Some improvement from last time. Now the Manuskript created file has its own icon, instead of a compressed file one. Not sure if will be the final design though:
Double clicking on the file icon, (Test.msk) opens Manuskript, as expected, but does not open the Test.msk file. Also as expected, the app is a wrapper around Python, so I presume I must tell the wrapper to pass the file to the inner python app.
It couldn’t be that easy…
Getting there though, yep, I’m a bit slow…
Regards,
RR
Ah, well, that’s going to pull in a certain amount of Haiku specific functionality. Your wrapper will need to be a BApplication subclass instance to do this, and handle entry_ref values passed to its RefsReceived() member function. Unless someone knows of another way to get there. Oh, and you’d have to turn those files into Python objects, possible a Python list of Python objects depending on how your application handles multiple files.
Right off hand I can’t guess how the Haiku application dispatching system ties in with the Qt functions … are you already subclassing BApplication, or just starting the interpreter directly from main()?
Have you considered Pete Goodeve’s xicon?
Maybe not exactly what you need, but at least worth a try, and maybe looking at the sourcecode for inspiration.
@donn, it is indeed a BApplication. While on the Awesome tutorial I didn´t use the BApplication, the Manuskript work is an evolved version of that, using the BApplication class. When the whole process is finished will post the step-by-step guide again with all the acquired knowledge for others to use, and the whole code available, of course.
@PulkoMandy, I will take a look at the xicon sourcecode as you point out. @donn@PulkoMandy, in my ignorance, what I was thinking to try is instead of a BApplication(void), have it like BApplication(filename) - pseudo code:
Call BApplication(python filename to launch)
if filename == null
just launch the BApplication wrapper
else
pass the filename to the BApplication and launch "python3 filename"
though I haven´t got into that yet. Most likely will do this weekend if get Haiku time slot. I need to figure out how to do that, as @donn noted, and check what @PulkoMandy pointed.
while process outcome != success
me = keep working
else
me = happy
move to next task
Thanks both and those who replied here with hints on how to get this “far”. Hopefully will be finished soon.
Good, then you’re already set up in the dispatch model to some extent, like I guess you’re calling into Python from ReadyToRun(). So once you add a RefsReceived() method, the files will show up there.
Note that they could show up later - a RefsReceived() message could be delivered at any time, via a “drop” event, though in the scenario I think we’ve been talking about those messages will have been delivered before ReadyToRun().
@mazbrili, almost a year later, I took a look at the recipe of Calibre… anyway… sometimes need a brain change.
It does seem a bit harder to prepare a recipe for Haikuports than to make a package for Haiku (the recipe file is loooooong), so for now I’ll stick with the package, and once the HPKG process is complete, next step is make it into a recipe to have it available to all on Haikuports.
yes… it is bit intimidating at first time… usually i just go copy recipe that not too long and modify to my need step by step…
good luck… we waiting your recipe
Sorry 'bout that…! It wasn’t the easiest code to write either! Most of the hairiness, as I remember, was in trying to handle Terminal properly, not in the fairly standard drag&drop and stuff.
It was a lonnngg time ago, but if there are any specific questions i can try to answer them! (I haven’t looked at the whole thread, so I’m afraid I don’t know your exact goals.)
RefsReceived doesn’t need to be super complicated, though there’s some things that could go wrong for a non-native C++ speaker. Example that just copies the file names to /tmp/dropfiles. Some of this is copied out of the BeOS Developer’s Guide:
#include <app/Application.h>
#include <app/Message.h>
#include <storage/Entry.h>
#include <storage/Path.h>
#include <stdio.h>
#include <stdlib.h>
struct A: BApplication {
BList *fileList;
A(): BApplication("application/x-test") {
fileList = new BList();
void RefsReceived(BMessage *msg) {
uint32 type;
int32 count;
msg->GetInfo("refs", &type, &count);
if (type == B_REF_TYPE) {
int i;
for (i = 0; i < count ; ++i) {
entry_ref ref;
if (msg->FindRef("refs", i, &ref) == B_OK) {
BEntry entry(&ref);
BPath path;
entry.GetPath(&path);
fileList->AddItem(strdup(path.Path()));
void ArgvReceived(int argc, char **argv) {
int i;
for (i = 1; i < argc; ++i)
fileList->AddItem(strdup(argv[i]));
void ReadyToRun() {
FILE *fp = fopen("/tmp/dropfiles", "w");
int n = fileList->CountItems();
int i;
for (i = 0; i < n; ++i)
fprintf(fp, "%d: \"%s\"\n", i, (char *) fileList->ItemAt(i));
PostMessage(B_QUIT_REQUESTED);
int
main(int argc, char **argv)
A app;
app.Run();
Then you have to get Haiku to register your application for the type of files you want to accept. That’s in the FileTypes preference application.
EDIT: I’ve successfully cloned the project and succeeded to run it using the directions from the starting post of the thread. It’s still a pity that the work on the icon and on the opening files is lost.
The work on the icon isn’t lost. The opening files, as far as I remember wasn’t achieved at that time when I did that. I still keep all files but Manuskript has evolved into new versions. I never got to create the proper recipe, I’m still trying to figure out what a recipe does, and starting to understand it. To be honest, recipes do intimidate me a little bit, certainly until I do get to understand them, as with the first time I used Icon-O-Matic, I presume.
The Icon-O-Matic file is here:
Besides the Manuskript Icon, there I have other icons for other software I was trying, as well as some other generic icons.
At first I thought that I had to build a C++ wrapper around Python software, but in the end it looks like a proper recipe is just enough to get the software icon on the deskbar as well as the file opening thing. I did got to achieve the file association, though now I don’t remember in which thread it is. In fact, I didn’t figure out that myself, I was helped by other people here in the community @donn, @extrowerk, @Lrrr ? Can’t remember now. If I recall correctly, it had something to do with the PackageInfo file too. I have to review the work to precisely see where it was set.
Right now I’m working on a hardware project so Haiku improvement is going veeeeeery sloooowly, though eventually the hardware will run on Haiku too.
