Translation updated at Polygot for Dutch
I needed functionality to display MIME content from the clipboard, didn’t find it so i patched it in. Would be cool to get a copy to clipboard function at some point, I hope this patch is usefull.
diff --git a/src/datawindow.cpp b/src/datawindow.cpp
index 06ead9e..b786b6e 100644
--- a/src/datawindow.cpp
+++ b/src/datawindow.cpp
@@ -118,6 +118,18 @@ DataWindow::display_data()
switch (fFieldType)
+ case B_MIME_TYPE:
+ if (fFieldName.StartsWith("text/"))
+ const void* dataValue;
+ ssize_t bytes;
+ fDataMessage->FindData(fFieldName, B_MIME_TYPE, i, &dataValue, &bytes);
+ message_item_data = (char*)dataValue;
+ } else {
+ message_item_data=B_TRANSLATE("data cannot be displayed");
+ break;
case B_STRING_TYPE:
message_item_data=BString(fDataMessage->GetString(fFieldName, i, ""));
break;
Hi @BlueSky I saw you released a new version of kottan, but it seems this patch is not included. Could you add it to the application?
I put your diff in a PR for easy testing/merging by @BlueSky. Hope I got the “author” right…
Thanks humdinger ![]()
Thanks a lot @humdinger . I’ll be looking at and merging the 2 open PR’s over the next few days. I just wanted to get out the maintenance release as quick as possible to fix the bug with the missing translations ( I had forgotten to add the new language codes to the Makefile
Welcome to the club. ![]()
Does anyone know if it’s possible to include everything in the “locales” folder (sans the files’ .catkeys extension) to avoid having to list all language codes?
Can’t you use the asterix for it? (haven’t checked)
Nope. That would be too easy. ![]()
I tried with LOCALES = $(ls locales | xargs -- basename -a -s .catkeys), but that doesn’t work either.
Maybe something like…
LOCALES = $(patsubst locales/%.catkeys,%,$(wildcard locales/*.catkeys))
Magic! ![]()
This works, thanks Lrrr!
Ah great, that’s a good solution @Lrrr.
In my view it should be built into the makefile engine.
Projects may have a minimum percentage of translation to include a language in the release. But maybe an ALL_LOCALES variable so that you can use your vetted list or just LOCALES = $(ALL_LOCALES) depending on project rules is not a bad idea.
