I had e-mailed Mark Adler for zlib 1.1.4 on BeOS 5.
Blockquote
zlib 1.1.4 is almost 20 years old! I only support the most recent version.
All I can suggest is that you try ./configure -s, and then make.
I did that.
Also I’ve read that mupen64 uses gtk, so I installed gtk.
But mupen64 still doesn’t starts (libz.so 1.1.4 is missing).
Also I’ve been trying to copy libz.so (which was installed probably with mplayer - I couldn’t find the version number) from /BeOS5/home/config/libs/ to /boot/apps/mupen64/ - doesn’t starts.
Blockquote
BeBits has version 1.1.4. Sorry to say I don’t use Be anymore since it’s demise so I can’t say if this will work or not, but here is the link http://www.bebits.com/app/2822
But the link is not working.
On pulkomany’s website I’ve found zlib 1.1.3 but not 1.1.4
you can try to create symlink to libz.so in the same folder and name it libz.so.1.1.4 or whatever version is needed. With some luck it could work.
Also since you have zlib 1.1.4.pkg you can open it in SoftwareValet (the default) and in the wizard there will be a step where you can see which files are copied where. Maybe that could be of any help.
