Hello Haiku users,
the BeSly knowledge base start up a new project of storing hardware data of Haiku users in order to get a hardware database in the future.
http://software.besly.de/images/BeSlySAT.png
Program description:
About this Project
Many people ask for a database of compatible hardware for haiku. A project like this is a very big work and does not possible without the help of the users himself.
This project will try to generate a database like this, but not only to store compatible hardware, we want to collect all tried hardware, so developers can look into the database to work on new drivers too.
We also add a export funktion to get a text file for the haiku bug tracker, so you can add a hardware profile of your computer within a bug report.
How to use
Analysis:
Then you start the program many informations about your computer will be collected using the system commands “listdev” and “uname”.
You see a list of questions about yours system, answer them to generate a hardware profile of your system.
Store your hardware data using the database menu “add hardwaredata”.
We do a cut between program database and user database, so you can update your program database and add your own files of your user database into the program without destroying older entries.
Send you hardware data to BeSly selecting “Send your Database to BeSly” in the database menu (Here you only send the user database files to BeSly). A mail will be generated with the sending address, your database files included a zip archive and a generated subject.
Database:
Select the “Database” tab to see the hardware database. if you select one of the listed files the Hardware list will be listed at “Hardware”. All other informations are listed in the “Database” table.
Update the database
To update the database, select in the database menu “Update Database”. If a newer version is available you will be asked to install it.
Future plans:
- We want to generate a online database on the BeSly knowledge base.
- Some more export functions
- Let us see that the users asking for
- We hope to get any help of the Haiku main developers to can collect more usefull hardware informations
This first release are for testing, bug hunting and idea catching. We hope that many people have fun to send us there hardware informations stored with BeSly SAT.
You can download the HPKG package from our repository website: http://software.besly.de (not available over haikudepot)
It is very usefull in a haiku boot usb stick
We hope you enjoy and help us to make this successful.
Greetings Lelldorin
Tutorial: http://besly.de/menu/search/archiv/misc/beslysat.html
http://www.besly.de
