Hardware List: Complete Systems
Hello,
Just gave a try on a small beast PC tower this morning.
Everything is working very well. great !
Hrev on which was tested: 56627
System Type: 64bit
Running from: direct hardware
Model: Custom PC
Manufacturer: english ebay seller jalcomputers
Rating: excellent
Startup the system from: USB or real install
Boot options needed?: none
Motherboard: Asrock H610M-HVS/M.2 R2.0
Processor/Cores: Intel i9-13900K
Memory: 64Go, DDR4 3200MHz Corsair Vengeance LPX
Graphic cards/count: Intel UHD Graphics 770 integrated
Graphic card status: Everything works very well
Sound cards: Realtek ALC897/887 integrated in motherboard. Headphone jack, sound is ok
Networking cards: RTL8111/8168/8411
Network card status: works very well. For Wifi, use USB dongle.
USB types/cound: 4xUSB 3.2, 6xUSB 2.0
Storage: 4xSATA3, 1xUltra M.2 (PCIe Gen3x4). Haiku is installed on a Kingston 2To
~>  nproc
32
~> sysinfo
Kernel name: kernel_x86_64 built on: Dec  2 2022 07:31:02 version 0x1
32 Intel 13th Gen Core™ i9-13900K, revision b0671 running at 3000MHz
CPU #0: "13th Gen Intel(R) Core(TM) i9-13900K"
        Frequency: 5467.997
        Signature: 0x0b0671; Type 0, family 6, model 183, stepping 1
        Features: 0xbfebfbff
                FPU VME DE PSE TSC MSR PAE MCE CX8 APIC SEP MTRR PGE MCA CMOV PAT
                PSE36 CFLUSH DS ACPI MMX FXSTR SSE SSE2 SS HTT TM PBE
        Extended Features (0x00000001): 0x7ffafbff
                SSE3 PCLMULDQ DTES64 MONITOR DS-CPL VMX SMX EST TM2 SSSE3 SDBG FMA CX16 xTPR PDCM PCID
                SSE4.1 SSE4.2 x2APIC MOVEB POPCNT TSC-DEADLINE AES XSAVE OSXSAVE AVX F16C RDRND
        Extended Features (0x80000001): 0x2c100800
                SCE NX GBPAGES RDTSCP 64
        L2 Data cache fully associative, 1 lines/tag, 64 bytes/line
        L2 cache: 2048 KB, 8-way set associative, 0 lines/tag, 64 bytes/line
        Unknown cache descriptor 0xfe
        64-byte Prefetching
Hrev on which was tested: 56637 x86_64 (nightly image)
System Type: 64bit
Model: Custom PC
Manufacturer: some guy
Rating: Works 99% fine
Startup the system from: 32gb USB stick
Processor/Cores: AMD Athlon II X4 640 (4) @ 3.00
Memory: 4gb DDR2, unknown manufacturer
Graphic cards/count: Micro-Star MSI N210 Geforce (NVIDIA GeForce 210)
Vesa needed?: yes?
Graphic card status: works fine but didn’t run in native resolution (1280x1024) by default (fixed by just changing display settings to it)
Sound cards: onboard: AMD SBx00 Azalia ASRock / expanded: Micro-Star MSI N210 Geforce 210 PCIe (NVIDIA High Definition Audio)
Soundcard status:
Razer Kraken X For Console headphones not working
Genius SP-E120 loudspeakers working 100% fine
Networking cards: RTL810xE PCI Express Fast Ethernet controller
Network card status: Runs fine (ethernet connection)
Wireless Networking cards: no
Wireless Network card status: not tested
USB types/cound:
1 x USB3.0 Type A?
5 x USB2.0?
USB cards status: Working fine (every USB device was successfully detected and Haiku itself was running from USB)
SD cards: no
SD cards status: not tested
Integrated Webcams: no
Did you have to blacklist hardware?: no
Additional notes: maybe the built-in GNU/Bash Terminal will be better than me, a pathetic creature made out of meat and bones. Here it is:
~> listdev
device Bridge (Host bridge) [6|0|0]
  vendor 1022: Advanced Micro Devices, Inc. [AMD]
  device 9600: RS780 Host Bridge
  device 9603: RS780 PCI to PCI bridge (ext gfx port 0)
  vendor 10de: NVIDIA Corporation
  device 0a65: GT218 [GeForce 210]
  device 0be3: High Definition Audio Controller
  device 9605: RS780/RS880 PCI to PCI bridge (PCIE port 1)
  vendor 10ec: Realtek Semiconductor Co., Ltd.
  device 8136: RTL810xE PCI Express Fast Ethernet controller
device Mass storage controller (IDE interface, PCI native mode control [1|1|8f]
  vendor 1002: Advanced Micro Devices, Inc. [AMD/ATI]
  device 4390: SB7x0/SB8x0/SB9x0 SATA Controller [IDE mode]
device Serial bus controller (USB controller, OHCI) [c|3|10]
  device 4397: SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
  device 4398: SB7x0 USB OHCI1 Controller
device Serial bus controller (USB controller, EHCI) [c|3|20]
  device 4396: SB7x0/SB8x0/SB9x0 USB EHCI Controller
device Serial bus controller (SMBus) [c|5|0]
  device 4385: SBx00 SMBus Controller
device Mass storage controller (IDE interface, ISA Compatibility mode  [1|1|8a]
  device 439c: SB7x0/SB8x0/SB9x0 IDE Controller
  device 4383: SBx00 Azalia (Intel HDA)
  device 439d: SB7x0/SB8x0/SB9x0 LPC host controller
device Bridge (PCI bridge, Subtractive decode) [6|4|1]
  device 4384: SBx00 PCI to PCI Bridge
  device 4399: SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
  device 1200: Family 10h Processor HyperTransport Configuration
  device 1201: Family 10h Processor Address Map
  device 1202: Family 10h Processor DRAM Controller
  device 1203: Family 10h Processor Miscellaneous Control
  device 1204: Family 10h Processor Link Control
   device Unclassified device (Non-VGA unclassified device) [0|0|0]
     vendor 0000: Unknown
     device 0000: Unknown
~> listusb
1a2c:2124 /dev/bus/usb/0/0 "China Resource Semico Co., Ltd" "Keyboard" ver. 0110
0000:0000 /dev/bus/usb/0/hub "HAIKU Inc." "OHCI RootHub" ver. 0110
046d:c542 /dev/bus/usb/1/0 "Logitech, Inc." "Wireless Receiver" ver. 0302
0000:0000 /dev/bus/usb/1/hub "HAIKU Inc." "OHCI RootHub" ver. 0110
0000:0000 /dev/bus/usb/2/hub "HAIKU Inc." "EHCI RootHub" ver. 0200
046d:c534 /dev/bus/usb/3/2 "Logitech, Inc." "Unifying Receiver" ver. 2901
0000:0000 /dev/bus/usb/3/hub "HAIKU Inc." "OHCI RootHub" ver. 0110
0000:0000 /dev/bus/usb/4/hub "HAIKU Inc." "OHCI RootHub" ver. 0110
058f:6387 /dev/bus/usb/5/3 "Alcor Micro Corp." "Flash Drive" ver. 0002
0000:0000 /dev/bus/usb/5/hub "HAIKU Inc." "EHCI RootHub" ver. 0200
0000:0000 /dev/bus/usb/6/hub "HAIKU Inc." "OHCI RootHub" ver. 0110
New people have definitely come to us through beta 4. I would ask you to enter your hardware data in the appropriate lists so that we can expand the hardware database.
Would be nice to not ask for stuff we know for beta4 that it isn’t supported like bluetooth or webcams.
Those lists should only be there once we can expect people to report positively, otherwise we are asking people to waste their time testing stuff we already know doesn’t work.
yes, I agree with you that hardware that is not supported by haiku at the moment could not be queried. But now it is the case that people learn exactly from such forum entries that it is not possible. That’s why it’s ok for me with BluTooth, there are webcams that are supported, even if they are very old, and if you’re testing your system with Haiku, you can also include this.
If I should ONLY enter the results for three of my PCs during the last two years, there would be a long list of more than duplicate entries = each tested with hrev xyz…
A Zotac ZBOX IQ01, which worked wonderfully with Haiku 32bit + 64bit for at least three years, I disconnected from the net at some point. It is now lying around in a corner somewhere.
The other three PCs (Laptop DELL XPS 15 L502X, Zotac ZBOX MAGNUS ER51060) liked Haiku from totally to not at all - always change).
The gaming laptop from MSI* in native resolution amazingly with a certain nightly hrev until the last icon: rocket - after that was the end.
With Haiku r1/beta4 (32bit, 64 bit) all three computers did not want at all. I left the older (several years very compatible) ZBOX in place.
In the meantime (over several Hrev) the Haiku USB stick was not even shown as boot medium, so I suspected the stick itself or the connection to the computer as responsible.
This was not so, however, because a certain nightly wanted then again!
How should this be handled
*MSI Delta 15 A5EFK-009 AMD Advantage™ Edition Gaming Notebook
Display: 15.6" anti-glare (1920 x 1080, 240 Hz)
Processor: AMD Ryzen 9 5900HX / 3.3 GHz / Octa-Core
Graphics card: AMD Radeon RX 6700M 10 GB
Hard disks: 1 TB SSD (2nd will be retrofitted)
Working memory: 16 GB RAM (64 GB are ready)
Operating system: Microsoft Windows 11 Home (64 Bit)
Translated with www.DeepL.com/Translator (free version)
I make sure that the same computer/hardware components are not always in the list, but if it was running under an old version and suddenly it isn’t anymore, it will be entered (once) and if it wasn’t running then but now, it will it also entered to show progress/regression.
So that I can find it again: Haiku running on Protonet Maya - Off-Topic - Haiku Community (haiku-os.org)
