Hello.
After recent system update, via pkgman update
the terminal has stopped working.
This is what I see, when opening a new terminal:
I did a clean re-install of Haiku from the ISO image, which temporarily fixed the problem.
However, after running pkgman update
on the “fresh” system, again the same problem shows up!
Any ideas how to fix or avoid this problem?
Thank you and best regards!
