Sound on the Lenovo X 220
#1
Hello
I bought a used Lenovo X220 as it seemed Haiku compatible.
I installed Haiku, updated it regularly, but can’t get a sound
listdev shows
device Multimedi controller (Audio device) [4|3|0]
pressing the physical buttons for disabling/enabling the sound has no effect
pressing the physical button for sound low or high has no effect
when I try to install OpenSound in Haikudepot, I get an error message
Fatal error occured while installing package opensound: Failed to download package opensound.
but I am connected to Internet, as I can update Haikudepot or use any browser.
Thanks for any hint
#2
You can download it manually:
https://depot.haiku-os.org
#3
Yes, you need opensound to get sound working on the X220.
#4
I have installed it, rebooted, but still no sound, either playing with mplayer a video from a USB disk, or in youtube.com or allocine.fr
in mplayer, the sound is at 50%, still no sound if I put the gauge higher.
Any ideas?
Thanks
#5
Try with headphones, and check the mixer… IIRC with opensound there may be many options there, could be some need un-muting. But also perhaps @PulkoMandy can advise as he has a similar (the same?) laptop I believe. I have an x240 here, where I’m fairly sure sound worked fine last time I tried.
#6
Did you blacklist hda driver?
#7
You need to blacklist the HDA driver first, and then yes, you may need to tweak the outputs in Media preferences.
#8
no sound in the headphones
how do I blacklist the Hda driver?
a doc on that topic?
thanks
#9
First link on google search:
https://www.haiku-os.org/guides/daily-tasks/blacklist-packages/
#10
thanks
in
I see 4 dots, in the doc I see 3 dots after
entry blacklist
I tried both but still no sound
#11
You’re looking at the first code-box in the docs which gives its syntax, where “…” stands for optional additional entries. The next code-box and the following example show the actual usage in an example.
In your case the text file /system/settings/packages that should read:
Package haiku  {
	EntryBlacklist {
		add-ons/kernel/drivers/bin/hda
#12
thanks humdinger
done it, rebooted, still no sound
#13
in fact I have sound, not very high, but it works.
I guess I need to check the various gauges.
thanks to all
#14
I just tried this in my X220. If the audio is stuttering, in the process controller widget -> Threads and CPU usage -> MediaPlayer -> MediaPlayer or MediaPlayer audio ou controll and set it to real-time priority.
