I do not know about the rest of you–but the RetroArch software does not work in my Haiku. Although I did give it a go in Windows & OpenSuse–I do not like it one bit! I should never need the Internet to play an emulated game!
In addition, it is not superior to a stand-alone versions of ZSnes 1.51 or Snes9X 1.60…by a long shot!
Thanks…there is no Snes emulators for Haiku 64-bit except for ’ snes9x_libretro’ or ’
bsnes_libretro’ [and one other], which all are part of the RetroArch platform and do not work in my current Haiku (hrev 53379).
In Windows and Linux, I currently use ZSnes. In the past, I have used Snes9X, which works great as well. I also agree with you about BSnes. I never used Higan, which was developed from BSnes–so I cannot compare it.
You might try pressing F5 in the retroarch UI… on windows/mac/Linux in recent versions of retroarch it now has the desktop UI, it doesn’t seem to be enabled on Haiku but I imagine it is possible since haiku has QT5…
For some reason I was thinking you could run libretro cores as standalone applications but they do indeed require retroarch itself.
It’s a fork of BSNES that keeps the Qt GUI (which therefore means it should be easy to get running on Haiku) with some backports of the Higan emulation code.
By the way, if you’re not aware there is a good port of mgba-qt in the x86-64 repo - good for playing some of the GBA ports of SNES games in the meantime…
In the meantime, I have ten+ PC games running through my DosBox…so I will be entertained until a good SNES option happens.
I am a retro gamer where I created a Retro-PC running native era-appropriate OSes and hardware for my actual gaming experience. As a single-player retro gamer, I do not use Steam–should never need the Internet to game either!!
However, I am using Haiku daily now…so a quick game session every once awhile is fun in Haiku!
I had to install 32-bit Haiku so I could play bes9x, bezx, and bevice, and benes.
Retroarch is no fun and just too big. Its getting kind of like MESS: zillions of emulators in varying states of usability and growing heaps of version-specific and outdated documentation.
Old, stand alone emulators had a lot of, err, style. Remeber the DOS NES emulator called “Nesticle”? (I think it was developed by someone called The Shitman.) I fire it up once in a while in Dosbox, just for a laugh.
I wasn’t keen on RetroArch either, and I don’t know if this is of interest to anyone, but Stella, Hatari, and Atari800 can be easily compiled with only slight changes.
RetroArch is a very complicated emulator for me I use the more simply emulators for playing SNES games like ZSNES, Snes9x, Mednafen, higan, SnesGT, BSNES.
