IPP printing over CUPS
I’ve installed Haiku in a shared space because I think it is a good system for the usecase we need. I’m currently setting up the printing stuff. We have two printers connected to a tiny server which runs a CUPS server that shares the printers over IPP.
Under Linux, a printer utility finds a printer under the address
ipp://192.168.178.22:631/printers/HP_LaserJet_5P
and is able to properly set it up.
However, when I enter the address under the Haiku printer settings, it shows the HTTP error HTTP/1.1 400 Bad Request, and when removing the port it cannot connect to the IPP server.
On the server CUPSd listens on ports 631 and 632
Is there a way to set up network printing under Haiku using a CUPS server?
Thanks in advance
What shows the error, Haiku’s own driver?
Sounds like we may, well, be sending bad requests. Likely that needs a bug report.
Seems to be the case, it fails at init_transport
I’ve tried to run wireshark (I don’t really know how to use it properly) but it marked an outgoing packet as malformed, it’s the Get-Printer-Attributes (0x000b) package
haiku uses guetenprint and does have lpp support iirc. works with my brother printers
Yoh could set up your printer’s CUPS server to accept a JetDirect connection on port 9100.
Then in Haiku print prefs: PCL5 ->JetDirect → Printer IP.
