0 pair(s) found
5 pair(s) found
input_server: clone_area() error!
input_server: load_add_on(Switcher) success
input_server: instantiating filter Switcher
input_server: load_add_on(WSServerFilter) success
input_server: instantiating filter WSServerFilter
input_server: load_add_on(screen_saver) success
input_server: instantiating filter screen_saver
input_server: load_add_on(MenuKey) success
input_server: instantiating device MenuKey
input_server: registering device Menu Key Device 0 0 from MenuKey
input_server: load_add_on(keyboard) success
input_server: instantiating device keyboard
input_server: StartMonitoringDevice input/keyboard/usb
usbd: [std_ops] std_ops(1)
usbd: [std_ops] loading
usbd: [init_busses] loading module 'busses/usb/ohci/v2'
OHCI: std_ops():
OHCI: MODULE_INIT
OHCI: ohci_init(): built at Feb 22 2001 13:35:22
OHCI: std_ops():
OHCI: MODULE_UNINIT
usbd: [init_busses] loading module 'busses/usb/uhci/v2'
UHCI: std_ops():
UHCI: MODULE_INIT
UHCI: uhci_init(): built at Feb 22 2001 13:35:15
UHCI: new_hcd_info():
UHCI: hc = 0x0102d000
UHCI: frame_list_base = 028e8000
UHCI: io_base = 0xef80, intr_line = 0x09
UHCI: new_roothub_info(0x0102d000), rh = 0x0102c2b0
UHCI: anchor_qh.own_pa = 028ea212
UHCI: Checking legacy support: USBCMD = 0041, PCI_USB_LEGKEY = 0030
usbd: [hcd_cb] adding bus number 0 which allows 0 page boundry crossings
.[31menum:.[0m init_enum()
.[31menum:.[0m bus 0 online
usbd: [get_usb_id] assigned new usb id 1, slot entry 1, ptr = 0x01009dd0
UHCI: create_endpoint(): 0x0102d000, 0x01009e64, 0x600d3040, 0, 1
UHCI: td_num = 8, max_packets_in_row = 1, ioc_period = 4
UHCI: TD cbuf: tds @0x0102fcf0, tds[0].own_pa 028eacf0
UHCI: new ep = 0x01009e80
UHCI: endpoint @0x01009e80:
.hc 0x0102d000
.ep_addr 0
.dev_addr 0
.low_speed 1
usbd: [get_usb_id] assigned new usb id 2, slot entry 2, ptr = 0x01009e48
UHCI: create_endpoint(): 0x0102d000, 0x0102fe54, 0x600d3040, 0, 0
UHCI: td_num = 8, max_packets_in_row = 2, ioc_period = 4
UHCI: TD cbuf: tds @0x0102ff10, tds[0].own_pa 028eaf10
UHCI: new ep = 0x0102fe70
UHCI: endpoint @0x0102fe70:
.hc 0x0102d000
.ep_addr 0
.dev_addr 0
.low_speed 0
usbd: [get_usb_id] assigned new usb id 3, slot entry 3, ptr = 0x0102fe38
usbd: [get_usb_id] assigned new usb id 4, slot entry 4, ptr = 0x01030058
usbd: [set_address] setting address 1 for device 0x01030058
usbd: [get_usb_id] assigned new usb id 5, slot entry 5, ptr = 0x010301d0
UHCI: create_endpoint(): 0x0102d000, 0x0103025c, 0xfd0459cc, 1, 0
UHCI: get_descriptor() returns 1
UHCI: TD cbuf: tds @0x01030330, tds[0].own_pa 028eb330
UHCI: new ep = 0x01030290
UHCI: endpoint @0x01030290:
.hc 0x0102d000
.ep_addr 0
.dev_addr 1
.low_speed 0
usbd: [get_usb_id] assigned new usb id 6, slot entry 6, ptr = 0x01030240
usbd: [load_configs] For loop, i = 0, count = 1
usbd: [load_configs] got real config descr. prepare to parse
usbd: [load_configs] 1 interfaces, 1 endpoints, 0 generic
usb version: 1.00
class/subclass/protocol: 9 / 0 / 0
max packet size 0: 8
vendor/product id: 0x07a4 / 0xbe05
device version: 1.00
manufacturer (text): Be Incorporated
product (text): UHCI Root Hub
serial number (text): <NONE>
num_configurations: 1
[Configuration 1]
number interfaces: 1
configuration_value: 1
configuration (text): <NONE>
attributes: 0xe0
max power (mA): 0
[Interface 1]
interface number: 0
alternate setting: 0
number endpoints: 1
interface: <NONE>
[Endpoint 1]
endpoint type: Interrupt
endpoint address: 1 (IN)
max packet size: 1
interval (ms): 255
usbd: [new_device] new device (/0)
usbd: [do_notify] do_notify(0x01030058, 0)
usbd: [get_usb_id] assigned new usb id 7, slot entry 7, ptr = 0x01030560
UHCI: create_endpoint(): 0x0102d000, 0x010305ec, 0x01030526, 1, 0
UHCI: td_num = 2, max_packets_in_row = 1, ioc_period = 1
UHCI: TD cbuf: tds @0x010306c0, tds[0].own_pa 028eb6c0
UHCI: new ep = 0x01030620
UHCI: endpoint @0x01030620:
.hc 0x0102d000
.ep_addr 129
.dev_addr 1
.low_speed 0
usbd: [get_usb_id] assigned new usb id 8, slot entry 8, ptr = 0x010305d0
.[31menum:.[0m hub /0 configured
.[31menum:.[0m new hub (/0), 2 ports, 0 ms delay, 0 ma
.[31menum:.[0m bus 0 root hub 0x01030058
usbd: [register_driver] driver "hid" registered
usbd: [install_notify] driver "hid" requests notify(), hooks @ 0x600c7224
usbd: [inform] searching children of hub @ 0x01030058
.[31menum:.[0m /0:0 - CONNECTED POWER_ON (connected child, resetting)
.[31mhid.[0m: published 0 devices
usbd: [uninstall_notify] driver "hid" requests no more notify()
usbd: [std_ops] std_ops(2)
usbd: [std_ops] uninit request - not unloading
++++++++ init_driver kb_mouse built May 26 2000 12:35:15
kb_mouse: wait_status (01, 01) timed out after 10 ms
get_data error: output buffer empty!
got 0x55 after 1 retries
got a 0 after 0 retries
Found a keyboard!
Enabling aux interface worked!
Found a PS2 mouse!
kbmouse init_driver: success!
uninit_driver kb_mouse
input_server: watch_node -> B_WATCH_DIRECTORY
usbd: [get_usb_id] assigned new usb id 9, slot entry 9, ptr = 0x00ff8158
usbd: [set_address] setting address 2 for device 0x00ff8158
usbd: [get_usb_id] assigned new usb id 10, slot entry 10, ptr = 0x00ff8260
UHCI: create_endpoint(): Found a keyboard!
0x0102d000, 0x00ff82ac, 0xfc01fee0, 2, 0
UHCI: Found a PS2 mouse!
TD cbuf: tds @0x00ff84a0, tds[0].own_pa 0287f4a0
UHCI: new ep = 0x00ff8420
UHCI: endpoint @0x00ff8420:
kbmouse open 'input/keyboard/at/0'
.hc 0x0102d000
.ep_addr 0
.dev_addr 2
.low_speed 0
opening AT keyboard
usbd: [get_usb_id] assigned new usb id 11, slot entry 11, ptr = 0x00ff8290
!!no scancode file - use built in table
input_server: registering device AT Keyboard 1 8002d618 from keyboard
input_server: load_add_on(mouse) success
usbd: [load_configs] 2 interfaces, 2 endpoints, 2 generic
input_server: instantiating device mouse
usb version: 2.00
input_server: StartMonitoringDevice input/mouse/usb
class/subclass/protocol: 0 / 0 / 0
kbmouse open 'input/mouse/ps2/0'
vendor/product id: 0x046d / 0xc534
SUccessfully enabled PS2 mouse
device version: 29.01
manufacturer (text): Logitech
kbmouse open 'input/mouse/serial/0'
product (text): USB Receiver
input_server: registering device PS/2 Mouse 0 8002d9b0 from mouse
input_server: load_add_on(serial_mouse) success
input_server: instantiating device serial_mouse
[Configuration 1]
number interfaces: 2
configuration (text): RQR29.01_B0016
attributes: 0xa0
max power (mA): 98
[Interface 1]
interface number: 0
lucent hardware not located.
number endpoints: 1
class/subclass/protocol: 3 / 1 / 1
interface: <NONE>
[Endpoint 1]
max packet size: 8
interval (ms): 8
[Unknown Descriptor]
09 21 11 01 00 01 22 3b 00
[Interface 2]
interface number: 1
number endpoints: 1
class/subclass/protocol: 3 / 1 / 2
interface: <NONE>
[Endpoint 1]
endpoint address: 2 (IN)
max packet size: 20
interval (ms): 2
error calling PnP BIOS (83)
Trying data port 0x20b
09 21 11 01 00 01 22 b1 00
usbd: [new_device] new device (/0/0)
usbd: [do_notify] do_notify(0x00ff8158, 0)
PCI->PCI bridges not yet supported
rd = 0x010307b8, rd->driver_name = hid
do_republish(hid, (null))
do_republish(hid, (null)) done
usbd: [_repub_cb] about to republish usb devices
usbd: [_repub_cb] ## republishing hid
publish_command(hid): start
BeOS PCMCIA Card Services 3.0.14
options: [pci] [cardbus]
usbd: [inform] telling "hid" about device @ 0x00ff8158
Intel PCIC probe: usbd: [get_usb_id] assigned new usb id 12, slot entry 12, ptr = 0x011026a8
not found.
UHCI: create_endpoint(): 0x0102d000, 0x011055d4, 0x00ff86db, 2, 0
UHCI: options: [pci] [cardbus]
Intel PCIC probe: UHCI: not found.
TD cbuf: tds @0x010e6950, tds[0].own_pa 02be4950
new ep = 0x010e6810
Intel PCIC probe: UHCI: endpoint @0x010e6810:
not found.
.hc 0x0102d000
.ep_addr 129
.dev_addr 2
.low_speed 0
usbd: [get_usb_id] assigned new usb id 13, slot entry 13, ptr = 0x011055b8
usbd: [get_usb_id] assigned new usb id 14, slot entry 14, ptr = 0x010bea98
UHCI: create_endpoint(): 0x0102d000, 0x0104a94c, 0x00ff86f4, 2, 0
UHCI: TD cbuf: tds @0x010e6770, tds[0].own_pa 02be4770
UHCI: new ep = 0x010e66d0
UHCI: endpoint @0x010e66d0:
.hc 0x0102d000
.ep_addr 130
.dev_addr 2
.low_speed 0
usbd: [get_usb_id] assigned new usb id 15, slot entry 15, ptr = 0x0104a930
.[31mhid.[0m: adding keyboard
.[31mhid.[0m: adding mouse
.[31mhid.[0m: publishing input/keyboard/usb/0
.[31mhid.[0m: publishing input/mouse/usb/0
.[31mhid.[0m: published 2 devices
usbd: [uninstall_notify] unbinding dev 0x00ff8158, cookie 0x00000009
usbd: [put_device] device /0/0 refcount--, now 0
usbd: [put_device] unconfiguring
usbd: [put_usb_id] removed id 12 from the table
usbd: [put_usb_id] removed id 13 from the table
UHCI: cancel_transfers(): 0x010e6810
UHCI: cancel_transfers(): 0x010e6810 done
UHCI: destroy_endpoint(): 0x010e6810
UHCI: endpoint_intr_remove_from_schedule(): 0x010e6810
UHCI: endpoint_intr_remove_from_schedule(): 0x010e6810 done
UHCI: destroy_endpoint(): 0x010e6810 done
usbd: [put_usb_id] removed id 14 from the table
usbd: [put_usb_id] removed id 15 from the table
UHCI: cancel_transfers(): 0x010e66d0
UHCI: cancel_transfers(): 0x010e66d0 done
UHCI: destroy_endpoint(): 0x010e66d0
UHCI: endpoint_intr_remove_from_schedule(): 0x010e66d0
UHCI: endpoint_intr_remove_from_schedule(): 0x010e66d0 done
UHCI: destroy_endpoint(): 0x010e66d0 done
publish_command(hid) done
usbd: [_repub_cb] done republishing usb devices
.[31menum:.[0m /0:0 - CONNECTED ENABLED POWER_ON (connected child, resetting)
usbd: [get_usb_id] assigned new usb id 16, slot entry 16, ptr = 0x0112b400
UHCI: create_endpoint(): 0x0102d000, 0x01139fec, 0x00ff86db, 2, 0
UHCI: TD cbuf: tds @0x0113a0c0, tds[0].own_pa 02f1d0c0
UHCI: new ep = 0x0113a020
.[31menum:.[0m /0:0 - CONNECTED ENABLED POWER_ON (reset ack)
UHCI: endpoint @0x0113a020:
.hc 0x0102d000
.ep_addr 129
.dev_addr 2
.low_speed 0
usbd: [get_usb_id] assigned new usb id 17, slot entry 17, ptr = 0x01139fd0
usbd: [get_usb_id] assigned new usb id 18, slot entry 18, ptr = 0x00eb7898
UHCI: create_endpoint(): 0x0102d000, 0x00c9ca34, 0x00ff86f4, 2, 0
UHCI: TD cbuf: tds @0x00eb6ef0, tds[0].own_pa 02539ef0
UHCI: new ep = 0x01106cf0
UHCI: endpoint @0x01106cf0:
.hc 0x0102d000
.ep_addr 130
.dev_addr 2
.low_speed 0
usbd: [get_usb_id] assigned new usb id 19, slot entry 19, ptr = 0x00c9ca18
input_server: registering device USB Keyboard 1 1 8002df50 from keyboard
input_server: registering device USB Mouse 1 0 8002dd68 from mouse
input_server: starting device Menu Key Device (0) in MenuKey
input_server: starting device PS/2 Mouse (0) in mouse
input_server: starting device USB Mouse 1 (0) in mouse
input_server: starting device AT Keyboard (1) in keyboard
input_server: starting device USB Keyboard 1 (1) in keyboard
flo_init: cyl_map[0].address = 0x00001000 size = 00004800
flo_init: cyl_map[1].address = 0 size = 00000000
floppy uninit()
IDE -- init_v06:
IDE PCI - intwait: timeout - status: 0x50, bm-status: 0x64
regs: 0x00, 0x02, 0x18, 0x00, 0x02, 0x3c
IDE ATAPI -- request_sense: no media, ascq 00
IDE ATAPI -- configure_device: drive dma mode: 0x12
IDE ATAPI -- configure_device: controller dma mode: 0x12
IDE PCI - intwait: timeout - status: 0x50, bm-status: 0x24
regs: 0x00, 0x80, 0x18, 0x00, 0xb8, 0x75
IDE ATAPI -- configure_device: drive dma mode: 0x01
IDE ATAPI -- configure_device: controller dma mode: 0x00
IDE -- uninit:
IDE ATA -- control: unknown ioctl 0x000027d7
IDE ATA -- configure_dma: drive dma mode: 0x12
IDE ATA -- configure_dma: controller dma mode: 0x12
IDE ATA -- configure_overlap: device doesn't support overlapped commands
IDE ATA -- get_bios_driveinfo: ata/1/0 match bios drive 0x81
IDE -- init_v06:
regs: 0x00, 0x02, 0x18, 0x00, 0x02, 0x90
regs: 0x00, 0x80, 0x18, 0x00, 0xbc, 0x90
.[31m1394 bus manager:.[0m Error in get_module(busses/1394/aic5800/v1)
.[31m1394 bus manager:.[0m No 1394 busses found
symbios: sim_install()
unable to get 1394 module
adaptec: sim_path_inquiry()
adaptec: wide16
scsi_cam: path=0, devcount=16
emu10k: init_hardware()
emu10k: init_driver()
adaptec: wide16
Intel PCIC probe: not found.
awe64: init_hardware()
awe64: init_driver()
cs4236: init_driver()
Sound Blaster DSP version 4.16 found at 0x220.
SB Reg 0x81 = 0x36
awe64: successfully found low area at 0x8000
awe64: uninit_driver()
.[36mvdsp:.[0m May 26 2000 12:39:58, init_driver()
.[36mvdsp:.[0m USBD loaded okay
opti931: init_hardware()
usbd: [register_driver] driver "mo" registered
opti931: init_driver()
usbd: [install_notify] driver "mo" requests notify(), hooks @ 0x603c6d48
3c9xx(B) Be99H-WOL 2/24/99
(null): 3Com 3c905B Cyclone 100baseTx at 0xec00, ymf715: init_driver()
.[36mvdsp:.[0m publish_devices()
00.[36mvdsp:.[0m uninit_driver()
:50usbd: [uninstall_notify] driver "mo" requests no more notify()
:da:5f:dc:f9, IRQ 9
8K byte-wide RAM 5:3 Rx:Tx split, autoselect/Autonegotiate interface.
MII transceiver found at address 24, status 7849.
auvia: init_hardware()
MII transceiver found at address 0, status 7849.
Enabling bus-master transmits and whole-frame receives.
Found 3Com Vortex/Boomerang cards found.1
sonorus: init_hardware() 12:39:21 May 26 2000
generic: hw found (1)
(null): 3Com 3c905B Cyclone 100baseTx at 0xec00, awe64: init_driver()
00SB Reg 0x81 = 0x36
:50awe64: successfully found low area at 0x8000
:daawe64: pcm_open()
:5f:dc:f9, IRQ 9
Storing TxRing
Storing RxRing
DmaCtrl was= 20, now= 310020
APM disabled on MP systems
||| init: returning 0
PATH = /boot/apps/Switcher-1.0.4/Indicator, addon_id = 455
func_name = Instantiate__8DeskViewP8BMessage, err = No Error
PATH = /boot/apps/MemoChip86/MemoChip, addon_id = 461
func_name = Instantiate__10MCMiniIconP8BMessage, err = No Error
(null): 3Com 3c905B Cyclone 100baseTx at 0xec00, 00:50:da:5f:dc:f9, IRQ 9
Storing TxRing
Storing RxRing
PATH = /boot/home/config/bin/VolumeControl, addon_id = 490
func_name = Instantiate__10VolumeViewP8BMessage, err = No Error
awe64: DMA half-page is 2048
Interesting that BeOS 5 Pro is reporting a non-default SMP config, where I would have expected to be using a default config.
Wonder if the system freeze is related to these errors:
``Warning: absent MPS table interrupt entry for PCI bus 00, device 0e, pin 01."
Since this MB supports âWindows 95, Windows 98, Windows ME, Windows 2000 & Windows XPââI expect the default would be MPS 1.4 and this MB was probably manufactured in the post-BeOS 5 era. Thatâs why Windows 2000 installs easily. So this MB may not be fully compatible with BeOS.
BeOS 5 runs pretty flawlessly on my Tyan S1836 with a pair of 450MHZ pentium III CPUs, which is funny because I hate tyan boardsâŚ
Motherboards:
- Normally, donât install greater than 1GB RAM.
- Donât use MPS 1.4 - disable it and use MPS 1.1-only.
- Disable APIC.
- Check for secondary CPU activity during the BIOS boot screen.
