Problems enabling smp on BeOS 5 using dual P3 cpus
Hi!,
Recently assembled a new system to run old intel beos stufff.
Choose a supermicro P6DBU motherboard looked ideal for BeOS it was old soported dual P3 cpus have onboard scsi agp pci and isa.
So after installing the dual P3 500 cpus, 512megs of ram and a matrox millenium card.
Tryed to run BeOS MAX 4.1 and Zeta 1.2 but no luck the OS will boot and freeze after a few seconds unless I disable SMP support in the boot menu (running using a single CPU all is good).
Now wondering if anyone remembers any kind of fix for SMP issues on BeOS ?.
Hi thanks for the link but don’t see anything relevant to issue there, maybe you can elaborate ?.
The people in the forum thread can help you there as they have P3/P4 setups.
I’ve ran BeOS Max on a 440LX… my BIOS had options for different implementations of SMP support do you have anything like that in yours?
These should show as something about MPS or ACPI. MPS is how SMP was implemented before ACPI. Its likely BeOS is only happy if things are configured just right there.
Yes there’s an option to change MPS 1.1 or MPS 1.4 also theres a ā€œACPI Control Registerā€ enabled/disabled. Tested changing this options but don’t fix the issue.
Interesting issue…I have always run with Asus P2B-D or Gigabyte GA-6BXD motherboards. Never liked the SuperMicro boards for using 440BX chipsets.
It is been a very long time since I installed BeOS 5–but I do not recall doing anything special to get SMP to work. The same is true with Zeta 1.2/1.5 installs.
My retro PC currently runs on GA-6BXC at the moment with Zeta 1.51 (so I can use a P3 1Ghz with 768Mb RAM). When I run with dual CPU MBs, I run dual P3 850MHz CPUs with 1Gb RAM. I believe the default setting is ā€˜ON’ for MPS or ACPI on my MBs.
I am looking for another Asus PB-D MB since the last got fried due to a bad video card.
If you have not checked–make sure you are running on the latest BIOS update/level for the MB. That could impact SMP capabilities.
Already updated the bios to the last level before, don’t seem to be a way to get this working on this motherboard.
But all seems to work ok if smp keep disabled, thees anyway to disable SMP without having to enter the startup menu and disable it in every boot ?
I don’t recall the BeOS PE being non-SMP, could you please support this claim with a link?
Me neither. I had a Asus p2b dualP3 500 which perfectly ran 5.0.3 PE with SMP.
I suggest testing with less ram since 512mb was the limit -including- graphics card.
Be claimed it couldn’t do SMP in the list of restricted features. This was only partially true.
It was non-SMP when hot-loaded from DOS or DOS-based Windows, as the second CPU wouldn’t be active due to said OS. If you installed it to a real hard drive and used bootman, SMP worked.
I have SMP working with 512MB RAM and a Matrox G550 but on a P4 class system, RAM may or may not be the issue.
The only freezing situations i’ve had with beos are the ones related to DMA, therefor your freezing problem might just be a symptom (in combination with smp) of that, so you may wanna try to disable DMA in the boot menu safe options and see what happens.
  • Kernel settings file - uncomment ā€œmultiprocessor_support disabledā€
There are also (commented):
  • smp_io_interrupts enabled
  • max_cpu_number 1
Technically, your BIOS startup screen will reveal both of your CPUs are active on startup. Supermicro may help on the correct settings for legacy OSes like BeOS.
Reading up on issues others have had with this board its probably the IDE controllers not being setup … boards back then you had to often go into the bios and setup the HDD or some nonsense or it would hang. Another user said his would hang with OS/2 unless he went and disabled IDE alltogether (maybe he was booting from SCSI?)
If you wanted to boot from a disk, you needed to detect it in bios. Same as of today, no nonsense needed. Of course, then choose the boot order.
On machines with IDE and SCSI drives, the order would be more picky, with SCSI controllers wanting to be first, even when you didn“t want to boot from them.
One possible test for @soviet9922 would be to boot/install some linux version, to see if the SMP part would work correctly then. Or Windows NT / 2K, that should support two cpus also.
If he installed Zeta 1.2, the OS would automatically detect the multiple CPUs. And he said that even ZetaOS was uni not dual-SMP.
Might be a silly question, during POST, does the BIOS report that both CPUs are detected and reports their info on the booting screen? Refer to attached picture that I found online as an example on how the Award BIOS for GA-6BXD MB’s presents it.
Since the Supermicro P6DBU uses the AMIBios:
Do you see something similar?
And American Megatrends BIOS does this on my 440LX. My old BeOS video happend to include the BIOS during boot. This is also one of those mouse oriented BIOS and it has a GUI and such. Also note that is BeOS Max in the video.
Here some info about MPS (for those us that want to remember the difference between versions 1.1 and 1.4.
Quick Review of MPS Control Version For OS
The MPS Control Version For OS feature is only applicable to multiprocessor motherboards as it specifies the version of the Multi-Processor Specification (MPS) that the motherboard will use. The MPS is a specification by which PC manufacturers design and build Intel architecture systems with two or more processors.
MPS 1.1 was the original specification. MPS version 1.4 adds extended configuration tables for improved support of multiple PCI bus configurations and greater expandability in the future. In addition, MPS 1.4 introduces support for a secondary PCI bus without requiring a PCI bridge.
If your operating system comes with support for MPS 1.4, you should change the setting from the default of 1.1 to 1.4. You also need to enable MPS 1.4 support if you need to make use of the secondary PCI bus on a motherboard that doesn’t come with a PCI bridge.
You should only leave it as 1.1 only if you are running an older operating system that only supports MPS 1.1.
source: https://www.techarp.com/bios-guide/mps-control-version-os/
So for BeOS 5 Pro, I would change the MPS setting to 1.1 and test it. If it is already at 1.1, switch to 1.4. Hopefully, the 2nd CPU will show up (assuming the CPU is good too).
Booting disabling DMA don’t work system freeze.
Tested changing to MPS 1.1 but makes no difference system freeze.
Removed all drives and left only the dvd drive but this makes no difference.
Tried disabling APM enabling PNP mode and a bunch of other options but no luck.
Windows 2000 works great and detects the 2 pentium III 500 mhz, ecomstation (os/2) also detects and works fine using 2 cpu’s.
Sometimes beos will work up to 60 seconds before freezing and I can see if opening Pulse that the dual cpus are detected and working but the system will freeze always after some time passes.
Now if I disable SMP beos works great already do the install fine and can use the computer for hours like this.
Kernel serial output from boot the moment the system freeze
Be Intel Pentium Kernel version of  Sep 15 2000 time 18:29:36
(C) Copyright 1991-97 Be, Inc.  All Rights Reserved.
Total Memory 512 MB
CPU features: 0
IBM PC Compatible platform
CPU speed is 501MHZ
The platform is Intel MPS compliant
APIC Timer clock is 25
Non-default MP configuration was found. Using BIOS provided MP configuration.
MP Configuration Table: 0x002f7088 :
Header: base_len 268, spec_rev 1.4, OEM_ID INTEL   , product_id 440BX
OEM_table_ptr 00000000, OEM_table_size 0, entry_count: 25, LAPIC addr fee00000, ext_table_size 16
CPU: LAPIC_id 0x00, LAPIC_version 11/11, enabled , bootstrap   , family 6, model 7, stepping 2, features 0387fbff
CPU: LAPIC_id 0x01, LAPIC_version 11/11, enabled , nonbootstrap, family 6, model 7, stepping 3, features 0387fbff
Bus: bus_id 0, type: PCI
Bus: bus_id 1, type: PCI
Bus: bus_id 2, type: ISA
IOAPIC: id 2, version 11, flags 01, address fec00000
IO INTERRUPT:    type: EINT, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 00, APIC id 2, APIC INTIN# 0
IO INTERRUPT:    type:  INT, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 01, APIC id 2, APIC INTIN# 1
IO INTERRUPT:    type:  INT, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 00, APIC id 2, APIC INTIN# 2
IO INTERRUPT:    type:  INT, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 03, APIC id 2, APIC INTIN# 3
IO INTERRUPT:    type:  INT, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 04, APIC id 2, APIC INTIN# 4
IO INTERRUPT:    type:  INT, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 05, APIC id 2, APIC INTIN# 5
IO INTERRUPT:    type:  INT, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 06, APIC id 2, APIC INTIN# 6
IO INTERRUPT:    type:  INT, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 07, APIC id 2, APIC INTIN# 7
IO INTERRUPT:    type:  INT, polarity: active high, trigger mode: edge    , bus id 2, bus IRQ 08, APIC id 2, APIC INTIN# 8
IO INTERRUPT:    type:  INT, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 0c, APIC id 2, APIC INTIN# 12
IO INTERRUPT:    type:  INT, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 0d, APIC id 2, APIC INTIN# 13
IO INTERRUPT:    type:  INT, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 0e, APIC id 2, APIC INTIN# 14
IO INTERRUPT:    type:  INT, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 0f, APIC id 2, APIC INTIN# 15
IO INTERRUPT:    type:  INT, polarity: active low , trigger mode: level   , bus id 2, bus IRQ 0a, APIC id 2, APIC INTIN# 16
IO INTERRUPT:    type:  INT, polarity: active low , trigger mode: level   , bus id 2, bus IRQ 0b, APIC id 2, APIC INTIN# 18
IO INTERRUPT:    type:  INT, polarity: active low , trigger mode: level   , bus id 2, bus IRQ 09, APIC id 2, APIC INTIN# 19
IO INTERRUPT:    type:  SMI, polarity: bus spec   , trigger mode: bus spec, bus id 2, bus IRQ 00, APIC id 2, APIC INTIN# 23
LOCAL INTERRUPT: type: EINT, polarity: bus spec   , trigger mode: bus spec, bus id 0, bus IRQ 00, APIC id 255, APIC INTIN# 0
LOCAL INTERRUPT: type:  NMI, polarity: bus spec   , trigger mode: bus spec, bus id 0, bus IRQ 00, APIC id 255, APIC INTIN# 1
IOAPIC #0 Redirection table dump:
PIC_conn_mode = 1
IOAPIC has 24 interrupt lines
 0, unmasked edge , high 7 00  0 00000000
 1, masked   edge , high 0 70  1 fec00000
 2, masked   edge , high 0 80  2 fec00000
 3, masked   edge , high 0 90  3 fec00000
 4, masked   edge , high 0 a0  4 fec00000
 5, masked   edge , high 0 b0  5 fec00000
 6, masked   edge , high 0 c0  6 fec00000
 7, masked   edge , high 0 d0  7 fec00000
 8, masked   edge , high 0 e0  8 fec00000
 9, masked   edge , high 0 f0  9 fec00000
10, masked   edge , high 0 61 10 fec00000
11, masked   edge , high 0 71 11 fec00000
12, masked   edge , high 0 81 12 fec00000
13, masked   edge , high 0 91 13 fec00000
14, masked   edge , high 0 a1 14 fec00000
15, masked   edge , high 0 b1 15 fec00000
16, masked   edge , high 0 00  0 00000000
17, masked   edge , high 0 00  0 00000000
18, masked   edge , high 0 00  0 00000000
19, masked   edge , high 0 00  0 00000000
20, masked   edge , high 0 00  0 00000000
21, masked   edge , high 0 00  0 00000000
22, masked   edge , high 0 00  0 00000000
23, masked   edge , high 0 00  0 00000000
Level triggered interrupts: 9 10 11
PIC is used for IRQs:
LVT dump:
LVT0 : masked   edge  high 0 00
LVT1 : unmasked edge  high 4 00
Timer: masked   edge  high 0 00
Error: unmasked edge  high 0 30
PCI: initiating new PCI scan
Can't find the io interrupt entry with src_bus=00 and src_irq=1f
Warning: absent MPS table interrupt entry for PCI bus 00, device 07, pin 04.
Can't find the io interrupt entry with src_bus=00 and src_irq=1c
Using PIC IRQ 9 for PCI bus 00, device 07, pin 04
Can't find the io interrupt entry with src_bus=00 and src_irq=38
Warning: absent MPS table interrupt entry for PCI bus 00, device 0e, pin 01.
Using PIC IRQ 10 for PCI bus 00, device 0e, pin 01
Can't find the io interrupt entry with src_bus=00 and src_irq=48
Warning: absent MPS table interrupt entry for PCI bus 00, device 12, pin 01.
Using PIC IRQ 11 for PCI bus 00, device 12, pin 01
Can't find the io interrupt entry with src_bus=00 and src_irq=50
Warning: absent MPS table interrupt entry for PCI bus 00, device 14, pin 01.
Using PIC IRQ 9 for PCI bus 00, device 14, pin 01
PIC_conn_mode = 1
PIC is used for IRQs: 9 10 11
LVT dump:
bus  0 device  0 function  0: vendor 8086 device 7190 revision 03
  class_base =  6 class_function = 00 class_api = 00
  line_size=00 latency_timer=40 header_type = 00 BIST=00
  rom_base=00000000  pci 00000000 size=00000000
  cardbus_CIS 00000000 subsystem id 0000 subsystemn vendor id 0000
  interrupt_line=00 interrupt_pin=00 min_grant=00 max_latency=00
  base reg 0: host addr f8000000 pci f8000000 size 04000000, flags 08
  base reg 1: host addr 00000000 pci 00000000 size 00000000, flags 00
  base reg 2: host addr 00000000 pci 00000000 size 00000000, flags 00
  base reg 3: host addr 00000000 pci 00000000 size 00000000, flags 00
  base reg 4: host addr 00000000 pci 00000000 size 00000000, flags 00
  base reg 5: host addr 00000000 pci 00000000 size 00000000, flags 00
bus  0 device  1 function  0: vendor 8086 device 7191 revision 03
  class_base =  6 class_function = 04 class_api = 00
  line_size=00 latency_timer=40 header_type = 01 BIST=00
  primary_bus= 0 secondary_bus= 1 subordinate_bus= 1 secondary_latency=64
  memory_base = 0000fda0 memory_limit = 0000fda0
  bridge_control = 0080 secondary_status = 22a0
  base reg 0: host addr 00000000 pci 00000000 size 00000000, flags 00
bus  0 device  7 function  0: vendor 8086 device 7110 revision 02
  class_base =  6 class_function = 01 class_api = 00
  line_size=00 latency_timer=00 header_type = 80 BIST=00
bus  0 device  7 function  1: vendor 8086 device 7111 revision 01
  class_base =  1 class_function = 01 class_api = 80
  base reg 4: host addr 0000ffa0 pci 0000ffa0 size 00000010, flags 01
bus  0 device  7 function  2: vendor 8086 device 7112 revision 01
  class_base = 12 class_function = 03 class_api = 00
  interrupt_line=09 interrupt_pin=04 min_grant=00 max_latency=00
  base reg 4: host addr 0000ef80 pci 0000ef80 size 00000020, flags 01
bus  0 device  7 function  3: vendor 8086 device 7113 revision 02
  class_base =  6 class_function = 80 class_api = 00
  line_size=00 latency_timer=00 header_type = 00 BIST=00
bus  0 device 14 function  0: vendor 9005 device 001f revision 00
  class_base =  1 class_function = 00 class_api = 00
  line_size=00 latency_timer=40 header_type = 00 BIST=80
  rom_base=febc0000  pci febc0000 size=00020000
  cardbus_CIS 00000000 subsystem id 000f subsystemn vendor id 9005
  interrupt_line=0a interrupt_pin=01 min_grant=27 max_latency=19
  base reg 0: host addr 0000e800 pci 0000e800 size 00000100, flags 01
  base reg 1: host addr febfb000 pci febfb000 size 00001000, flags 04
  base reg 2: host addr 00000000 pci 00000000 size 00000010, flags 00
bus  0 device 15 function  0: vendor 121a device 0002 revision 02
  class_base =  4 class_function = 00 class_api = 00
  interrupt_line=ff interrupt_pin=00 min_grant=00 max_latency=00
  base reg 0: host addr f7000000 pci f7000000 size 01000000, flags 08
bus  0 device 16 function  0: vendor 121a device 0002 revision 02
  base reg 0: host addr f6000000 pci f6000000 size 01000000, flags 08
bus  0 device 18 function  0: vendor 102b device 051b revision 00
  class_base =  3 class_function = 00 class_api = 00
  rom_base=febe0000  pci febe0000 size=00010000
  cardbus_CIS 00000000 subsystem id 2100 subsystemn vendor id 102b
  interrupt_line=0b interrupt_pin=01 min_grant=00 max_latency=00
  base reg 0: host addr fc000000 pci fc000000 size 01000000, flags 08
  base reg 1: host addr febfc000 pci febfc000 size 00004000, flags 00
  base reg 2: host addr fe000000 pci fe000000 size 00800000, flags 00
bus  0 device 20 function  0: vendor 10b7 device 9055 revision 24
  class_base =  2 class_function = 00 class_api = 00
  line_size=08 latency_timer=40 header_type = 00 BIST=00
  rom_base=feba0000  pci feba0000 size=00020000
  cardbus_CIS 00000000 subsystem id 9055 subsystemn vendor id 10b7
  interrupt_line=09 interrupt_pin=01 min_grant=0a max_latency=0a
  base reg 0: host addr 0000ec00 pci 0000ec00 size 00000080, flags 01
  base reg 1: host addr febfaf80 pci febfaf80 size 00000080, flags 00
PCI: chipset uses mechanism #1
pci_init Done
starting cpu 1
Started other CPUs
sysinit1: 1
dma coherent with respect to CPU cache
sysinit1: 2
NTHREADS = 4096, NTEAMS = 1024, NSEMS = 16384
NAREAS = 8192
NPORTS = 4096, MAXMSGS = 8192, MAXBUFS = 8192
sysinit1: 3
sysinit1: 4
MMU large pages: available
BIOS: used(0x0009f000,    61000)
need 4349 segment descriptors and 238 task segments (228 int handlers)
handlers: apicsz = 12, picsz = 12
tasks: apicsz = 12, picsz = 12
total size = 5364, at 0x0031e178
VM initialized (NEW WAY)
sysinit1: 5
sysinit1: 6
sysinit1: 7
sysinit1: 8
sysinit1: 9
sysinit1: 10
sysinit1: 11
sysinit1: 12
sysinit1: 13
sysinit1: 14
sysinit1: 15
sysinit1: 16
sysinit1: 17
sysinit1: 18
sysinit1: 19
sysinit1: 20
sysinit1: 21
sysinit1: 22
sysinit1: 23
mtrr_cap = 508, mtrr_def_type_reg = c00, mtrr_num = 8
done init_mtrrs_intel
cpu_module = 0x0018aa00
Calling sync_mtrrs()
sync_mtrrs()
cpu0_mtrrs = 0x0046a068
Calling isr
cpcpu_u_ddoo_mtmr(0txrc(00x0f30c0830,c8 1)0
 1)c0Ca0l3lc80ng>0xse00t_a6all06_mt)
rrs
(Callfc00ngc80-sex0_a6al_m8)rr
set_ax00_mtrrs_i6a0el(08)0046a0e8)_alwsr(250_m 606060650, 606606)60
06ri6e6_m
sr(2rite8, sr(2060, 60066060660606066)
wrwrte_mte_(258s 606(250606060 606)
0605rite_m505(250, 05)5050
0wr050505)
e_wrsr(e_ms6926 0, 0))
wrwrte_msrte_msr(26a50 0505005550505505
0505ite
mwrite_m269, (2)
6c, rite_m05r(26c, 05050505000505055)
wrwteite_msmsr2626d 5 505505050555050
050wri
e_mwsit(2eb,msr(26
, 0w05050e_ms052650, 505005)5050
0505)
riteitmsrmsr020, 0 0)
wwrite__msr(r6(26 5050 050550505050)
505ri5050msr(202
wr05050e05msr05)
263wr 0)e_
sr(2rit, _m5sr(250f050505)05
050rite_m050(205)
wr 0)
we_mst(_ms5, 20)
 w)
tewrmsre_msr020, , 0))
writetemssr(2002, 0))
writite_mmr(r(28, 0)
8,w 0)
te_msr(2ri4, 0e_
msrri20a_msr 00a,
0wri
te_mitr(2_b, 0)(20b
 wri
we_msr(e_msrc20 0 0
wrwitetemsrsr(020d, 0) 0
rire_te_r(208,s0)
(20rit 0)msr(wr09, 0)te_wrsrte_m2r(2ff, c006)
)D
ne elet_a0l_00rr6ai068)l(
xw04ita068)
mloningca set_allg semtrrs(0xfc003c8rr->0x0046ac068c8
writ0x_ms46(20b, 0))
ofnc0e cpu_do8_0m, r(0x
f
c003ci8t0e, 0s)r
0c, 0)
write_msr(20d, 0)
write_msr(20e, 0)
write_msr(20f, 0)
write_msr(2ff, c06)
Done set_all_mtrrs_intel(0x0046a068)
Done calling set_all_mtrrs(0xfc003c80->0x0046a068)
Done cpu_do_mtr(0xfc003c80, 1)
sync_mtrrs() done
Done calling sync_mtrrs()
Done init_mtrs()
sysinit1: 24
sysinit1: 25
sysinit1: 26
sysinit2: 0
syyssiinitni1:t 271:
27
sysinit2: 2
sysinit2: 3
sysinit2: 6
sysinit2: 7
vga_init_driver()
boot_frame_buffer = 0
vga_uninit_driver()
IDE PCI -- find_devices: intel 82371AB (PIIX4) chipset
IDE PCI -- find_devices: controller supports DMA
IDE PCI -- find_devices: interrupts are sharable
IDE -- try_module: busses/ide/pdc202xx/v0.6 is wrong version
IDE ATA -- configure_dma: drive dma mode: 0x12
IDE ATA -- configure_dma: controller dma mode: 0x12
IDE ATA -- configure_overlap: device doesn't support overlapped commands
IDE ATA -- get_bios_driveinfo: checksum of ata/0/0 matched bios drive 0x80
IDE ATA -- get_bios_driveinfo: checksum of ata/1/0 matched bios drive 0x81
IDE PCI -- uninit
ISA DMA: found intel PIIX/PIIX3/PIIX4 chipset
flo_init: cyl_map[0].address = 0x00001000 size = 00004800
flo_init: cyl_map[1].address =        0 size = 00000000
floppy uninit()
KERNEL: make_fixed_driver: driver already exists! (ata)
can't add boot driver ata to /dev
IDE -- init_v06:
IDE PCI - intwait: timeout - status: 0x50, bm-status: 0x64
regs: 0x00, 0x02, 0x18, 0x00, 0x02, 0x90
IDE ATAPI -- request_sense: no media, ascq 00
IDE ATAPI -- configure_device: drive dma mode: 0x12
IDE ATAPI -- configure_device: controller dma mode: 0x12
IDE PCI - intwait: timeout - status: 0x50, bm-status: 0x24
regs: 0x00, 0x80, 0x18, 0x00, 0xb4, 0x90
IDE ATAPI -- configure_device: drive dma mode: 0x01
IDE ATAPI -- configure_device: controller dma mode: 0x00
IDE -- uninit:
IDE PCI -- uninit
symbios: sim_install()
adaptec: sim_install()
adaptec: located adapter 0 (AIC 7890/91)
adaptec: OSMMapIOHandle(...,0,0,256,0,2,...)
adaptec: opening window to ioregs @ 0x0000e800
adaptec: allocated 36864 bytes of workspace
adaptec: 30021000 / 0119c000
adaptec: initialization succeeded
adaptec: handling irq 10
adaptec: waiting on autoconfig
adaptec: done autoconfig (i=0)
adaptec: successful autoconfig
adaptec: autoconfig processing...
scsi_cam: ccb_pool_size = 32
adaptec: sim_path_inquiry()
adaptec: wide16
scsi_cam: path=0, devcount=16
scsi_cam: module 'busses/scsi/aic78xx/v1' loaded
scsi_cam: module 'busses/scsi/aic78xx/v1' initialized
scsi_cam: path 0 slack...
can't add boot driver fmap to /dev
sysinit2: 8
sysinit2: 9
sysinit2: 10
sysinit2: 11
sysinit2: 12
Scanning /dev/disk
Scanning /dev/disk/floppy
Trying /dev/disk/floppy/raw
floppy uninit()
Scanning /dev/disk/ide
Scanning /dev/disk/ide/ata
Scanning /dev/disk/ide/ata/0
Scanning /dev/disk/ide/ata/0/master
Scanning /dev/disk/ide/ata/0/master/0
Trying /dev/disk/ide/ata/0/master/0/raw
IDE ATA -- get_bios_driveinfo: ata/0/0 match bios drive 0x80
IDE PCI -- uninit
found boot device: /dev/disk/ide/ata/0/master/0/raw
IDE PCI -- uninit
Max log buffer == 256k
Checking block bitmap...
Done checking bitmap.
bfs @ 0x4756d8 (BeOS) on /dev/disk/ide/ata/0/master/0/0_1
sysinit2: 13
  memcpy patched to memcpy_default
  memcpy_internal patched to memcpy_default
  memset patched to memset_default
  memset_internal patched to memset_default
4 pair(s) found
0 pair(s) found
removing raw
removing floppy
removing raw
removing 0
removing slave
removing 0
removing raw
removing 0
removing slave
removing 1
removing atapi
sysinit2: 14
sysinit2: 15
sysinit2: 18
swap size: 640MB
setting vnid 0x100002 (bi@ 0x747b18) to be UN-CACHED
sysinit2: 21
kdbg: Sep 15 2000 18:31:29
kdbg: loaded debugger extension "debugger/disasm/v1"
kdbg: loaded debugger extension "debugger/gdb-stub/v1"
kdbg: loaded debugger extension "debugger/i586/v1"
kdbg: loaded debugger extension "debugger/internals/v1"
kdbg: loaded debugger extension "debugger/parser/v1"
kdbg: loaded debugger extension "debugger/symbols/v1"
sysinit2: 22
sysinit2: 23
sysinit2: 28
sysinit2: 29
sysinit2: 30
Starting  /boot/beos/bin/sh /boot/beos/system/boot/Bootscript
opening (generic) match file for /boot/beos/system/lib/libroot.so
4 pair(s) found
0 pair(s) found
sysinit2: 31
Looking for RTC settings file
clockconfig: No knowledge about contents of RTC
SKD: init_hardware(): checking pci index 0, device 0x8086/0x7190
SKD: init_hardware(): checking pci index 1, device 0x8086/0x7191
SKD: init_hardware(): checking pci index 2, device 0x8086/0x7110
SKD: init_hardware(): checking pci index 3, device 0x8086/0x7111
SKD: init_hardware(): checking pci index 4, device 0x8086/0x7112
SKD: init_hardware(): checking pci index 5, device 0x8086/0x7113
SKD: init_hardware(): checking pci index 6, device 0x9005/0x001f
SKD: init_hardware(): checking pci index 7, device 0x121a/0x0002
SKD: init_hardware(): checking pci index 8, device 0x121a/0x0002
SKD: init_hardware(): checking pci index 9, device 0x102b/0x051b
SKD: init_hardware(): checking pci index 10, device 0x10b7/0x9055
SKD: init_hardware - no supported devices
AKD init_hardware(): checking pci index 0, device 0x8086/0x7190
AKD init_hardware(): checking pci index 1, device 0x8086/0x7191
AKD init_hardware(): checking pci index 2, device 0x8086/0x7110
AKD init_hardware(): checking pci index 3, device 0x8086/0x7111
AKD init_hardware(): checking pci index 4, device 0x8086/0x7112
AKD init_hardware(): checking pci index 5, device 0x8086/0x7113
AKD init_hardware(): checking pci index 6, device 0x9005/0x001f
AKD init_hardware(): checking pci index 7, device 0x121a/0x0002
AKD init_hardware(): checking pci index 8, device 0x121a/0x0002
AKD init_hardware(): checking pci index 9, device 0x102b/0x051b
AKD init_hardware(): checking pci index 10, device 0x10b7/0x9055
AKD: init_hardware - no supported devices
Radeon - init_hardware: Version: 3.3.0.0
Radeon - Radeon_CardDetect: no supported devices found
VMware: init_hardware
VMware: init_hardware: -1
3dfx_v4: init_hardware - Enter - PCI 3dfx-driver: May 26 2000 12:35:09
+++ probe_devices: 0 supported devices
+++ uninit_driver
+++ uninit_driver
create_mtr(0x1a8, fc000000, 01000000, 1)
cpuc_dou_dmot_r(mx00t469(060,x 1)04
6Dx0on469ee 0c,p 1u_
do_Dmtron0xe c0p0u_d6o_m9te(06000, 04)
9e60, 0)
No changes in dir : /boot/beos/etc/fonts/ttfonts
No changes in dir : /boot/home/config/fonts/ttfonts
opening (generic) match file for /boot/beos/system/lib/libbe.so
  _ReservedDragger1__8BDragger patched to DragBitmap__8BDraggerP6BPointP12drawing_mode
  _ReservedSlider1__7BSlider patched to SetOrientation__7BSlider11orientation
  _ReservedSlider2__7BSlider patched to SetBarThickness__7BSliderf
  _ReservedSlider3__7BSlider patched to SetFont__7BSliderPC5BFontUl
  _ReservedHandler1__8BHandler patched to SendNotices__8BHandlerUlPC8BMessage
