I’m working on it. @PulkoMandy where can I find a square Haiku logo in SVG format? I haven’t been able to find anything like Haiku’s square Github logo as an SVG in the repos.
The logo needs to be square, an SVG, feature the logo and project name, and be displayable on a white background. See my PR, it’s a terribly logo but intended as a placeholder.
Done. The above linked square “H” logo is, as far as I can tell, the preferred logo for these dimension constraints. Otherwise the usual “Haiku” logo, of course.
Does it really need to be square? we have severall non-square logos that fit the bill.
The H logo humdinger mentioned is square-ish, but does not mention the project name as such.
If you need a square one we can probably make you one, though.
@x512 Sure, just flag the first post in the series as “something else” and request it be moved to a new topic.
I don’t think that was ment as an rargument, but rather as an observation.
edit: @rjzak I have the logo exported as SVG from wonderbrush, but since it has the wrong “file extension” the forum forbids me from uploading it, I think you can export it yourself, or alternatively i can provide it to you. the result from the wonderbrush export looks perfectly fine.
Just going by the rules. And a maintainer already approved the PR with the terrible logo I used as a placeholder. So maybe there’s a difference between the written vs. enforced rules.
Logos must include the company, product or project name in English. It’s fine to also include words from another language. If you don’t have a version of your logo with the name in it, please open an issue and we’ll create one for you (and please specify the font).
That’s the full text, but I figured if someone else who isn’t a Haiku user/developer/fan won’t make something as nice as we would.
I need it as an SVG, and Wonderbrush doesn’t convert images to SVG. I used Inkscape and Adobe Illustrator, but they embed the image as base64 and basically just displays that. Which should be fine, but causes errors with RISC-V’s landscape program: FATAL: Item Haiku has no image_data. Seems there’s a check to ensure SVGs are real SVGs, not just embedded images (maybe? I don’t know for sure and don’t know much about graphics).
I also tried https://www.pngtosvg.com/, which I used initially, but it creates messy images. But it might not matter since the log will be small.
Though I do like that line down the middle of the leaf.
