Hrev on which was tested: 57233 onward
System Type: 64bit
Running from: direct hardware
Model: Vivobook S400C
Manufacturer: Asus
Rating: Very good
Startup the system from: HDD
Boot options needed?: None
Processor/Cores: Intel, Core i3, 4
Memory: Integrated, 4GB
Graphic cards/count: Integrated
Vesa needed?: no
Graphic card status: very good
Sound cards: Factory fitted
Soundcard status: Not tested
Networking cards: Factory fitted
Network card status: very good
Wireless Networking cards: Factory fitted
Wireless Network card status: Good
USB types/cound: 2.0, 3.0
USB cards status: Good
SD cards: N/A
SD cards status: N/A
Integrated Webcams: N/A
Did you have to blacklist hardware?: No
Additional notes: Touchscreen fully operable
Time to add mine here I suppose ![]()
Main laptop at the moment:
Hrev: mainly R1B4 with updates, rarely nightly
System type: 64bit
Running from: bare metal
Model: HP Laptop 17-xp1010nb 17.3inch screen
Manufactur: HP
Rating: very good
Startup the system from: BIOS EFI boot
Boot options needed: None
Processors/Cores: AMD Ryzen 7 5825U 2.00 GHz 8/16
Memory: Integrated, 16GB SODIMM DDR4 SDRAM
Graphic cards/count: Integrated AMD Radeon ⢠Graphics
Vesa needed?: no
Sound cards: Factory fitted, Realtek(R) Audio
Soundcard status: Fully working (speakers, jack output)
Networking cards: Internal RTL8822CE 802 11ac PCI Adaptor
Network card status: Not supported
Wireless Networking cards: External, RTL8188EU wireless LAN 802 11n USB 2.0
Wireless Network card status: Not supported
USB types/cound: 3.0
SD cards: N/A
Integrated Webcams: HP True Vision HD Camera
Additional notes: No output with HDMI to external screen
Hrev on which was tested: 57633
System Type: 64bit
Running from: direct hardware / virtual machine? Direct Hardware
Model: Surface Pro 5
Manufacturer: Microsoft
Rating: Generally functional. Surface keyboard/mouse works, but no multi-touch mouse support (USB mouse works fine); touchscreen does not work; no wifi; ethernet via the Surface Dock 2 works; Surface Dock 2 USB works (successfully mounted USB CDROM); builtin webcam not recognized; no is USB webcam connected to Surface Dock 2; builtin audio works; multiple displays are not detected; unable to adjust display resolution, but increase font size works sufficiently; nearly daily driveable.
Startup the system from: NVMe SSD 120GB
Boot options needed?: n/a
Processor/Cores: Intel i5-7300U @ 2.70GHz 4 Cores
Memory: 8GB
Graphic cards/count: Intel HD Graphics 620 onboard
Vesa needed?: no
Graphic card status: works fine; canāt adjust display resolution
Sound cards: Intel Sunrise Point-LP HD Audio onboard
Soundcard status: works fine
Networking cards: Microsoft RTL8153B GigE [Surface Ethernet Adapter] - via Surface Dock 2
Network card status: works
Wireless Networking cards: Marvell 88W8897 [AVASTAR] 802.11ac
Wireless Network card status: Recognized, but no driver; not functional
USB types/cound: Intel Sunrise Point-LP USB 3.0 xHCI Controller; 1X on board USB-A
USB cards status: works
SD cards status: n/a
Integrated Webcams: neither onboard webcam or USB Logitech HD Pro webcam work (they are recognized, but no driver)
Did you have to blacklist hardware?: ???
Additional notes: Generally runs very well and is fast; only major problem is lack of wifi and Falkon browser crashes regularly (WebPositive is slow)
listdev output:
device Bridge (Host bridge) [6|0|0]
device 5904: Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers
device 5916: HD Graphics 620
device Signal processing controller [11|80|0]
device 1903: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
device Multimedia controller [4|80|0]
device 1919: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging Unit
device Unclassified device (Non-VGA unclassified device) [0|0|0]
device 9d35: Sunrise Point-LP Integrated Sensor Hub
device Serial bus controller (USB controller, XHCI) [c|3|30]
device 9d2f: Sunrise Point-LP USB 3.0 xHCI Controller
device Hub (Unused, Full speed (or root) hub) [9|0|0]
vendor 0000: Unknown
device 0000: Unknown
device Human Interface Device (Boot Interface Subclass, Mouse) [3|1|2]
vendor 1ea7: SHARKOON Technologies GmbH
device 0066: [Mediatrack Edge Mini Keyboard]
device Hub (Unused, Single TT) [9|0|1]
vendor 045e: Microsoft Corp.
device 09b3: Unknown
device 09b4: Unknown
device CDC Data (Unused) [a|0|0]
device 09a0: RTL8153B GigE [Surface Ethernet Adapter]
device Audio (Streaming) [1|2|0]
vendor 046d: Logitech, Inc.
device 082d: HD Pro Webcam C920
device Human Interface Device (No Subclass, None) [3|0|0]
device 09a8: Unknown
device Mass Storage (SCSI, Bulk-Only) [8|6|50]
vendor 18a5: Verbatim, Ltd
device 0414: Unknown
device 09ac: Unknown
device Vendor Specific Class (Vendor Specific Subclass, Vendor Specific Protocol) [ff|ff|ff]
device 07e4: Unknown
device 9d31: Sunrise Point-LP Thermal subsystem
device 9d32: CSI-2 Host Controller
device 9d60: Sunrise Point-LP Serial IO I2C Controller #0
device 9d61: Sunrise Point-LP Serial IO I2C Controller #1
device 9d62: Sunrise Point-LP Serial IO I2C Controller #2
device 9d63: Sunrise Point-LP Serial IO I2C Controller #3
device Communication controller [7|80|0]
device 9d3a: Sunrise Point-LP CSME HECI #1
device 9d3e: iTouch Controller
device 9d13: Sunrise Point-LP PCI Express Root Port #4
vendor 11ab: Marvell Technology Group Ltd.
device 2b38: 88W8897 [AVASTAR] 802.11ac Wireless
device 9d18: Sunrise Point-LP PCI Express Root Port #9
device Mass storage controller (Non-Volatile memory controller, NVM Ex [1|8|2]
vendor 1c5c: SK hynix
device 1327: BC501 NVMe Solid State Drive
device 9d27: Sunrise Point-LP Serial IO UART Controller #0
device 9d4e: Sunrise Point LPC Controller/eSPI Controller
device Memory controller [5|80|0]
device 9d21: Sunrise Point-LP PMC
device Multimedia controller (Audio device) [4|3|80]
device 9d71: Sunrise Point-LP HD Audio
Hrev on which was tested: hrev57645
System Type: 64bit
Model: Futro S920
Manufacturer: Fujitsu
Rating: Works fine.
Startup the system from: mSATA 8GB
Processor/Cores: AMD GX 415GA @ 1.50GHz 4 Cores
Memory: 4GB
Graphic cards/count: Kabini [Radeon HD 8330E]
Vesa needed?: no
Graphic card status: works fine in 4K and also in FHD
Sound cards: AMD FCH Azalia Controller on board
Networking cards: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Wireless Networking cards: None
Wireless Network card status: -
USB types/count: 6 USB 2.0 + 2 USB 3.0
Integrated Webcams: none
Additional notes: Runs fine
**listdev output:*device Bridge (Host bridge) [6|0|0]
vendor 1022: Advanced Micro Devices, Inc. [AMD]
device 1536: Family 16h Processor Root Complex
vendor 1002: Advanced Micro Devices, Inc. [AMD/ATI]
device 9833: Kabini [Radeon HD 8330E]
device 9840: Kabini HDMI/DP Audio
device 1538: Family 16h Processor Function 0
device 1439: Family 16h Processor Functions 5:1
vendor 10ec: Realtek Semiconductor Co., Ltd.
device 8168: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
device 7814: FCH USB XHCI Controller
device Mass storage controller (SATA controller, AHCI 1.0) [1|6|1]
device 7801: FCH SATA Controller [AHCI mode]
device Serial bus controller (USB controller, OHCI) [c|3|10]
device 7807: FCH USB OHCI Controller
device Human Interface Device (Boot Interface Subclass, Keyboard) [3|1|1]
vendor 0c45: Microdia
device 7605: Unknown
vendor 0461: Primax Electronics, Ltd
device 4e84: Unknown
device Serial bus controller (USB controller, EHCI) [c|3|20]
device 7808: FCH USB EHCI Controller
device Serial bus controller (SMBus) [c|5|0]
device 780b: FCH SMBus Controller
device 780d: FCH Azalia Controller
device 780e: FCH LPC Bridge
device 1530: Family 16h Processor Function 0
device 1531: Family 16h Processor Function 1
device 1532: Family 16h Processor Function 2
device 1533: Family 16h Processor Function 3
device 1534: Family 16h Processor Function 4
device 1535: Family 16h Processor Function 5
Hrev on which was tested: hrev57705
System Type: 64bit
Model: NUC5CPYH
Manufacturer: Intel
Rating: Well
Startup the system from: USB, SSD both work
Processor/Cores: 2x Intel Celeron N3050
Memory: 4GB, manufacturer unknown
Graphic cards/count: Intel onboard, 8086:22b1
Vesa needed?: EFI Framebuffer driver
Graphic card status: EFI Framebuffer driver, working on HDMI
Sound cards: Intel HDA onboard
Networking cards: Realtek gigabit wired, Intel 7260 wifi
Network card status: Both work once packages updated
USB types/cound: 2x front USB3, 2x rear USB3
USB cards status: all work
SD cards: Onboard reader
SD cards status: I have nothing to test
Hrev on which was tested: 57937+118
System Type: 64bit
Model: 255 G9 Laptop - 840T7PA
Manufacturer: HP
Rating: Not well, CPU and RAM goes max, esp with WebPositive browsing, Some issue with HaikuDepot do not quit - HaikuDepot is stopping or completing running operation before quiting.
Boot options needed?: N/A
Processor/Cores: AMD, Athlon Silver 3050U, 2 Core
Memory: 4GB, HP Supplied.
Graphic cards: onboard - AMD Radeon - Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series]
Vesa needed?: donāt know
Graphic card status: Working
Sound cards: onboard - AMD Family 17h/19h HD Audio Controller
Soundcard status: Audio out is working, mic is not working.
Networking cards: onboard - RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller
Network card status: working
Wireless Networking cards: onboard - RTL8822CE 802.11ac PCIe Wireless Network Adapter
Wireless Network card status: not identified.
USB types/cound: USB A x2, USB C x1.
USB cards status: All USB ports working.
SD cards: NA
SD cards status: Onboard Reader is working
Integrated Webcams: Integrated Webcam not identified.
Did you have to blacklist hardware?: N/A.
Additional notes: Following not working.
- Trackpad
- Bluetooth - local devices
- Wireless - not listed.
- Microphone - not listed.
- Webcam - not listed.
~> listdev
device 15d0: Raven/Raven2 Root Complex
device Generic system peripheral (IOMMU) [8|6|0]
device 15d1: Raven/Raven2 IOMMU
device 1452: Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
device 15d3: Raven/Raven2 PCIe GPP Bridge [6:0]
device 8168: RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller
device c822: RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor 144d: Samsung Electronics Co Ltd
device a80b: NVMe SSD Controller PM9B1 (DRAM-less)
device 15db: Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
device 15d8: Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series]
device 15de: Raven/Raven2/Fenghuang HDMI/DP Audio Controller
device Encryption controller [10|80|0]
device 15df: Family 17h (Models 10h-1fh) Platform Security Processor
device 15e5: Raven2 USB 3.1
vendor ffff: Unknown
device 5678: Unknown
vendor 413c: Dell Computer Corp.
device 301a: Dell MS116 Optical Mouse
vendor 05e3: Genesys Logic, Inc.
device 0608: Hub
device Video (Video Streaming) [e|2|1]
vendor 0408: Quanta Computer, Inc.
device 536c: Unknown
device Wireless (Radio Frequency, Bluetooth) [e0|1|1]
vendor 0bda: Realtek Semiconductor Corp.
device b00c: Unknown
device 15e2: ACP/ACP3X/ACP6x Audio Coprocessor
device 15e3: Family 17h/19h HD Audio Controller
device 790b: FCH SMBus Controller
device 790e: FCH LPC Bridge
device 15e8: Raven/Raven2 Device 24: Function 0
device 15e9: Raven/Raven2 Device 24: Function 1
device 15ea: Raven/Raven2 Device 24: Function 2
device 15eb: Raven/Raven2 Device 24: Function 3
device 15ec: Raven/Raven2 Device 24: Function 4
device 15ed: Raven/Raven2 Device 24: Function 5
device 15ee: Raven/Raven2 Device 24: Function 6
device 15ef: Raven/Raven2 Device 24: Function 7
Hrev on which was tested: 58330
System Type: 64bit
Model: X1 Yoga Gen1
Manufacturer: Lenovo
Rating: 9/10
Processor/Cores: Intel Core i7-6500u 2 core/4 thread
Memory: 8GB, soldered
Graphic cards/count: onboard Intel HD Graphics 520
Vesa needed?: no
Graphic card status: 3D works OK with llvmpipe, full 1440p resolution
Soundcard status: Works fine through internal speakers, havenāt tested headphones
Networking cards: onboard Intel Ethernet Connection I219-V
Network card status: Havenāt tested wired because it needs a dongle I donāt have.
Wireless Networking cards: onboard Intel Wireless 8260
Wireless Network card status: Wifi works great if booted in BIOS mode, no wifi in UEFI mode. 5GHz works fine.
USB types/cound: 3x USB 3.0 Type A
SD cards: N/A
Integrated Webcams: Integrated Chicony webcam is not detected in CodyCam
Did you have to blacklist hardware?: no
Additional notes: Best installed in Legacy BIOS mode so the Wifi works. Trackpad works, with touch-to-click, TrackPoint works. Touchscreen does not work.
~> listdev
device 1904: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers
device 1916: Skylake GT2 [HD Graphics 520]
device Generic system peripheral [8|80|0]
device 1911: Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
vendor 8087: Intel Corp.
device 0a2b: Bluetooth wireless interface
device Video (Video Streaming) [e|2|0]
vendor 04f2: Chicony Electronics Co., Ltd
device b5c1: Unknown
device Vendor Specific Class () [ff|0|0]
vendor 138a: Validity Sensors, Inc.
device 0090: VFS7500 Touch Fingerprint Sensor
vendor 056a: Wacom Co., Ltd
device 503f: Unknown
device c52f: Nano Receiver
device 9d10: Sunrise Point-LP PCI Express Root Port #1
device (Unknown) (255:0:0) [ff|0|0]
device 525a: RTS525A PCI Express Card Reader
device 9d12: Sunrise Point-LP PCI Express Root Port #3
device 24f3: Wireless 8260
device 9d14: Sunrise Point-LP PCI Express Root Port #5
vendor 15b7: Sandisk Corp
device 5006: SanDisk Extreme Pro / WD Black SN750 / PC SN730 / Red SN700 NVMe SSD
device 9d48: Sunrise Point-LP LPC Controller
device 9d70: Sunrise Point-LP HD Audio
device 9d23: Sunrise Point-LP SMBus
device 1570: Ethernet Connection I219-V
Hrev on which was tested: 57937+129
System Type: 64bit
Model: HP Elitebook 820 G2
Manufacturer: HP
Rating: 9/10 - All core āessentialā hardware works, more āesotericā hardware not yet supported
Startup the system from: 256GB SATA SSD
Processor/Cores: Intel® Broadwell Core⢠i7 i7-5500U 2.4 GHz (2 Core H/T)
Memory: 16GB, DDR3L-SDRAM 1600 MHz 2 x 8 GB
Graphic cards: Integrated IntelĀ® HD Graphics 5500
Vesa needed?: Nope
Graphic card status: Working with a range of resolutions supported @ 60Hz, inculding native 1920 x 1080
Sound cards: onboard - Intel Broadwell U HD Sound - āDTS Studio Soundā
Soundcard status: Inbuilt speaker working, mic working (headset port untested)
Wireless Networking cards: onboard - Intel Wireless 7265 - Wi-Fi 5 (802.11ac)
Wireless Network card status: Working
USB types/count: USB 3.2 Gen 1 Type-A ports X 3
SD cards: N/A
Integrated Webcams: Integrated Webcam not identified/working.
Additional notes: Following not working/identifed.
- Smart Card Reader
- NFC Reader
- Web Cam
- Fingerprint Reader
⯠listdev
device 1604: Broadwell-U Host Bridge -OPIdevice Display controller (VGA compatible controller, VGA controller) [3|0|0]
device 1616: HD Graphics 5500device Multimedia controller (Audio device) [4|3|0]
device 160c: Broadwell-U Audio Controllerdevice Serial bus controller (USB controller, XHCI) [c|3|30]
device 9cb1: Wildcat Point-LP USB xHCI Controllerdevice Hub (Unused, Full speed (or root) hub) [9|0|0]
device 0000: Unknowndevice Human Interface Device (No Subclass, None) [3|0|0] vendor 3434: Unknown device 0321: Unknown device Hub (Unused, Single TT) [9|0|1] vendor 0424: Microchip Technology, Inc. (formerly SMSC) device 2134: Hub device Human Interface Device (Boot Interface Subclass, Mouse) [3|1|2] vendor 3152: Unknown device 1022: Unknown device Wireless (Radio Frequency, Bluetooth) [e0|1|1] vendor 8087: Intel Corp. device 0a2a: Bluetooth wireless interface device Vendor Specific Class () [ff|0|0] vendor 138a: Validity Sensors, Inc. device 003f: VFS495 Fingerprint Reader device CDC Data (Unused, Vendor specific) [a|0|2] vendor 03f0: HP, Inc device 521d: Unknown device Video (Video Streaming) [e|2|0] vendor 04ca: Lite-On Technology Corp. device 704d: Unknowndevice Communication controller [7|80|0]
device 9cba: Wildcat Point-LP MEI Controller #1device Network controller (Ethernet controller) [2|0|0]
device 15a2: Ethernet Connection (3) I218-LMdevice Multimedia controller (Audio device) [4|3|0]
device 9ca0: Wildcat Point-LP High Definition Audio Controllerdevice Bridge (PCI bridge, Normal decode) [6|4|0]
device 9c90: Wildcat Point-LP PCI Express Root Port #1device Bridge (PCI bridge, Normal decode) [6|4|0]
device 9c92: Wildcat Point-LP PCI Express Root Port #2device (Unknown) (255:0:0) [ff|0|0]
device 5227: RTS5227 PCI Express Card Readerdevice Bridge (PCI bridge, Normal decode) [6|4|0]
device 9c96: Wildcat Point-LP PCI Express Root Port #4device Network controller [2|80|0]
device 095a: Wireless 7265device Serial bus controller (USB controller, EHCI) [c|3|20]
device 9ca6: Wildcat Point-LP USB EHCI Controllerdevice Hub (Unused, Full speed (or root) hub) [9|0|0]
device 0000: Unknowndevice Hub (Unused, Full speed (or root) hub) [9|0|0] vendor 8087: Intel Corp. device 8001: Integrated Hubdevice Bridge (ISA bridge) [6|1|0]
device 9cc3: Wildcat Point-LP LPC Controllerdevice Mass storage controller (SATA controller, AHCI 1.0) [1|6|1]
device 9c83: Wildcat Point-LP SATA Controller [AHCI Mode]device Serial bus controller (SMBus) [c|5|0]
device 9ca2: Wildcat Point-LP SMBus Controller
Hrev on which was tested: 58546
System Type: 64bit
Model: Elemental 15
Manufacturer: Slimbook
Startup the system from: 256GB NVME
Processor/Cores: Intel® 12th Gen Core⢠i5 i5-1235U 2.5 GHz (10 + 2 Cores)
Memory: 8GB, DDR4 3200 MHz 1 x 8 GB
Graphic cards: Integrated IntelĀ® Alder Lake UP3-GT2
Vesa needed?: yes
Sound cards: onboard - Intel Alder Lake PCH-P
Soundcard status: Inbuilt speaker working, inbuilt mic working
Wireless Networking cards: onboard - Intel Wireless AX201
USB types/count: USB 3.2 Gen 1 Type-A ports X 1, USB-A 2.0 x 1, USB-C 3.2 Gen2 X 1
USB cards status: All USB ports working. (USB-C untested)
SD cards: MicroSD
SD cards status: Failed to mount device, but could be a corrupted card.
- A brand new laptop where Haiku works as well as possible.
- Trackpad works well, but is identified on haiku as a mice, so scrolling does not work.
- Vesa mode, but nothing to complain
- No wmi support, so volume keys or brightness do not work
- It has a backlight keyboard but needs a wmi driver to work. At least on haiku is turned on
- dmidecode refuses to work. (edit: happens on more laptops. general issue?)
A lot of time has passed again. We have new members in the community, and progress has been made in hardware support.
So, once again, weāre calling on you to share your experiences with the community. Feel free to enter your hardware data in the appropriate lists in the forum so we can update our hardware database.
- Hardware List: must have
- Hardware List: Complete Systems (here)
- Hardware List: Joysticks, Game pads
- Hardware List: Pen Tablets
- Hardware List: Compatible printers
- Hardware List: Compatible wireless network adapters (extern)
- Hardware List: USB docking stations
- Hardware Liste: Compatible scanners
- Hardware List: Compatible External Network Adapters (LAN)
- Hardware List - External optical data carriers
- Hardware List: Tested graphic cards
- Hardware List: Tested sound cards
- Hardware List: Compatible Webcams
- Hardware List: Bluetooth Input Devices
Regards Lelldorin and the BeSly knowledge base
Does the low power cores also recognized by Haiku ?
Does Haiku kernel support EHFI already?
Hrev on which was tested: 56578+93
System Type: 64bit
Model: Laptop: Mobile 1515
Manufacturer: Terra (Wortmann AG)
Rating: Looks very good. Booting without options, no vesa, sound ok, touch ok, wlan displayed but not tested, also lan (not here for the moment)
Boot options needed?: no
Processor/Cores: Intel i3-7020U 2.30 GHz
Memory: 4GB unknown
Graphic cards/count: Graka OnBoard Intel (Kabylake ULT GT2) - Intel(R) HD Graphics 620
Vesa needed?: no
Graphic card status: good, but changing the screen resolution ends in a black screen (testing on hdd installed needed).
Sound cards: Realtek(R) Audio
Soundcard status: included speaker ok, external speaker with audio and usb for power ok
Networking cards: rtl81xx
Network card status: runs good
Wireless Networking cards: idualwifi7260
Wireless Network card status: Shows up many wlan ports a runs good
Integrated Webcams: Chicony USB2.0 untested
Additional notes: could be one of the best choices for haiku, but need to test more
Infos taken from this Video: https://www.youtube.com/watch?v=kDXRTOZwBU4&pp=ygUFaGFpa3U%3D
Hrev on which was tested: beta 5
System Type: unknown
Model: Laptop: III Maestro 11.6
Manufacturer: Evolve
Rating: look not so bad
Processor/Cores: Intel Celeron N3450 (1.1GHz) Processor
Memory: 4GB DDR4L-2133 RAM
Graphic cards/count: Intel HD Graphics 500 Integrated Graphics
Vesa needed?: no
Sound cards: no info
Soundcard status: untested
Wireless Networking cards: Wireless LAN Wifi 4 (802.11n)
Wireless Network card status: no used adapter TP Link
Additional notes: The tester remove the modem M2 and install a SSD to install (runs)
no trackpad, WiFi (wlan), sound
does not see emmc storage
System Type: 64bit
Model: ThinkPad x200s
Rating: perfect
Startup the system from: internal SSD
Processor/Cores: Intel Core 2
Memory: 8 GB
Graphic cards/count: Intel Mobile 4 (onboard)
Vesa needed?: no
Sound cards: Intel HD Audio
Networking cards: Intel 82567LM Gigabit
Network card status: works fine
Wireless Networking cards: Intel PRO/Wireless 5100 AGN
Wireless Network card status: works fine
USB types/cound: Intel 82801I ICH9
USB cards status: yes
SD cards: none
SD cards status: -
Did you have to blacklist hardware?: none
Additional notes: none
System Type: 64 bit
Model: ThinkPad X240
Rating: quite good, but not everything works
Boot options needed?: none
Processor/Cores: Intel Core i5-4200U
Memory: 8 GB
Graphic cards/count: Intel integrated Graphics
Vesa needed?: no
Sound cards: Intel 8 Series HD Audio controller
Networking cards: Intel I218-M Ethernet
Wireless Networking cards: Intel Wireless 7260
Wireless Network card status: doesnāt work, canāt find any networks or connect.
USB types/cound: Intel USB
SD cards: unknown
SD cards status: not tried
Integrated Webcams: Chicony integraed Wecam; doesnāt work
Additional notes:
- Touchscreen works, but behaves a bit strange (can open a menu, but canāt select an entry; works fine when using the touch pad / track point)
- canāt right-click with touchpad and track-point (Elan devices)
Hrev on which was tested: hrev57937+113
System Type: 32-bit
Running from: Direct hardware
Model: ThinkPad R40
Manufacturer: International Business Machines (IBM)
Rating: Mostly good for a 2 decade-old laptop
Startup the system from: HDD (5400RPM 44-pin IDE)
Processor/Cores: Intel Pentium M 1.3GHz (1c/1t)
Memory: Generic SO-DIMM DDR1 768MB
Graphic cards/count: ATi Radeon Mobility 7000 16MB VRAM
Vesa needed?: no
Graphic card status: The GPU runs good, smooth interface
Sound cards: onboard Intel ACā97 chipset
Networking cards: Intel Pro 10/100 LAN
Network card status: Works great
Wireless Network card status: N/A
USB types/cound: 2x USB 2.0
USB cards status: USB ports supported, working fine
SD cards: None
Did you have to blacklist hardware?: None
Additional notes: Sometimes randomly the keyboard and UltraNav (integrated pointing devices) donāt work
Hrev on which was tested: hrev58911
System Type: 64-bit
Model: ProDesk 600 G4
Manufacturer: HP
Rating: 10/10
Startup the system from: 1 TB NVMe internal ssd
Processor/Cores: Intel Core i5 8500T (2.1GHz) Processor / 6 cores
Memory: 32 GB
Graphic cards/count: * Intel UHD Graphics 630 Integrated Graphics
Vesa needed?: no
Graphic card status: works great
Soundcard status: Excellent, has internal speaker
Networking cards: Gigabit LAN / ipro1000/0
Wireless Networking cards: realtekwifi/0
USB types/cound: 4x USB 3.0 , 1x USB-c
USB cards status: All working, but havenāt tested the usb-c port
SD cards: None
Additional notes: You need to disable and enable a massive amount of options in the BIOS to get it booting, but after making those changes everything booted and worked well.
Fans kick on when viewing YouTube in Iceweasel and are very loud.
Hrev on which was tested: hrev58937
System Type: 64bit
Model: B550
Manufacturer: Asus
Rating: Works Perfect
Startup the system from: SATA SSD
Boot options needed?: Normal - No additional options
Processor/Cores: AMD Ryzen 5700x 8-Core
Memory: Generic DDR4 48GB 3200mhz
Graphic cards/count: AMD Radeon 6800XT 16GB (PCI-E 16x)
Vesa needed?: no
Graphic card status: Running at 2560x1440 75hz, no issues.
Sound cards: (onboard)
Soundcard status: Working perfectly
Networking cards: RTL8xxx Ethernet (onboard, will edit when I find exact)
Network card status: Ethernet works great.
Wireless Networking cards: Generic AX210 [typhoon peak] (PCI-E)
Wireless Network card status: AX210 Wifi works great (AC 5Ghz and N 2.4Ghz)
Wireless Networking cards: Generic BCM4360 (PCI-E)
Wireless Network card status: Broadcom card is displayed in network applet and Devices application but cannot scan or connect to networks
USB types/count: USB 2.0 / 3.0 / 3.1 / C (11 Ports)
USB cards status: All work, transfer speeds and USB-C untested
Additional notes: Multibooting with rEFInd loading the Haiku bootloader, absolutely no extra configuration needed. Detects other partitions on NVME drive. This could be a daily driver if needed excluding video accelerated tasks. Software acceleration is very sufficient with the 5700x.
Hrev on which was tested: hrev58986
System Type: 64bit
Model: Acer Aspire E5-511
Manufacturer: Acer
Rating: 7/10
Startup the system from: Internal HDD
Boot options needed? Secure boot off.
Processor/Cores: Intel Pentium N3530 with 4 cores @ 2.17GHz
Memory: 8GB DDR3, other info is forgotten
Graphic cards/count: Intel Atom Processor Z36xxx/Z37xxx Series, onboard
Vesa needed?: no
Graphic card status: Uses framebuffer driver, right resolution and refresh rate, canāt change brightness
Sound cards: Unknown info
Soundcard status: Everything works
Wireless networking cards: Qualcomm Atheros, onboard, other info is unknown
Wireless network card status: Everything works except IPv6
USB types/count: 2x USB type A 2.0, 1x USB type A 3.0
USB cards status: All of them work
SD cards: Unknown information
SD cards status: Everything works
Intergrated Webcams: Installed, unsupported
Additional notes: Touchpad works but canāt right click. Using UEFI.
Hrev: hrev57937+129 (āR1/beta5 x86_gcc2ā)
System Type: 32bit
Running From: direct hardware
Model: Toshiba Satellite M115-S3154
Manufacturer: Toshiba
Rating: 9/10
Startup the system from: internal SATA SSD
Boot options needed: boots with no configuration
Processor/Cores: Intel Core Duo (branded Centrino Duo), 2 cores
Memory: 3GB DDR2
Graphic card: Intel Mobile Express Integrated Graphics Controller (integrated graphics)
VESA needed: no
Graphic card status: runs well, no issues
Sound cards: unable to identify (sorry!) maybe available online?
Soundcard status: no sound through speakers or headphone jack
Networking cards: Realtek RTL810xE PCI Express Fast Ethernet
Network card status:no issues whatsoever in testing
Wireless Networking cards:Intel PRO/Wireless 3945ABG [Golan]
Wireless Network card status:regularly disconnects and reconnects from networks - maybe weak reception, maybe hardware support problems.
USB types/count: 4x usb 2.0
USB cards status: all 4 work perfectly
SD cards: ENE Technology SD/MMC Card Reader
SD cards status: donāt seem to work, and notebook fails to boot when a card is in the slot
Integrated Webcams: no webcam, N/A
Blacklist hardware? none
Additional notes: notebook PC. touchpad, keyboard both work perfectly. has an internal MATSHITA branded DVD-RAM UJ-841S drive (not a typo - DVD-RAM not DVD-ROM), labeled as a DVD Multi recorder, but detected as a CD-ROM drive. video DVDs can be seen in files, but cannot be played.
