That is known use case! I myself posted some pictures about 2 monitor working in the past!
But it is of limited use to have just 2 monitors with same content!
Generally, yes, they are the same. By default you should have the Haiku and HaikuDepot repositories. If you want FatElk and BeSly, you have to add them yourself. If it helps, think of HaikuDepot as a graphical front-end to pkgman
But there are also .hpkg files outside of these repositories, that you download from people’s websites (I have a few on Sourceforge myself). You can install those by double-clicking on the file, which will load it in HaikuDepot, or you can use pkgman install filename.hpkg
. Either way will work.
haiku still can not get sound from HDMI.
even a switch line from hdmi.
Tried Phones?
today, i test application bescreencapture to record a vedio with bfs system.
at last, it have no sound when i play the vedio.
i try to play the vedio with debian12.5.
it said the file broken.
sorts of data writing problem?
haiku hrev 57709
Possibly codec diferences. Try with different formats ( mpg, avi, etc ) .
BeScreenCapture only captures the screen. No audio is recorded.
i notice there is application to record audio with haiku.
so, is there any way to join them working together?
or, get a audio file and a movie file .
take them into one with some other application?
You could try Medo.
well, when i log into haiku, it always change the time.
you can see.
at the same time.
it is 19:56 with haiku.
then i switch into debian, but the time be the next tomorrow 7:56.
i adjust it be the day 19:56 with debian.
when i switch into haiku and then return debian, the time will be wrong again.
why 12 hours error?
i set them as the same local time zone.
hongkong, China
Your Debian setup most likely sets the hardware time to UTC (aka Greenwich Mean Time or GMT) and then calculates the local time from that. There is a switch in Haiku’s time preference to let it do the same.
Either way works fine, actually, but they have to be set up the same way on all operating systems on a computer.
If it is 07:56 PM, it’s the same time. In this case, it means that the local time is shown in different format; 24hrs instead of 12hrs AM/PM. You can change that in locale preferences.
ok, you are right.
it is different compatibility of time.
linux is sorts of Unix-like thing.
Don’t be fooled by the fact there’s a 32 bit version. Actually, some libs are using cpu features like SSE that are only available on i586 and later.
Not quite. The number is declining, but there are a few others that still offer 32-bit: https://www.debugpoint.com/32-bit-linux-distributions/
Haiku code usually detects cpu features before using them. Officially we require MMX extensions.
(Pentium II according to the release notes)
SSE2 is only required if you use webkit, and even then you can use netsurf instead.
another mini-pc which used for industry named “Hikvision mv-vb2210-120G”.
haiku have no network and get wrong resolution ratio which it should be 1366*768.
this is the information with zorin16.3.
user-desktop
description: Desktop Computer
product: To be filled by O.E.M. (To be filled by O.E.M.)
vendor: To be filled by O.E.M.
version: To be filled by O.E.M.
serial: To be filled by O.E.M.
width: 64 bits
capabilities: smbios-2.8 dmi-2.8 smp vsyscall32
configuration: boot=normal chassis=desktop family=To be filled by O.E.M. sku=To be filled by O.E.M. uuid=00020003-0004-0005-0006-000700080009
*-core
description: Motherboard
product: Aptio CRB
vendor: AMI Corporation
physical id: 0
slot: To be filled by O.E.M.
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: 5.6.5
date: 09/10/2018
capacity: 1MiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi
*-memory
description: System Memory
physical id: 28
slot: System board or motherboard
*-bank:0
description: DIMM DDR3 1333 MHz (0.8 ns)
product: M471B5773DH0-YH9
vendor: Samsung
physical id: 0
serial: 00000000
slot: A1_DIMM0
width: 64 bits
clock: 1333MHz (0.8ns)
*-bank:1
description: DIMMProject-Id-Version: lshwReport-Msgid-Bugs-To: FULL NAME EMAIL@ADDRESSPO-Revision-Date: 2012-10-07 14:34+0000Last-Translator: lumingzh lumingzh@qq.comLanguage-Team: Chinese (Simplified) zh_CN@li.orgMIME-Version: 1.0Content-Type: text/plain; charset=UTF-8Content-Transfer-Encoding: 8bitX-Launchpad-Export-Date: 2022-08-18 12:16+0000X-Generator: Launchpad (build 87919ae1fbf1142b0e02b80650e6ccf3e775beb3) [empty]
product: Array1_PartNumber1
vendor: A1_Manufacturer1
physical id: 1
serial: A1_SerNum1
slot: A1_DIMM1
*-cache:0
description: L1 cache
physical id: 32
slot: CPU Internal L1
capacity: 224KiB
capabilities: internal write-back
configuration: level=1
*-cache:1
description: L2 cache
physical id: 33
slot: CPU Internal L2
capacity: 2MiB
capabilities: internal write-back unified
configuration: level=2
*-cpu
description: CPU
product: Intel(R) Atom™ CPU E3845 @ 1.91GHz
vendor: Intel Corp.
physical id: 34
bus info: cpu@0
version: Intel(R) Atom™ CPU E3845 @ 1.91GHz
slot: SOCKET 0
capacity: 2400MHz
width: 64 bits
clock: 83MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp x86-64 constant_tsc arch_perfmon pebs bts rep_good nopl xtopology tsc_reliable nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 movbe popcnt tsc_deadline_timer aes rdrand lahf_lm 3dnowprefetch epb pti ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid tsc_adjust smep erms dtherm arat md_clear cpufreq
configuration: cores=4 enabledcores=4 threads=4
*-pci
description: Host bridge
product: Atom Processor Z36xxx/Z37xxx Series SoC Transaction Register
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 11
width: 32 bits
clock: 33MHz
configuration: driver=iosf_mbi_pci
resources: irq:0
*-display
description: VGA compatible controller
product: Atom Processor Z36xxx/Z37xxx Series Graphics & Display
physical id: 2
bus info: pci@0000:00:02.0
version: 11
width: 32 bits
clock: 33MHz
capabilities: pm msi vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:93 memory:d0000000-d03fffff memory:c0000000-cfffffff ioport:e080(size=8) memory:c0000-dffff
*-sata
description: SATA controller
product: Atom Processor E3800 Series SATA AHCI Controller
physical id: 13
bus info: pci@0000:00:13.0
version: 11
width: 32 bits
clock: 66MHz
capabilities: sata msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:91 ioport:e070(size=8) ioport:e060(size=4) ioport:e050(size=8) ioport:e040(size=4) ioport:e020(size=32) memory:d0916000-d09167ff
*-usb:0
description: USB controller
product: Atom Processor Z36xxx/Z37xxx, Celeron N2000 Series USB xHCI
physical id: 14
bus info: pci@0000:00:14.0
version: 11
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:92 memory:d0900000-d090ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 5.15.0-78-generic xhci-hcd
physical id: 0
bus info: usb@2
logical name: usb2
version: 5.15
capabilities: usb-2.00
configuration: driver=hub slots=6 speed=480Mbit/s
*-usb:0 UNCLAIMED
description: Generic USB device
product: Elite4 5.x
vendor: Senselock
physical id: 3
bus info: usb@2:3
version: 5.01
configuration: maxpower=22mA speed=12Mbit/s
*-usb:1
description: USB hub
product: USB2.0 Hub
vendor: Genesys Logic, Inc.
physical id: 4
bus info: usb@2:4
version: 85.37
configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s
*-usb:0
description: Mouse
product: USB OPTICAL MOUSE
physical id: 3
bus info: usb@2:4.3
version: 1.00
capabilities: usb-1.10
configuration: driver=usbhid maxpower=100mA speed=2Mbit/s
*-usb:1
description: Keyboard
product: USB Keyboard
vendor: SEM
physical id: 4
bus info: usb@2:4.4
version: 1.10
configuration: driver=usbhid maxpower=98mA speed=2Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@3
logical name: usb3
version: 5.15
capabilities: usb-3.00
configuration: driver=hub slots=1 speed=5000Mbit/s
*-generic
description: Encryption controller
product: Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine
physical id: 1a
bus info: pci@0000:00:1a.0
version: 11
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=mei_txe latency=0
resources: irq:94 memory:d0500000-d05fffff memory:d0400000-d04fffff
*-multimedia
description: Audio device
product: Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 11
width: 64 bits
clock: 33MHz
configuration: driver=snd_hda_intel latency=0
resources: irq:95 memory:d0910000-d0913fff
*-pci:0
description: PCI bridge
product: Atom Processor E3800 Series PCI Express Root Port 1
physical id: 1c
bus info: pci@0000:00:1c.0
version: 11
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:87 ioport:d000(size=4096) memory:d0800000-d08fffff
*-network UNCLAIMED
description: Ethernet controller
product: I210 Gigabit Network Connection
physical id: 0
bus info: pci@0000:01:00.0
version: 03
width: 32 bits
clock: 33MHz
capabilities: pm msi msix pciexpress cap_list
configuration: latency=0
resources: memory:d0800000-d087ffff ioport:d000(size=32) memory:d0880000-d0883fff
*-pci:1
product: Atom Processor E3800 Series PCI Express Root Port 2
physical id: 1c.1
bus info: pci@0000:00:1c.1
version: 11
width: 32 bits
clock: 33MHz
resources: irq:88 ioport:1000(size=4096)
*-pci:2
product: Atom Processor E3800 Series PCI Express Root Port 3
physical id: 1c.2
bus info: pci@0000:00:1c.2
version: 11
width: 32 bits
clock: 33MHz
resources: irq:89 ioport:c000(size=4096) memory:d0700000-d07fffff
*-network UNCLAIMED
physical id: 0
bus info: pci@0000:03:00.0
version: 03
width: 32 bits
clock: 33MHz
resources: memory:d0700000-d077ffff ioport:c000(size=32) memory:d0780000-d0783fff
*-pci:3
product: Atom Processor E3800 Series PCI Express Root Port 4
physical id: 1c.3
bus info: pci@0000:00:1c.3
version: 11
width: 32 bits
clock: 33MHz
resources: irq:90 ioport:b000(size=4096) memory:d0600000-d06fffff
*-network UNCLAIMED
physical id: 0
bus info: pci@0000:04:00.0
version: 03
width: 32 bits
clock: 33MHz
resources: memory:d0600000-d067ffff ioport:b000(size=32) memory:d0680000-d0683fff
*-usb:1
product: Atom Processor Z36xxx/Z37xxx Series USB EHCI
physical id: 1d
bus info: pci@0000:00:1d.0
version: 11
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci-pci latency=0
resources: irq:23 memory:d0915000-d09153ff
*-usbhost
product: EHCI Host Controller
vendor: Linux 5.15.0-78-generic ehci_hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 5.15
configuration: driver=hub slots=8 speed=480Mbit/s
*-isa
description: ISA bridge
product: Atom Processor Z36xxx/Z37xxx Series Power Control Unit
physical id: 1f
bus info: pci@0000:00:1f.0
version: 11
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration: driver=lpc_ich latency=0
resources: irq:0
*-serial
description: SMBus
product: Atom Processor E3800 Series SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 11
width: 32 bits
clock: 33MHz
capabilities: pm cap_list
configuration: driver=i801_smbus latency=0
resources: irq:18 memory:d0914000-d091401f ioport:e000(size=32)
*-pnp00:00
product: PnP device PNP0b00
physical id: 1
capabilities: pnp
configuration: driver=rtc_cmos
*-pnp00:01
product: PnP device PNP0c02
physical id: 2
capabilities: pnp
configuration: driver=system
*-pnp00:02
physical id: 3
capabilities: pnp
*-pnp00:03
product: PnP device PNP0501
physical id: 4
capabilities: pnp
configuration: driver=serial
*-pnp00:04
physical id: 5
capabilities: pnp
*-pnp00:05
physical id: 6
capabilities: pnp
*-pnp00:06
physical id: 7
capabilities: pnp
*-scsi
physical id: 8
logical name: scsi0
capabilities: emulated
*-disk
description: ATA Disk
product: SSD128G-E100M
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 5
serial: 30004469881
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: ansiversion=5 guid=b6fa7b08-027b-4ac8-87e9-2159ded584c6 logicalsectorsize=512 sectorsize=512
*-volume:0 UNCLAIMED
description: Windows FAT volume
vendor: mkfs.fat
physical id: 1
bus info: scsi@0:0.0.0,1
version: FAT32
serial: bc84-81f8
capacity: 511MiB
capabilities: boot fat initialized
configuration: FATs=2 filesystem=fat name=EFI System Partition
*-volume:1
description: EXT4 volume
vendor: Linux
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
logical name: /
version: 1.0
serial: 561e84d1-f21a-4b3e-8136-0834bba363ec
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2023-03-28 02:09:13 filesystem=ext4 lastmountpoint=/ modified=2024-06-23 10:05:04 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro mounted=2024-06-23 10:05:06 state=mounted
