Lazarus 1.9 trunk Qt4 and Qt5 interface (screenshots)
OK, not sure if this means that it works (think it’s using the internal debugger?)
Lazarus-debug
You can choose if al is right internal or gdb. The screenshot shows non-working debugger I think.
OK, just wanted to check :wink:
EDIT Same error when I switch to system gdb …
We use gdb 8 I think, while Lazarus expects a newer one . The header version in exes has been increased in the meantime. I think laz creates version 4 where gdb 8 expects an older one (2 I think).
So gdb does not recognize the laz builds correctly.
Yeah, there has been some mentioning on that in this thread iirc …
Out of curiosity: Does CudaText in your screenshot use standard font selection dialog, or it is in-home written specially for CudaText?
Not sure there, I know the font and fontsize are set in the source for CudaText.
Small changes related to freepascal in my repository Hakilo
  • Fixed fpc 3.2.0 to avoid problems with libiconv.
  • Renamed packages to fpc_haki and fpc_haki_source so names differ from haikuports versions. I don’t always need the latest version from haikuport, but I can’t prevent updating for a particular package
Now you can build fresh Lazarus 2.2 for testing
VirtualBox_Haiku64_10_02_2022_08_21_07
Just a “heads-up” regarding issues with serial ports. There have been some fixes related to termios calls (tcflush / tcsendbreak) not long ago. See: #17861 (tcflush() is implemented incorrectly) – Haiku.
Might warrant re-testing apps using those calls.
There are still other unresolved issues: #17867 (BSerialPort's WaitForInput() and timeout handling are broken.) – Haiku.
TL;DR;: Until those are fixed, do not rely on read timeouts, use select() and then read().
@rudolfc: Might want to check your inbox here. I’ve sent you a DM about this.
The latest version Lazarus 3.0 works well with the qt6 interface.
