I’m doing a “Quick Tour” where I have a couple of html pages where the user can go from one to the next.
Now I want to add an indicator on what page we are. I’d like to used a line of dots at the top, all white, only the current page with a black dot.
I made the changes in the “dots” branch at my github for the start-page only so far: See 1-start.html.
Unfortunately, I lack some html/css skills here…
How do I get to have the current page’s dot black most elegantly?
Please see the “navdots” entry in the Haiku-tour.css how I did so far.
The acronym elements would look better without the dotted underline, which you can remove. And for the current page’s bullet, you can use the same color as you use for the visited links - it stands out better than black. Then you can use that class on the current page’s acronym element.
By the way, the Previous and Next buttons are too small for a comfortable navigation with the mouse. Adding the name (text) of their functionality would really help.
It’s a visual thing - the navigation dots don’t have a clean look with the dotted underline. And the underline shows up in Chrome and Firefox, by using your link.
True, the buttons should be fully clickable. The problem is the links (anchors) are inside the spans, which have padding. The links could be styled without the spans and this problem would go away.
Very nice work! It is a good selection of topics and images, and simple enough to be a good and quick read.
I think the first page should start with more positive mood, instead of focusing already on the “confusion”. Just say something cool about Haiku, before approaching the “confusion”. Actually, maybe the sentence could be rephrased in order to avoid that word
I also have the feeling that some parts of the text could benefit from some skilled native English reviewer. But please don’t get me wrong on this, I really liked this work, and I just think it deserves attention to detail, since soon it’s probably going to be one of the first impressions for new Haiku users.
While Haiku shares many ideas with other operating systems, it does have a unique approach in some areas that are worth pointing out. In just a few slides, you’ll learn about the most important Haiku features and peculiarities that’ll help you get a running start.
You’re probably right. If you can be more specific, we can improve these passages.
I think it’s planned to have it included with the next Beta. Until then, the QuickTour is also available in HaikuDepot.
@waddlesplash, did you get a look at the user guide translation tool, and how we could deal with the QuickTour pages? I think I remember you mentioning something about that some time ago.
In 14_mounting.html, it says iso images can be mounted with a double click. This doesn’t work for me (x86_64.) Is this a sneak peek of an upcoming feature?
I’ll try it out sometime. You did hit the nail on the head. I was trying it on an anyboot. That might be a point of clarification in the tour until it’s implemented.
We should make this work for anyboot too. I think it’s a matter of having a MIME sniffing rule detecting the intel partitions in the image, and associating the file with mountvolume?
I think it’s more than that. At least my Haiku Beta anyboot has the correct MIME type application/x-cd-image and default application mountvolume associated. But it still won’t mount on double-click.
