Hmmm, but if I copy mupen64 to the /apps folder and install zlib 1.1.4 pkg and gtk pkg, it should work without doing anything additional.
Also I’m not sure why the other emulators don’t even start, with exception with the ones like Snes9x which work (they are listed previously - which work and which don’t).
So, now some of the emulators like BoycottAdvance work (the difference is I have only zlib 1.1.4 package installed) while mupen64 still doesn’t works and the others finalburn, dgensdl,sdlgnuboy,gens,visualboyadvance show only a command-line insterface, links in BeOS menu don’t start.
when I start ‘/boot/apps/finalburnsdl/finalburnsdl’ in terminal, it shows a line:
using finalburnalpha code: no
how do I enable ‘finalburnalpha code’?
/boot/apps/mupen64/mupen64
mupen64: missing library
probably some other library -not zlib1.1.4- is missing for mupen64 I’m not sure which one?
I wonder why there is a space here and not a period.
Make sure there is a lib (or symlink to a lib) with this exact name in /boot/apps/mupen64/lib folder.
there is also a libdl software valet package. I know this as I installed it a while back under BeOS PPC. I think the one I have is only PPC… but to be honest it might just have symlinked libroot, I didn’t check.
