Hello, how can i add a network drive.
The drive is available on IP 111.222.333.444:5000 and have a public Folder pictures.
Regards lorglas
Regards lorglas
If you NAS or whatever serves using nfs, you should be able to mount with:
mkdir -p /MyNAS
mount -t nfs4 -p "111.222.333.444:diskname" /MyNAS
That’s at least how I mount my Synology DiskStation. The “diskname” is, I think, the name of the disk or it’s mountpoint on the NAS. Not terribly sure…
I suppose using “diskname/YourPublicPictureFolder” should mount that specific folder.
Humdinger’s method doesn’t work for me. If it doesn’t work for you, try:
mount_nfs 111.222.333.444:sharename /mountpoint 1000 100
If you’re trying to mount using SMB/Samba/CIFS then it’s a whole other kettle of fish.
Note that mount_nfs is for nfs2.
