s40in
                    June 7, 2017,  7:39pm
              1
              I did not wait who will port Lazarus (freepascal IDE) to Haiku and did it myself
The error was simple. But I was looking for her for about 10 hours.
Lazarus 1.9 trunk Qt5pas(beta) + small patch in Haiku
It work!
Lazarus 1.9 trunk Qt4pas + small patch in Haiku
              So you can bring EGSL back to HAIKU?
              Awesome! Hope the bug in haiku gets submitted to trac and upstreamed, and the lazarus recipe appears in haikuports!
              Whoa… great… can you explain how to do that?
              Wow!  Impressive job!  Congratulations!
                s40in
                    June 8, 2017,  6:06am
              7
              The main decision
You need to add a line to Qt4Pas.pro  before build libQt4Pas (the same for qt5pas.pro )
QMAKE_CXXFLAGS += -mstackrealign -mincoming-stack-boundary=2
Download the compiled library libQt4pas and libQt5pas
Who can add this (QMAKE_CXXFLAGS…) to HaikuPorts recipe?
              big thanks for the file… i’ll try when i have time
              You can submit a pull request to haikuports adding it. It would be very welcome to see this working again!
                s40in
                    June 8, 2017,  1:50pm
              10
                s40in
                    June 8, 2017,  7:26pm
              11
              Very very interesting!!! Awesome job. Does the installation requires any tweaks?
I am looking forward to see it in Haikuports.
                s40in
                    June 14, 2017, 11:07am
              13
              Lazarus 1.8rc5 qt5 in message below  as portable requires only qt5 (5.6.1) from HaikuDepot
                s40in
                    June 14, 2017,  2:08pm
              14
              Lazarus Test App with qt5 haiku style (qthaikustyle  in haikuports)
Top window: the native window of the Tracker settings
Lower window - Form1 : test lazarus program with the same controls with qt5 haiku style
              But what happend with the scrollbar in the ListBox?
                michel
                    June 15, 2017,  4:28pm
              16
              Trying to set up fpc, but fcpmkcfg is missing, so the samplecfg script won’t run. any ideas?
                s40in
                    June 15, 2017,  6:33pm
              17
              Scrollbar automatically disappeared
                s40in
                    June 15, 2017,  6:38pm
              18
I had this error on old version fpc 3.0.0. New version fpc 3.0.2   is installed perfectly (Haiku x86 GCC 2 Hybrid)
                s40in
                    June 22, 2017,  9:00am
              19
              I recompiled freepascal 3.0.2 for Haiku gcc5 ABI
Download unofficial build freepascal 3.0.2 haiku (gcc5 ABI)   For test only
                s40in
                    June 26, 2017,  1:31pm
              20
              My last neews about lazarus in Haiku
I created two vector icons for Lazarus
from original logo
my first simple vector icon
Added icon to app
Changed setting folder to ~/config/settings/lazarus
Complex build (qt4 and qt5). Lazarus work with qt4 interface, but you can build you project with qt4 or qt5 backend. See screenshot below. You can rebuild lazarus with qt5 backend, if need.
Download Lazarus 1.9 qt4/qt5  (builded in Haiku gcc5_hybrid)
Download libqt4pas and libqt5pas (qt5.9) for Haiku gcc5_hybrid  (builded in Haiku gcc5_hybrid)
Download Qt5 (5.9.0-3) for Haiku gcc5_hybrid: qt5-5.9.0-3-x86.hpkg  and qt5_devel-5.9.0-3-x86.hpkg
Select qt backend in Lazarus project
