LibreOffice is now available for Haiku
Ahoy,
Sorry, but Qt is not on 6.6 in the HaikuDepot , but qt 6.70 base packages available since
2024-04-14, last Sunday
some additional Qt 6.x packages became available on
2024-04-15, actual Monday
at least for Haiku 64bit
Me myself was patient about Libreoffice upgrade
as for
when the update arrives into HaikuDepot
absolutely depends on the porter - 3deyes -
As he decides when the port is successful and bug free , tested well
related to Haiku release
so safe to provide in the repo.
Until then the available one is also enough good to use for any work.
Do you know such improvement in the new release or issue in actual one that justify to
have the new version installed as soon as possible ?
Or is this just about an urging matter … as it is already out for other operating system(s) ?..
~> ls -l /boot/system/packages/qt6*
-rw-r--r-- 1 user root    613701 ápr.   14 20:29 /boot/system/packages/qt6_5compat-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root  20522527 ápr.   14 20:28 /boot/system/packages/qt6_base-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root   1157478 ápr.   14 20:28 /boot/system/packages/qt6_charts-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root    232680 ápr.   14 20:29 /boot/system/packages/qt6_connectivity-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root    876089 ápr.   15 15:17 /boot/system/packages/qt6_datavis3d-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root  18781052 ápr.   14 20:28 /boot/system/packages/qt6_declarative-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root 263037126 ápr.   15 15:17 /boot/system/packages/qt6_doc-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root    106171 ápr.   14 20:28 /boot/system/packages/qt6_imageformats-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root   1023546 ápr.   16 14:55 /boot/system/packages/qt6_location-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root    185347 ápr.   15 15:11 /boot/system/packages/qt6_lottie-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root   1237603 ápr.   14 20:29 /boot/system/packages/qt6_multimedia-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root    100754 ápr.   15 15:11 /boot/system/packages/qt6_networkauth-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root    560184 ápr.   15 15:00 /boot/system/packages/qt6_positioning-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root    171208 ápr.    7 01:51 /boot/system/packages/qt6_qtspeech-6.6.0-1-x86_64.hpkg
-rw-r--r-- 1 user root   6882769 ápr.   15 15:11 /boot/system/packages/qt6_quick3d-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root   3168981 ápr.   15 15:11 /boot/system/packages/qt6_quick3dphysics-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root     96650 ápr.   15 15:11 /boot/system/packages/qt6_quicktimeline-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root    763237 ápr.   15 15:11 /boot/system/packages/qt6_scxml-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root    259195 ápr.   15 15:00 /boot/system/packages/qt6_sensors-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root     65368 ápr.   15 15:00 /boot/system/packages/qt6_serialport-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root   2136549 ápr.   14 20:28 /boot/system/packages/qt6_shadertools-6.7.0-3-x86_64.hpkg
-rw-r--r-- 1 user root    294365 ápr.   14 20:28 /boot/system/packages/qt6_svg-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root  47160361 ápr.   14 20:29 /boot/system/packages/qt6_tools-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root   3786551 ápr.   15 15:00 /boot/system/packages/qt6_translations-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root    153360 ápr.   15 15:11 /boot/system/packages/qt6_webchannel-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root    129872 ápr.   15 15:11 /boot/system/packages/qt6_websockets-6.7.0-1-x86_64.hpkg
-rw-r--r-- 1 user root     86840 ápr.   16 14:55 /boot/system/packages/qt6_webview-6.7.0-1-x86_64.hpkg
LibreOffice has been updated to version 24.3.2.1. You can test it.
Thank you very much . upgraded…works beautifully
One version higher than on Voidlinux
However, LO appears flashy, beautiful on Haiku
On Voidlinux, it appears somewhat dull, dreary
Maybe because as you said Haiku uses QT backend while linux uses GTK?
Does the spell checker work for anyone? English(USA) is selected, but the Automatic Spell Checking doesn’t flag incorrectly spelled words. Doing a manual check doesn’t show anything and the drop down menu for language is blank with no options to set it.
Am I missing something that should be installed? AbiWord does spell check correctly, and I don’t know if that means anything or not.
You need to download the dictionary from the LibreOffice extensions site and install it:
Nice! As there are already language packs for LibreOffice in HaikuDepot, would it make sense to add those dictionaries to those?
Good idea - I’ll try to do that
Thank you for this last post, it helped me to install/activate Hungarian spellchecking in LibreOffice.
From Linux I remembered I need hunspell to be installed and that establish Hungarian spell checking system-wide as apps would yuse spell checking would find it.
~> pkgman search hunspell -D
Repository Name Version Arch
enchant 2.5.0-1 x86_64
HaikuPorts enchant 2.5.0-1 x86_64
hunspell 1.7.2-1 x86_64
HaikuPorts hunspell 1.7.2-1 x86_64
HaikuPorts hunspell_devel 1.7.2-1 x86_64
HaikuPorts hunspell_source 1.7.2-1 source
Against that this latest available version and installed it was not enough to activate spell checking in Libreoffice.
However I found that …
a Hungarian dictionary is available and is set to use,…
I could not select - on Spellchecking panel - the appropriate
Language → Magyar
the pull down stuff was inactive and at Language was ‘None’ only.
I had not made screenshot about it then.
So I tried out to use that language extension you posted last.
As it is on Github, I tried to get the files with git - into my home dir.
~> mkdir -p 755 LibreOffice_dictionaries
~> cd LibreOffice_dictionaries
~/LibreOffice_dictionaries> git https://github.com/FaridZelli/LibreOffice-dictionaries
git: 'https://github.com/FaridZelli/LibreOffice-dictionaries' is not a git command. See 'git --help'.
~/LibreOffice_dictionaries> git --help
usage: git [-v | --version] [-h | --help] [-C <path>] [-c <name>=<value>]
           [--exec-path[=<path>]] [--html-path] [--man-path] [--info-path]
           [-p | --paginate | -P | --no-pager] [--no-replace-objects] [--bare]
           [--git-dir=<path>] [--work-tree=<path>] [--namespace=<name>]
           [--config-env=<name>=<envvar>] <command> [<args>]
These are common Git commands used in various situations:
start a working area (see also: git help tutorial)
   clone     Clone a repository into a new directory
   init      Create an empty Git repository or reinitialize an existing one
work on the current change (see also: git help everyday)
   add       Add file contents to the index
   mv        Move or rename a file, a directory, or a symlink
   restore   Restore working tree files
   rm        Remove files from the working tree and from the index
examine the history and state (see also: git help revisions)
   bisect    Use binary search to find the commit that introduced a bug
   diff      Show changes between commits, commit and working tree, etc
   grep      Print lines matching a pattern
   log       Show commit logs
   show      Show various types of objects
   status    Show the working tree status
grow, mark and tweak your common history
   branch    List, create, or delete branches
   commit    Record changes to the repository
   merge     Join two or more development histories together
   rebase    Reapply commits on top of another base tip
   reset     Reset current HEAD to the specified state
   switch    Switch branches
   tag       Create, list, delete or verify a tag object signed with GPG
collaborate (see also: git help workflows)
   fetch     Download objects and refs from another repository
   pull      Fetch from and integrate with another repository or a local branch
   push      Update remote refs along with associated objects
'git help -a' and 'git help -g' list available subcommands and some
concept guides. See 'git help <command>' or 'git help <concept>'
to read about a specific subcommand or concept.
See 'git help git' for an overview of the system.
~/LibreOffice_dictionaries> git clone https://github.com/FaridZelli/LibreOffice-dictionaries
Cloning into 'LibreOffice-dictionaries'...
remote: Enumerating objects: 68, done.
remote: Counting objects: 100% (2/2), done.
remote: Compressing objects: 100% (2/2), done.
remote: Total 68 (delta 1), reused 0 (delta 0), pack-reused 66
Receiving objects: 100% (68/68), 82.70 MiB | 1.80 MiB/s, done.
Resolving deltas: 100% (1/1), done.
~/LibreOffice_dictionaries> ls -l
total 6
drwxr-xr-x 1 user root 4096 ápr.   23 07:28 LibreOffice-dictionaries
~/LibreOffice_dictionaries> cd LibreOffice-dictionaries
~/LibreOffice_dictionaries/LibreOffice-dictionaries> ls -l
total 85636
-rw-r--r-- 1 user root   419294 ápr.   23 07:28 af_ZA.oxt
-rw-r--r-- 1 user root    80375 ápr.   23 07:28 an_ES.oxt
-rw-r--r-- 1 user root  1459958 ápr.   23 07:28 ar.oxt
-rw-r--r-- 1 user root  1619104 ápr.   23 07:28 be_BY.oxt
-rw-r--r-- 1 user root  1257451 ápr.   23 07:28 bg_BG.oxt
-rw-r--r-- 1 user root   342496 ápr.   23 07:28 bn_BD.oxt
-rw-r--r-- 1 user root     5475 ápr.   23 07:28 bo.oxt
-rw-r--r-- 1 user root   758140 ápr.   23 07:28 br_FR.oxt
-rw-r--r-- 1 user root   103843 ápr.   23 07:28 bs_BA.oxt
-rw-r--r-- 1 user root  1489828 ápr.   23 07:28 ca.oxt
-rw-r--r-- 1 user root   118208 ápr.   23 07:28 ckb.oxt
-rw-r--r-- 1 user root  3985540 ápr.   23 07:28 cs_CZ.oxt
-rw-r--r-- 1 user root  1852901 ápr.   23 07:28 da_DK.oxt
-rw-r--r-- 1 user root 17887048 ápr.   23 07:28 de.oxt
-rw-r--r-- 1 user root  1813786 ápr.   23 07:28 el_GR.oxt
-rw-r--r-- 1 user root  5089144 ápr.   23 07:28 en.oxt
-rw-r--r-- 1 user root   228373 ápr.   23 07:28 eo.oxt
-rw-r--r-- 1 user root  6017749 ápr.   23 07:28 es.oxt
-rw-r--r-- 1 user root   818216 ápr.   23 07:28 et_EE.oxt
-rw-r--r-- 1 user root   347884 ápr.   23 07:28 fa_IR.oxt
-rw-r--r-- 1 user root  1852579 ápr.   23 07:28 fr_FR.oxt
-rw-r--r-- 1 user root   909051 ápr.   23 07:28 gd_GB.oxt
-rw-r--r-- 1 user root  1701956 ápr.   23 07:28 gl.oxt
-rw-r--r-- 1 user root   562094 ápr.   23 07:28 gu_IN.oxt
-rw-r--r-- 1 user root    38503 ápr.   23 07:28 gug.oxt
-rw-r--r-- 1 user root  1029438 ápr.   23 07:28 he_IL.oxt
-rw-r--r-- 1 user root    65497 ápr.   23 07:28 hi_IN.oxt
-rw-r--r-- 1 user root   211769 ápr.   23 07:28 hr_HR.oxt
-rw-r--r-- 1 user root  1860272 ápr.   23 07:28 hu_HU.oxt
-rw-r--r-- 1 user root   759999 ápr.   23 07:28 id.oxt
-rw-r--r-- 1 user root   691827 ápr.   23 07:28 is.oxt
-rw-r--r-- 1 user root  1132804 ápr.   23 07:28 it_IT.oxt
-rw-r--r-- 1 user root    51627 ápr.   23 07:28 kmr_Latn.oxt
-rw-r--r-- 1 user root   820031 ápr.   23 07:28 ko_KR.oxt
-rw-r--r-- 1 user root   121583 ápr.   23 07:28 lo_LA.oxt
-rw-r--r-- 1 user root   296613 ápr.   23 07:28 lt_LT.oxt
-rw-r--r-- 1 user root   385675 ápr.   23 07:28 lv_LV.oxt
-rw-r--r-- 1 user root  1730270 ápr.   23 07:28 mn_MN.oxt
-rw-r--r-- 1 user root   313447 ápr.   23 07:28 ne_NP.oxt
-rw-r--r-- 1 user root   638699 ápr.   23 07:28 nl_NL.oxt
-rw-r--r-- 1 user root  3015505 ápr.   23 07:28 no.oxt
-rw-r--r-- 1 user root   566978 ápr.   23 07:28 oc_FR.oxt
-rw-r--r-- 1 user root  1950245 ápr.   23 07:28 pl_PL.oxt
-rw-r--r-- 1 user root  5879877 ápr.   23 07:28 pt_BR.oxt
-rw-r--r-- 1 user root  1160041 ápr.   23 07:28 pt_PT.oxt
-rw-r--r-- 1 user root      435 ápr.   23 07:28 README.md
-rw-r--r-- 1 user root  1448912 ápr.   23 07:28 ro.oxt
-rw-r--r-- 1 user root  1076252 ápr.   23 07:28 ru_RU.oxt
-rw-r--r-- 1 user root   264770 ápr.   23 07:28 si_LK.oxt
-rw-r--r-- 1 user root  1042334 ápr.   23 07:28 sk_SK.oxt
-rw-r--r-- 1 user root  1447207 ápr.   23 07:28 sl_SI.oxt
-rw-r--r-- 1 user root   641767 ápr.   23 07:28 sq_AL.oxt
-rw-r--r-- 1 user root  1932262 ápr.   23 07:28 sr.oxt
-rw-r--r-- 1 user root  1587344 ápr.   23 07:28 sv_SE.oxt
-rw-r--r-- 1 user root   202104 ápr.   23 07:28 sw_TZ.oxt
-rw-r--r-- 1 user root   493833 ápr.   23 07:28 te_IN.oxt
-rw-r--r-- 1 user root   247472 ápr.   23 07:28 th_TH.oxt
-rw-r--r-- 1 user root  2114218 ápr.   23 07:28 tr_TR.oxt
-rw-r--r-- 1 user root  1547195 ápr.   23 07:28 uk_UA.oxt
-rw-r--r-- 1 user root    15168 ápr.   23 07:28 vi.oxt
-rw-r--r-- 1 user root     2600 ápr.   23 07:28 zu_ZA.oxt
~/LibreOffice_dictionaries/LibreOffice-dictionaries> less README.md
As I had the files, and especially the hungarian one among them, moreover there were no useful infos how to add to LibreOffice in the README file, …
I tried out as you showed to add an extension - in earlier post - within LibreOffice.
Then I checked spellchecking in Writer - writing a word intentionally WRONG - it marked as wrong as usually done in apps
I fixed the wrong letter in the word - the marking disappeared
It works now this way - I dunno why hunspell and libreoffice packages does not enough to be installed on Haiku to activate the Hungarian spellchecking in LibreOffice …
Maybe the hunspell is different for the newest version of Libreoffice.
However I found 1.72 on Github as well - as it is in the Haikuports repo.
Anyway -
Thank you, Gerasim, it helped to setup spellchecking.
I made this long post ..
maybe give a help for others to install for their language too.
I did it. Everything’s working fine. The language packs contain dictionaries in addition to localization. I will push it to haikuports tomorrow.
works quite fine but I get consistent crashes when trying to hop into presentation mode. Where do I report Haiku specific bugs? It’s not happening on Linux.
Issues regarding ported software can be reported here: Issues · haikuports/haikuports · GitHub
The problem is enabling full screen mode. If you enable presentation mode in a window, the problem does not happen.
Ah okay thanks… is this a known issue (i.e. already in GitHub issue tracker)?
Because I’d really need fullscreen mode for a proper presentation, so this is only a workaround…
I fix this bug. You just need to wait for the builder to build the package. I think it will be tomorrow.
Fantastic!!!
Fixed version is available now, you can update and check it out
See: LibreOffice Calc: pasting to multiple cells doesn’t work · Issue #5990 · haikuports/haikuports · GitHub
Fixed?
I expect this is a beginner question. I just downloaded the application, and it runs OK but can’t deal with documents, apparently lacking fonts. There’s just Noto; it persistently thinks I’ll want to use Thai Noto, which one would think might be a preference one could change, but the real problem is that I don’t particularly want to use any Noto. It can convert the document to a readable PDF, so the font info is in here somewhere. Is there a separate package download that provides the fonts for document work?
