[quote=bbjimmy]Since the program crashes ( closes without any error message ) and won’t allow one to send the information, there will never be any data feedback. The project is a great idea, it just needs to get the bugs worked out.
BeSly Software Solutions
Developers: Christian Albrecht, Lorenz Glaser
Version 0.2.1 - Oktober 2015
– EDIT –
I removed the .besly folder in /boot/home ( this should really be moved to /boot/home/config/settings/besly ) and the program re-built the database and it seemed to work this time. My issue may have something to do with having installed and attempted to run a previous version.[/quote]
ok i will see to local this error. i never have it by myself.
such bugs are not possible to solve without a bug report.
i have some problems with storing userdata into a settings folder. this is not correct. i select the hone folder for the User file because it is the right folder in my eyes. and so long haiku have so many changes and writing rights changes i let them there. we can talk about this past haiku r1.
