How can I contribute to Haiku?
debug report:
Debug information for team /boot/system/bin/python3.9 (1221):
CPU(s): 1x AMD QEMU Virtual CPU version 2.5+
Memory: 3.00 GiB total, 588.41 MiB used
Haiku revision: hrev56578+87 Jul 30 2023 06:34: (x86_64)
Active Threads:
	thread 1227: team 1221 debug task
	thread 1221: python3 (main)
		state: Exception (General protection fault)
		Frame		IP			Function Name
		00000000	0xdeadbeefdeadbeef	?
			Unable to retrieve disassembly for IP 0xdeadbeefdeadbeef: address not contained in any valid image.
		0x7f98aaf907c0	0xaa478ed534	std::default_delete<BView>::operator()(BView*) const + 0x26
		0x7f98aaf90800	0xaa478dacb9	std::unique_ptr<BView, std::default_delete<BView> >::~unique_ptr() + 0x4d
		0x7f98aaf90850	0xaa478d1819	_ZN8pybind116class_I5BViewJEE7deallocERNS_6detail16value_and_holderE + 0x3a
		0x7f98aaf90920	0x26f7443cffc	pybind11::detail::clear_instance(_object*) + 0x12f
		0x7f98aaf90950	0x26f7443d0d1	pybind11_object_dealloc + 0x13
		0x7f98aaf909a0	0x11065cea808	dict_dealloc + 0x328
		0x7f98aaf90a00	0x11065cff8c2	subtype_dealloc + 0x1c2
		0x7f98aaf90a50	0x11065cea7f8	dict_dealloc + 0x318
		0x7f98aaf90ab0	0x11065cff8c2	subtype_dealloc + 0x1c2
		0x7f98aaf90ae0	0x11065cea8af	free_keys_object + 0x5f
		0x7f98aaf90af0	0x11065d6f7e4	dict_tp_clear + 0x4
		0x7f98aaf90c70	0x11065db2f12	collect + 0x732
		0x7f98aaf90c90	0x11065db362e	_PyGC_CollectNoFail + 0x3e
		0x7f98aaf90d20	0x11065da1186	_PyImport_Cleanup + 0x296
		0x7f98aaf90d50	0x11065da8bb8	Py_FinalizeEx + 0x78
		0x7f98aaf90e20	0x11065db2013	Py_RunMain + 0x163
		0x7f98aaf90e50	0x11065db1d76	Py_BytesMain + 0x26
		0x7f98aaf90e80	0x10316da365a	_start + 0x3a
		0x7f98aaf90eb0	0x1199d2dcae3	runtime_loader + 0x103
		00000000	0x7ffffddd0258	commpage_thread_exit + 0
		Registers:
			  rip:	0xdeadbeefdeadbeef
			  rsp:	0x00007f98aaf90798
			  rbp:	0x00007f98aaf907b0
			  rax:	0x000000e7de4f0600
			  rbx:	0x000000e7dd363c88
			  rcx:	0x00007f98aaf90820
			  rdx:	0xdeadbeefdeadbeef
			  rsi:	0x000000e7de4f0600
			  rdi:	0x000000e7de4f0600
			   r8:	0x00007f98aaf90810
			   r9:	0x000000e7de409000
			  r10:	0x000000e7de3f1000
			  r11:	0x00000000000185f0
			  r12:	0x000000e7cd6bbfc0
			  r13:	0x000000e7dd356f60
			  r14:	0x000000e7daa93920
			  r15:	0x0000000018007800
			   cs:	0x002b
			   ds:	0x0000
			   es:	0x0000
			   fs:	0x0000
			   gs:	0x0000
			   ss:	0x0023
			  st0:	0
			  st1:	0
			  st2:	0
			  st3:	0
			  st4:	0
			  st5:	0.99
			  st6:	9.83e+04
			  st7:	nan
			  mm0:	{0x3c, 0, 0, 0}
			  mm1:	{0x4, 0, 0, 0}
			  mm2:	{0, 0, 0, 0}
			  mm3:	{0, 0, 0, 0xc000}
			  mm4:	{0, 0, 0, 0}
			  mm5:	{0x7000, 0xa3d, 0xa3d7, 0xfd70}
			  mm6:	{0, 0, 0, 0xc000}
			  mm7:	{0, 0, 0, 0}
			 xmm0:	{0, 0, 0, 0, 0, 0, 0, 0}
			 xmm1:	{0xcccc, 0xcccc, 0xcccc, 0xcccc, 0xcccc, 0xcccc, 0xcccc, 0xcccc}
			 xmm2:	{0xbc1, 0xaaf9, 0x7f98, 0, 0xffb2, 0xdd34, 0xe7, 0}
			 xmm3:	{0xb000, 0xcd6b, 0xe7, 0, 0x14c0, 0x660d, 0x110, 0}
			 xmm4:	{0x2031, 0x3032, 0x3332, 0x202c, 0x3231, 0x333a, 0x3a39, 0x3731}
			 xmm5:	{0xb90, 0xaaf9, 0x7f98, 0, 0xb90, 0xaaf9, 0x7f98, 0}
			 xmm6:	{0xb90, 0xaaf9, 0x7f98, 0, 0xb90, 0xaaf9, 0x7f98, 0}
			 xmm7:	{0x1, 0, 0, 0, 0x3f9, 0, 0, 0}
			 xmm8:	{0xaa, 0, 0, 0, 0, 0, 0, 0}
			 xmm9:	{0x1, 0, 0, 0, 0, 0, 0, 0}
			xmm10:	{0x5298, 0x1809, 0, 0, 0x5298, 0x1809, 0, 0}
			xmm11:	{0, 0, 0, 0, 0, 0, 0, 0}
			xmm12:	{0, 0, 0, 0, 0, 0, 0, 0}
			xmm13:	{0, 0, 0, 0, 0, 0, 0, 0}
			xmm14:	{0, 0, 0, 0, 0, 0, 0, 0}
			xmm15:	{0, 0, 0, 0, 0, 0, 0, 0}
Loaded Images:
	ID		Text Base	Text End	Data Base	Data End	Type	Name
	10926	0x8c4843000	0x8c4a17000	0x8c4c17000	0x8c4c2d000	lib    	/boot/system/lib/libicuuc.so.66.1
	10922	0x28d505f000	0x28d5071000	0x28d5271000	0x28d5272000	lib    	/boot/system/lib/libroot-addon-icu.so
	10916	0x2ec9990000	0x2ec9aa4000	0x2ec9ca4000	0x2ec9cf6000	lib    	/boot/system/lib/libroot_debug.so
	10931	0x3c6fae3000	0x3c6faf1000	0x3c6fcf1000	0x3c6fcf2000	lib    	/boot/system/lib/python3.9/lib-dynload/math.cpython-39.so
	10925	0x4cc5b93000	0x4cc5b9f000	0x4cc5d9e000	0x4cc5da0000	lib    	/boot/system/lib/libicuio.so.66.1
	10921	0x4e762ea000	0x4e764ca000	0x4e766ca000	0x4e766e0000	lib    	/boot/system/lib/libstdc++.so.6.0.29
	10924	0x6126aee000	0x6126de5000	0x6126fe4000	0x6126ffd000	lib    	/boot/system/lib/libicui18n.so.66.1
	10920	0x6157d95000	0x6157dab000	0x6157fab000	0x6157fac000	lib    	/boot/system/lib/libgcc_s.so.1
	10956	0x7b6335e000	0x7b63369000	0x7b63568000	0x7b6356a000	lib    	/boot/system/lib/python3.9/lib-dynload/_struct.cpython-39.so
	10930	0x7e37c4c000	0x7e37c50000	0x7e37e50000	0x7e37e51000	lib    	/boot/system/lib/python3.9/lib-dynload/select.cpython-39.so
	10958	0xa21aad7000	0xa21ae06000	0xa21b005000	0xa21b033000	lib    	/boot/system/lib/libbe.so
	10963	0xaa477d1000	0xaa479e7000	0xaa47be7000	0xaa47bf0000	lib    	/BeRepos/Haiku-PyAPI/bin/interface/InterfaceKit.so
	10918	0xe7de654000	0xe7de695000	0xe7de894000	0xe7de89d000	lib    	/boot/system/lib/libnetwork.so
	10928	0x102e5cc0000	0x102e5cc3000	0x102e5ec2000	0x102e5ec3000	lib    	/boot/system/lib/python3.9/lib-dynload/grp.cpython-39.so
	10915	0x10316da3000	0x10316da4000	0x10316fa3000	0x10316fa4000	app    	/boot/system/bin/python3.9
	10917	0x11065b93000	0x11065eb5000	0x110660b5000	0x11066115000	lib    	/boot/system/lib/libpython3.9.so.1.0
	10914	0x1199d2cd000	0x1199d2ea000	0x1199d4ea000	0x1199d4eb000	lib    	/boot/system/runtime_loader
	10962	0x149c71f1000	0x149c71f9000	0x149c73f8000	0x149c73f9000	add-on 	/boot/system/add-ons/locale/catalogs/plaintext
	10929	0x18f9c190000	0x18f9c194000	0x18f9c393000	0x18f9c394000	lib    	/boot/system/lib/python3.9/lib-dynload/_posixsubprocess.cpython-39.so
	10960	0x1aec0eaa000	0x1aec0f68000	0x1aec1168000	0x1aec1169000	lib    	/boot/system/lib/libzstd.so.1.5.2
	10927	0x1bfc3690000	0x1bfc3694000	0x1bfc3893000	0x1bfc3894000	lib    	/boot/system/lib/python3.9/lib-dynload/_heapq.cpython-39.so
	10959	0x1e781d2c000	0x1e781d42000	0x1e781f41000	0x1e781f42000	lib    	/boot/system/lib/libz.so.1.2.13
	10923	0x1f03f6e9000	0x1f03f6ea000	0x1f03f8e9000	0x1f03f8ea000	lib    	/boot/system/lib/libicudata.so.66.1
	10919	0x1f975adb000	0x1f975ae4000	0x1f975ce4000	0x1f975ce5000	lib    	/boot/system/lib/libbsd.so
	10957	0x26f743a4000	0x26f746ae000	0x26f748ad000	0x26f748b9000	lib    	/BeRepos/Haiku-PyAPI/bin/app/AppKit.so
	10913	0x7ffffddd0000	0x7ffffddd8000	0x00000000	0x00000000	system 	commpage
Areas:
	ID		Base		End			Size (KiB)	Protection	Locking			Name
	38732	0x18000000	0x18100000	      1024	rw-        	none          	heap
	38873	0x60000000	0x60001000	         4	rw-cS      	none          	server_memory
	38875	0x68000000	0x68020000	       128	rw-cS      	none          	server_memory
	38743	0x8c4843000	0x8c4a17000	      1872	r-x        	none          	libicuuc.so.66.1_seg0ro
	38744	0x8c4c17000	0x8c4c2c000	        84	rw-        	none          	libicuuc.so.66.1_seg1rw
	38745	0x8c4c2c000	0x8c4c2d000	         4	rw-        	none          	libicuuc.so.66.1_seg2rw
	38711	0x98b469000	0x98b479000	        64	rw-        	none          	rld heap
	38734	0x28d505f000	0x28d5071000	        72	r-x        	none          	libroot-addon-icu.so_seg0ro
	38735	0x28d5271000	0x28d5272000	         4	rw-        	none          	libroot-addon-icu.so_seg1rw
	38715	0x2ec9990000	0x2ec9aa4000	      1104	r-x        	none          	libroot_debug.so_seg0ro
	38716	0x2ec9ca4000	0x2ec9cb2000	        56	rw-        	none          	libroot_debug.so_seg1rw
	38717	0x2ec9cb2000	0x2ec9cf6000	       272	rw-        	none          	libroot_debug.so_seg2rw
	38767	0x3c6fae3000	0x3c6faf1000	        56	r-x        	none          	math.cpython-39.so_seg0ro
	38768	0x3c6fcf1000	0x3c6fcf2000	         4	rw-        	none          	math.cpython-39.so_seg1rw
	38741	0x4cc5b93000	0x4cc5b9f000	        48	r-x        	none          	libicuio.so.66.1_seg0ro
	38742	0x4cc5d9e000	0x4cc5da0000	         8	rw-        	none          	libicuio.so.66.1_seg1rw
	38728	0x4e762ea000	0x4e764ca000	      1920	r-x        	none          	libstdc++.so.6.0.29_seg0ro
	38729	0x4e766ca000	0x4e766d8000	        56	rw-        	none          	libstdc++.so.6.0.29_seg1rw
	38730	0x4e766d8000	0x4e766e0000	        32	rw-        	none          	libstdc++.so.6.0.29_seg2rw
	38738	0x6126aee000	0x6126de5000	      3036	r-x        	none          	libicui18n.so.66.1_seg0ro
	38739	0x6126fe4000	0x6126ffc000	        96	rw-        	none          	libicui18n.so.66.1_seg1rw
	38740	0x6126ffc000	0x6126ffd000	         4	rw-        	none          	libicui18n.so.66.1_seg2rw
	38726	0x6157d95000	0x6157dab000	        88	r-x        	none          	libgcc_s.so.1_seg0ro
	38727	0x6157fab000	0x6157fac000	         4	rw-        	none          	libgcc_s.so.1_seg1rw
	38712	0x61d1e34000	0x61d1e35000	         4	rw-cS      	none          	_rld_debug_
	38848	0x7b6335e000	0x7b63369000	        44	r-x        	none          	_struct.cpython-39.so_seg0ro
	38849	0x7b63568000	0x7b6356a000	         8	rw-        	none          	_struct.cpython-39.so_seg1rw
	38765	0x7e37c4c000	0x7e37c50000	        16	r-x        	none          	select.cpython-39.so_seg0ro
	38766	0x7e37e50000	0x7e37e51000	         4	rw-        	none          	select.cpython-39.so_seg1rw
	38853	0xa21aad7000	0xa21ae06000	      3260	r-x        	none          	libbe.so_seg0ro
	38854	0xa21b005000	0xa21b033000	       184	rw-        	none          	libbe.so_seg1rw
	38731	0xa332855000	0xa332865000	        64	rw-        	none          	rld heap
	38865	0xaa477d1000	0xaa479e7000	      2136	r-x        	none          	InterfaceKit.so_seg0ro
	38866	0xaa47be7000	0xaa47bef000	        32	rw-        	none          	InterfaceKit.so_seg1rw
	38867	0xaa47bef000	0xaa47bf0000	         4	rw-        	none          	InterfaceKit.so_seg2rw
	38733	0xaa975e9000	0xaa977e9000	      2048	rw-        	none          	additional heap area
	38746	0xc2df905000	0xc2df91d000	        96	rw-        	none          	rld heap
	38747	0xe0d0559000	0xe0d0571000	        96	rw-        	none          	rld heap
	38748	0xe317f71000	0xe319a2c000	     27372	r--S       	none          	libicuuc.so.66 mmap area
	38749	0xe73eeee000	0xe73ef2e000	       256	rw-        	none          	libpython3.9.so.1.0 mmap area
	38750	0xe76c5f5000	0xe76c635000	       256	rw-        	none          	libpython3.9.so.1.0 mmap area
	38751	0xe779d00000	0xe779f00000	      2048	rw-        	none          	additional heap area
	38752	0xe7c811b000	0xe7c815b000	       256	rw-        	none          	libpython3.9.so.1.0 mmap area
	38753	0xe7cd691000	0xe7cd6d1000	       256	rw-        	none          	libpython3.9.so.1.0 mmap area
	38754	0xe7d62a3000	0xe7d62e3000	       256	rw-        	none          	libpython3.9.so.1.0 mmap area
	38755	0xe7daa90000	0xe7daad0000	       256	rw-        	none          	libpython3.9.so.1.0 mmap area
	38756	0xe7dbb25000	0xe7dbb65000	       256	rw-        	none          	libpython3.9.so.1.0 mmap area
	38757	0xe7dc371000	0xe7dc3b1000	       256	rw-        	none          	libpython3.9.so.1.0 mmap area
	38760	0xe7dd32e000	0xe7dd36e000	       256	rw-        	none          	libpython3.9.so.1.0 mmap area
	38863	0xe7de3f1000	0xe7de431000	       256	rw-        	none          	libpython3.9.so.1.0 mmap area
	38864	0xe7de445000	0xe7de645000	      2048	rw-        	none          	additional heap area
	38721	0xe7de654000	0xe7de695000	       260	r-x        	none          	libnetwork.so_seg0ro
	38722	0xe7de894000	0xe7de898000	        16	rw-        	none          	libnetwork.so_seg1rw
	38723	0xe7de898000	0xe7de89d000	        20	rw-        	none          	libnetwork.so_seg2rw
	38868	0xf16c5be000	0xf16c5fe000	       256	rw-        	none          	libpython3.9.so.1.0 mmap area
	38761	0x102e5cc0000	0x102e5cc3000	        12	r-x        	none          	grp.cpython-39.so_seg0ro
	38762	0x102e5ec2000	0x102e5ec3000	         4	rw-        	none          	grp.cpython-39.so_seg1rw
	38713	0x10316da3000	0x10316da4000	         4	r-x        	none          	python3.9_seg0ro
	38714	0x10316fa3000	0x10316fa4000	         4	rw-        	none          	python3.9_seg1rw
	38718	0x11065b93000	0x11065eb5000	      3208	r-x        	none          	libpython3.9.so.1.0_seg0ro
	38719	0x110660b5000	0x110660f3000	       248	rw-        	none          	libpython3.9.so.1.0_seg1rw
	38720	0x110660f3000	0x11066115000	       136	rw-        	none          	libpython3.9.so.1.0_seg2rw
	38709	0x1199d2cd000	0x1199d2ea000	       116	r-x        	none          	runtime_loader_seg0ro
	38710	0x1199d4ea000	0x1199d4eb000	         4	rw-        	none          	runtime_loader_seg1rw
	38861	0x149c71f1000	0x149c71f9000	        32	r-x        	none          	plaintext_seg0ro
	38862	0x149c73f8000	0x149c73f9000	         4	rw-        	none          	plaintext_seg1rw
	38763	0x18f9c190000	0x18f9c194000	        16	r-x        	none          	_posixsubprocess.cpython-39.so_
	38764	0x18f9c393000	0x18f9c394000	         4	rw-        	none          	_posixsubprocess.cpython-39.so_
	38857	0x1aec0eaa000	0x1aec0f68000	       760	r-x        	none          	libzstd.so.1.5.2_seg0ro
	38858	0x1aec1168000	0x1aec1169000	         4	rw-        	none          	libzstd.so.1.5.2_seg1rw
	38758	0x1bfc3690000	0x1bfc3694000	        16	r-x        	none          	_heapq.cpython-39.so_seg0ro
	38759	0x1bfc3893000	0x1bfc3894000	         4	rw-        	none          	_heapq.cpython-39.so_seg1rw
	38855	0x1e781d2c000	0x1e781d42000	        88	r-x        	none          	libz.so.1.2.13_seg0ro
	38856	0x1e781f41000	0x1e781f42000	         4	rw-        	none          	libz.so.1.2.13_seg1rw
	38736	0x1f03f6e9000	0x1f03f6ea000	         4	r-x        	none          	libicudata.so.66.1_seg0ro
	38737	0x1f03f8e9000	0x1f03f8ea000	         4	rw-        	none          	libicudata.so.66.1_seg1rw
	38724	0x1f975adb000	0x1f975ae4000	        36	r-x        	none          	libbsd.so_seg0ro
	38725	0x1f975ce4000	0x1f975ce5000	         4	rw-        	none          	libbsd.so_seg1rw
	38850	0x26f743a4000	0x26f746ae000	      3112	r-x        	none          	AppKit.so_seg0ro
	38851	0x26f748ad000	0x26f748b8000	        44	rw-        	none          	AppKit.so_seg1rw
	38852	0x26f748b8000	0x26f748b9000	         4	rw-        	none          	AppKit.so_seg2rw
	38707	0x7f98a9f8d000	0x7f98aaf93000	     16408	rw-s       	none          	python3_1221_stack
	38706	0x7fe8795d0000	0x7fe8795d4000	        16	rw-k       	full          	user area
	38708	0x7ffffddd0000	0x7ffffddd8000	        32	r-xSk      	full          	commpage
Protection Flags: r - read, w - write, x - execute, s - stack, o - overcommit, c - cloneable, S - shared, k - kernel
Semaphores:
	ID		Count	Last Holder	Name
	443727	    0	        750	some BLocker
	443735	    0	        750	some BBlockCache lock
	443742	    0	        750	AppServerLink_sLock
	443751	    0	        752	Catalog
	443762	    0	        752	token space
	443763	    0	        752	BMessageQueue Lock
	443764	    0	        752	LocaleRosterData
	443765	    0	        750	BLooperList lock
	443767	    0	        750	some BLocker
	443769	    0	        750	some BLocker
	443773	    0	        750	clipboard
	443781	    0	        752	AppLooperPort
	443782	    0	        750	width buffer
	443787	    0	        750	screen list
	443899	    0	        750	tool tip manager
This indicates a use-after-free.
