Here is my situation. I have an existing Haiku VM running in Parallels (current version). However, I’m running out of disk space.
Using the normal disk resize in Parallels corrupts the disk.
So, I tried doing a new install following the instructions on haiku-os.org to do so. Getting the any boot image to boot worked perfectly. However, I then tried to install it on a VM drive that I created and attached to the VM. Everything went fine, until I rebooted and tried to boot from this new install drive.
I can’t create a new VM drive that boots. Has anyone had any success with this? It obviously worked at some point, that’s how I created the original VM, that is larger than the any boot image.
Thanks!
