Somehow GTK is borked here on this install (for quite some time), a quick check on 32bit (and another 64bit laptop) and updated packages shows no problems, playback is fine. When looking at the dependencies for Epiphany I don’t see a direct link to libqxp?
Really, I am surprised…Web now opens videoes, but garbled sound output remains unsolve.
I thought libqxp upgrade had something to do with the issue of video not opening…I also did not do anything…but video opens now
Falkon, otter both crash at random…not usable
Ladybird, heaviest (16MB) among all…not usable
Dooble better now…using Dooble for youtube…I think I had tried dooble at a time when webpositive was broken due to webkit 1.8…for about 5 days, webpositive was not usable due to webkit1.8…maybe dooble was also affected at that time
I am surprised that, except webpositive all other browsers can display indian fonts on the google search engine page…where it says Google also offered in…(Hindi Kannada Tamil…)
Webpositive displays blank squares at these fonts
Basically because browsers on Haiku has different browser engines, and especially the ported browsers requires - and this way installs also - additional environment packages too to their web engines as well.
I mean,
Dooble, Falkon, Otter, Qupzilla(it was Falkon, earlier) - engine : qtwebkit (This WebKit engine is developed as Webkit for QT development environment - actually for QT5 - so it is a totally different engine what works under Web+ or Web browsers)
Web (Epiphany) - engine : webkit_gtk (This WebKit engine is developed as Webkit for GTK - formerly Gimp Toolkit - development environment - it is developped within this cross-platform widget toolkit for GUIs.).
So the installed browsers what can/could do or do not do or cannot do with web contents - depends on which engine used, that engine and also the browser how accurate to the latest version - in case Haiku.
Browsers like Netsurf, Ladybird, Dillo,etc on Haikuare also totally different as they came from such projects which custom developments for special operating systens or development frameworks - so they do not use mainstream open source engines but their custom solutions, and mostly does not target full modern HTML5 services but basic HTML or Web services for limited or offline web browsing like the documents and guides locally, or read e-mails, mailgroups or use simple ftp, gopher , for example.
Also the ported browser apps has their own solution some cases for what they use in their solutions - instead of what Haiku actually offers (or does not offer actually as it is still missing from Haiku as a service or there is no connnection established among them as it is already available in ported apps). You can read about these (for example Media Kit or other part’s missing codes) in several Haiku blog posts or in forum threads.
Just to be sure, for webpositive to show regional fonts on the google search page, this noto regional fonts is not needed…correct?
On this google search page, not one, but 5 or 6 languages fonts, all different from each other, are displayed simultaneously by other browsers
Webpositive displays blank squares at this point. Pl. see the attached screen shots, as displayed by webpositive and Dooble
Pl. note the difference where it says 'Google offered in…"
