Thank you very much! I will need some time to try this out ![]()
I changed the recipe for IBM Plex to OTF and put the version to 6.4.0
Please check it and upload it to media-fonts/ibm_plex
I can understand posting it here if you do not want to use github, but since you have already uploaded it to github you can put this as a pull request.
If you donât have anything set up like an own âforkâ and such on github you can iirc still use the web editor and just replace the content with your new version and propose this as a PR.
Regards
I use the famous font from Poland, PĂłltawski Nowy (which is variable-weight Antykwa Poltawskiego). I used to use Antykwa ToruĹska before that.
I strongly suggest no longer using the original Antykwa Poltawskiego and to switch to PĂłltawski Nowy instead - itâs a technically better font (based on the same type), but looks more or less the same. You can vary the weight of it infinitely.
