depot?
Thank you very much for your work 3dEyes!
I’m work on it. Minetest and Neverball already in HaikuDepot.
NOTE: Benchmarks are funny little things …
About GLteapot and other Haiku-included demos, here is a simple 3D spinning ball demo from Mesa demos. Both ball, cube, and teapot demos are well known in 3D computer graphics as they were some of the original 3D demos to show off surface textures, shadows, and reflectivity.
Wow; are these mesa demos in the Depot? Thanks.
Wow! How is the performance of PPSSPP?
On real hardware:
with minimal ppsspp settings (low resolution, disabled shaders, disabled texture intepolation) - about 20-30 fps.
if i set high resolution (1:1) - about 10-20 fps.
That’s quite good for a Core 2 Quad with an old(er) graphics card.
Not to mention, running using only software-based OpenGL.
Speaking of 3D games, I can’t believe that prboom-plus wasn’t in the repos!
prboom_plus-2.5.1.4.recipe
SUMMARY="Doom source port"
DESCRIPTION="PrBoom+ is a Doom source port developed from the original PrBoom project by Andrey Budko"
HOMEPAGE="http://prboom-plus.sourceforge.net"
COPYRIGHT="Andrey Budko 2016"
LICENSE="GNU GPL v2"
REVISION="1"
SOURCE_URI="https://downloads.sourceforge.net/project/prboom-plus/prboom-plus/$portVersion/prboom-plus-$portVersion.tar.gz"
CHECKSUM_SHA256="e0e2241d174839b107f1a42b191aa9895dc6749e477cbc850ad520fba2353b94"
SOURCE_DIR="prboom-plus-$portVersion"
ARCHITECTURES="!x86_gcc2 ?x86 x86_64"
SECONDARY_ARCHITECTURES="x86"
PROVIDES="
prboom_plus$secondaryArchSuffix = $portVersion
prboom_plus_server$secondaryArchSuffix = $portVersion
REQUIRES="
haiku$secondaryArchSuffix
lib:libSDL_1.2$secondaryArchSuffix
lib:libSDL_net_1.2$secondaryArchSuffix
BUILD_REQUIRES="
haiku${secondaryArchSuffix}_devel
devel:libsdl$secondaryArchSuffix
devel:libsdl_net$secondaryArchSuffix
BUILD_PREREQUIRES="
cmd:gcc$secondaryArchSuffix
cmd:install
cmd:ld$secondaryArchSuffix
cmd:make
cmd:pkg_config$secondaryArchSuffix
cmd:autoconf
cmd:automake
BUILD()
runConfigure ./configure --without-mixer --disable-gl --with-waddir=$dataDir/prboom-plus/
make $jobArgs
INSTALL()
cd src
mkdir -p $binDir
cp prboom-plus \
prboom-plus-game-server $binDir
cd ../data
mkdir -p $dataDir/prboom-plus
cp prboom-plus.wad $dataDir/prboom-plus/
I managed to build ioquake3, it mostly worked with the opengl1 renderer but crashed when you try to move the mouse
If you want to try to build ioquake3, here’s a patch to make it build (Shamelessly ripped from the patches for OpenArena):
ioq3-Haiku.patch
diff --git a/Makefile b/Makefile
index 97f21639..9c91e9f4 100644
--- a/Makefile
+++ b/Makefile
@@ -933,6 +933,49 @@ ifeq ($(PLATFORM),sunos)
else # ifeq sunos
+# SETUP AND BUILD -- HAIKU
+ifeq ($(PLATFORM),haiku)
+ SHLIBEXT=so
+ SHLIBCFLAGS=-fno-PIC
+ SHLIBLDFLAGS=-shared $(LDFLAGS)
+ LDFLAGS=-lnetwork
+ BASE_CFLAGS = -Wall -fno-strict-aliasing -Wimplicit -Wstrict-prototypes -fPIC
+ CLIENT_CFLAGS =
+ CLIENT_CFLAGS += $(SDL_CFLAGS)
+ SERVER_CFLAGS =
+ LIB=
+ CLIENT_LIBS=$(SDL_LIBS) -lGL
+ USE_CODEC_VORBIS = 1
+ HAVE_VM_COMPILED=true
+ BUILD_CLIENT = 1
+ BUILD_GAME_QVM = 0
+ BASE_CFLAGS+=-D_BSD_SOURCE -DUSE_ICON
+ ifeq ($(USE_OPENAL),1)
+ CLIENT_CFLAGS += -DUSE_OPENAL
+ ifeq ($(USE_OPENAL_DLOPEN),1)
+ CLIENT_CFLAGS += -DUSE_OPENAL_DLOPEN
+ endif
+ endif
+ ifeq ($(USE_CURL),1)
+ CLIENT_CFLAGS += -DUSE_CURL
+ ifeq ($(USE_CURL_DLOPEN),1)
+ CLIENT_CFLAGS += -DUSE_CURL_DLOPEN
+ endif
+ endif
+ ifeq ($(USE_CODEC_VORBIS),1)
+ CLIENT_CFLAGS += -DUSE_CODEC_VORBIS
+ CLIENT_LIBS += -lvorbisfile -lvorbis -logg
+ endif
+else # ifeq haiku
# SETUP AND BUILD -- GENERIC
@@ -951,6 +994,7 @@ endif #OpenBSD
endif #NetBSD
endif #IRIX
endif #SunOS
+endif #Haiku
ifndef CC
CC=gcc
diff --git a/code/qcommon/q_platform.h b/code/qcommon/q_platform.h
index 27ca856e..344cb400 100644
--- a/code/qcommon/q_platform.h
+++ b/code/qcommon/q_platform.h
@@ -298,6 +298,29 @@ Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#endif
+//================================================================= HAIKU ===
+#ifdef __HAIKU__
+#include <endian.h>
+#define OS_STRING "HAIKU"
+#define ID_INLINE
+#define PATH_SEP '/'
+#ifdef __i386__
+#define ARCH_STRING "x86"
+#elif __x86_64__
+#undef idx64
+#define idx64 1
+#define ARCH_STRING "x86_64"
+#endif
+#define Q3_LITTLE_ENDIAN
+#define DLL_EXT ".so"
+#endif
//catch missing defines in above blocks
Is any chance to see GZDoom in ports? It supports some awesome mods like BrutalDoom or Doom Slayer Chronicles
I have just had a look at that, seems like gcc is missing a feature that gzdoom needs (thread-local-storage). I’m going to add that to the recipie for gcc, build it and try again.
Create a PR, or all your work will be guaranteed lost.
I want a engine to play Kingpin
