Has anyone had experience with display tablets yet?
I am using Huion KAMVAS GT-191 … it is not even recognized as a secondary monitor, so no signal on it at all
I remember there was a Linux kernel driver written for it 2-3 years ago (called Digimend driver, something like that) … later on it was implemented, so it is automatically recognized upon boot (except callibration, that needs to be done separately).
Good day @urosdjordjic,
No signal because Haiku does not support dual monitors yet. That is what is keeping me from getting a Huion pen display. I use the pen tablet, the Huion W1409 and works fine with Haiku, but it’s not a pen display.
You’ll have to wait until the dual monitor is fully supported. And, you could do a test, which is only plug the Kamvas as a main monitor, and disconnect the other monitor, and test if the pen display behaves properly as a pen display. I mean, you can draw and do stuff. I presume the touch screen would be recognized as an USB device and might behave as mine. Let us know.
Regards,
RR
Forgot one thing:
Turn off the computer. Unplug your display, plug the Kamvas with all the wires, Video and USB. When everything is set, turn on the computer and test the Kamvas.
Beware of the USB cable connected before turning on the computer. I always get KDL crashes if I plug my Huion’s USB cable once Haiku is running (already ticket for this).
Regards,
RR
I have tried that too … Huion is recognized, but only as a screen.
So the pen is not working at all
With that setup again, and even if the pen is not working, launch the terminal and run the command listusb
That command will list all usb devices connected to your PC. As the Kamvas has an USB cable, I understand that the touch/pen input will be managed by USB. In the screenshot I posted, the third line says “Pen Tablet”. That is my Huion W1409. Theoretically, you should see something similar, indicating that your touch/pen screen is there. If it’s not there, then might need to file a ticket.
If it’s there, that’s a first step. I’m presuming your pen does not need charging nor battery, so can be used 24/7 unless mine, as sometimes I forgot the pen’s battery drained out and of course I get no input whatsoever. If the touch/pen is there and not responding to pen movements, then will need to file a ticket.
In my case, I don’t get the click on tracker though I get clicks on Krita and other software.
Let us know how this is going.
Regards,
RR
Good day @roiredxsoto,
It has listed the tablet itself, but pen is not recognised .
Yes, you’re correct, it doesn’t need charging or battery.
I remember that upon running the equivalent usb listing command on Linux, it shown them separately ( something like Tablet Monitor and Pen Pen )
Not related to this, but kudos to Haiku, it registered Apple’s Magic mouse and keyboard
Good day, @urosdjordjic,
That’s “normal?”, there is no “pen pen” on Haiku. At least with my Huion there is none either and I can use the pen. The tablet also should appear inside the Input preferences, though not identified as tablet. Good thing the identifier is the same, I presume.
Therefore, I asume you should file a ticket, but before, check out these two:
https://dev.haiku-os.org/ticket/14592
https://dev.haiku-os.org/ticket/16878
Those are the ones I filed regarding mine. Check them out, mainly the first one, as in that one there is a procedure you can follow in order to get more info to add to the ticket.
Regards,
RR
Good day, @roiredxsoto,
Yep, tablet appears in the input preferences as well. I guess that’s normal that it doesn’t show a pen separately.
I have filed a ticket too:
https://dev.haiku-os.org/ticket/16895
Btw, how can I ‘‘install/implement’’ your patches? Maybe they would work for my device too
Regards,
Uros
Thanks, but I’m not the dev, I’m just a regular user, so I haven’t developed any patches
. Those patches referred to in the ticket might be already included in latest Haiku nightlies, and might be because of that that I can use the Huion to “paint” right now. Also, USB XHCI is getting better too, so hopefully
soon you will be able to use the GT to paint.
Patience
Regards,
RR
So are you suggesting upgrading to nightly? I am currently on the Beta 2 (btw, I had a first crash yesterday lol … I was watching youtube in Webpositive + Haiku community opened only )
Regards,
Uros
Maybe not move to nightly, but test with nightly and see if with the nightly it works. I’m on nightly everywhere… Maybe I should move to beta?
… naaaah, who said fear
Just need to install nightly onto an usb pendrive and test it out.
Crashes happen sometimes, even on other oses too
Just remember what the “smart one” said: Be watel my fliend
Regards,
RR
Good day @roiredxsoto ,
Stupid question, but how do I actually get nightly images?
What I could find searching in the browser seems very confusing
Blockquote Crashes happen sometimes, even on other oses too
True lol
Regards,
Uros
@roiredxsoto
Got it after all … I will give it a go. Maybe it supports GT already somehow.
I have booted into latest nightly live.
Pen still doesn’t work … I have even tried my Wacom Intuos Draw, that doesn’t work either
Both devices are still listed though, but no idea why Wacom is not functioning.
Regards,
Uros
Looks like my old Wacom does work, and does not report the pen either:
~> listusb
1ea7:0907 /dev/bus/usb/0/10/2 "SHARKOON Technologies GmbH" "USB-HID Gaming Keyboard" ver. 0300
045e:0773 /dev/bus/usb/0/10/3 "Microsoft Corp." "Microsoft Nano Transceiver v1.0" ver. 0674
05e3:0610 /dev/bus/usb/0/10/hub "Genesys Logic, Inc." "4-port hub" ver. 9226
056a:0015 /dev/bus/usb/0/12 "Wacom Co., Ltd" "CTE-440 [Graphire4 (4x5)]" ver. 0403
0000:0000 /dev/bus/usb/0/hub "HAIKU Inc." "XHCI RootHub" ver. 0300
0000:0000 /dev/bus/usb/1/hub "HAIKU Inc." "XHCI RootHub" ver. 0300
0000:0000 /dev/bus/usb/2/hub "HAIKU Inc." "XHCI RootHub" ver. 0300
And opposite to the Huion, with the Wacom I can do a Click with the pen, and can plug/unplug with Haiku running without KDLs. This with the latest nightly up to date:
Haiku hawku 1 hrev55026 Apr 5 2021 07:18:13 x86_64 x86_64 Haiku
Check it out and see if now it works for you.
Regards,
RR
Hello,
this is to let you know drawing with Huion Kamvas Pro 20 2019 (GT-1901) works fine on nightly build Haiku shredder 1 hrev55758.
I have not yet managed to make use of the internal tablet buttons, but prefer keyboard strokes anyway.
The pen display mirrors the contents of the 1st monitor.
Kind regards,
Wolfgang
Hello,
That’s great news! Thanks for letting me know
Good day @wolfsch ,
That is good news indeed. Question arises regarding your GPU, as in my case, with a Radeon iGPU have no dual monitor support.
Regarding the buttons, when I use the digitizer on Linux, the buttons are set on a per software basis, the specific software allows to assign functions to the buttons. I did it with Inkscape and MyPaint iirc. Check with the software you use.
Nonetheless, is still good news for us Haiku users.
Regards,
RR
Hello @roiredxsoto,
the GPU is an Intel UHD Graphics 620 as in my ZOTAC ZBOX CI662.
I work with Krita, but did not find any options in the tablet section of the preferences.
On my Manjaro KDE box there is a KDE settings dialogue for the tablet. I was unable to find any tablet setting in MyPaint by the way.
Interestingly enough, while now switching between Manjaro and Haiku I had to realize Haiku hangs at startup when the Kamvas is switched on, just showing the row of startup icons with the rocket symbol on the right. With Kamvas off at startup everything fine again.
Best regards,
Wolfgang
Do you work professionaly with Krita?
