I think Python bindings for the Haiku API would be great. The hard (and fun) part of the bindings is usually converting between the native language types and Python - I used Pyrex back in the day to create Python bindings for PortAudio, and I used PerlXS to wrap some Objective-C MacOS functions in Perl. Itâs always rewarding when you get it to work! If I had free time I might be interested in working on this, but right now I really donât have much.
pybind11 will convert between cpp and python types
The problem is that I do not have any experience in C++ or the Haiku API
current progress:
So far have made bindings for:
AppDefs.h, Application.h, Clipboard.h, Cursor.h, Handler.h, Invoker.h, Key.h, KeyStore.h, Looper.h, Message.h, MessageFilter.h, MessageQueue.h
I have done âcompleteâ bindings for AppKit, and InterfaceKit.h, Window.h, Rect.h, View.h, StringView.h, Button.h, Control.h and TextControl.h in the InterfaceKit.
I compile all the cpp files in each kit together into one .so and symlink it to Window.so, View.so, etc.
My problem is, when i run this test program,
from bin import BApplication, BWindow, BRect, BMessage, BView, BButton, window_type, B_NOT_RESIZABLE
class Window(BWindow):
def __init__(self):
BWindow.__init__(self, BRect(100,100,200,150), "Hello Haiku!", window_type.B_TITLED_WINDOW, B_NOT_RESIZABLE)
self.say_hi = BMessage(1)
self.panel = BView(self.Bounds(), "panel", 8, 20000000)
self.button = BButton(self.panel.Bounds(), "hi", "Say Hello!", self.say_hi) #BRect(10,10,100,50)
self.panel.AddChild(self.button, None)
self.AddChild(self.panel, None)
def MessageReceived(self, msg):
if msg.what == self.say_hi.what:
print("Hello World!")
else:
BWindow.MessageReceived(self, msg)
def QuitRequested(self):
print("PyQUIT")
return True
class App(BApplication):
def __init__(self):
BApplication.__init__(self, "application/x-python")
def ReadyToRun(self):
self.window = Window()
self.window.Show()
def main():
global be_app
be_app = App()
be_app.Run()
print('Ran')
if __name__ == "__main__":
main()
it runs, but when i close it, it stays in the deskbar, and it does not quit in the terminal.
I have to use the vulcan death grip or ^Z on it.
Do you know why?
EDIT:
^Z quits in terminal, but it stays on Deskbar.
Why do you create the be_app as global?
I was calling be_app.Lock() and be_app.Quit() in QuitRequested. It didnât help.
You probably need B_QUIT_ON_WINDOW_CLOSE in your window flags if youâre trying to quit the entire app by closing the window.
I tried that, it âworksâ, but pops up an error dialog.
Well, I canât help if you donât say what the error message is. This is how itâs normally done for simple apps.
It just says something like, this application has ran into an error which prevents it from continuing etc
output is:
panel BView::_InitData(): resizing mode or flags swapped
PyQUIT
Ran
Kill Thread
This dialog has an option to save a debug report, which will have more information.
Debug information for team /boot/system/bin/python3.9 (2232):
CPU(s): 1x AMD QEMU Virtual CPU version 2.5+
Memory: 3.00 GiB total, 767.11 MiB used
Haiku revision: hrev56578+87 Jul 30 2023 06:34: (x86_64)
Active Threads:
thread 2238: team 2232 debug task
thread 2232: python3 (main)
state: Debugged
Frame IP Function Name
00000000 0x5f414354 ?
Unable to retrieve disassembly for IP 0x5f414354: address not contained in any valid image.
0x7f5b40ed5ce0 0x18574d99a76 std::default_delete<BMessage>::operator()(BMessage*) const + 0x26
0x7f5b40ed5d20 0x18574d79f1f std::unique_ptr<BMessage, std::default_delete<BMessage> >::~unique_ptr() + 0x4d
0x7f5b40ed5d70 0x18574d6b489 _ZN8pybind116class_I8BMessageJEE7deallocERNS_6detail16value_and_holderE + 0x3a
0x7f5b40ed5e40 0x18574ca080c pybind11::detail::clear_instance(_object*) + 0x12f
0x7f5b40ed5e70 0x18574ca08e1 pybind11_object_dealloc + 0x13
0x7f5b40ed5ec0 0x220ee5637f8 dict_dealloc + 0x318
0x7f5b40ed5f20 0x220ee5788c2 subtype_dealloc + 0x1c2
0x7f5b40ed5f70 0x220ee5637f8 dict_dealloc + 0x318
0x7f5b40ed5fd0 0x220ee5788c2 subtype_dealloc + 0x1c2
0x7f5b40ed6000 0x220ee5638af free_keys_object + 0x5f
0x7f5b40ed6010 0x220ee5e87e4 dict_tp_clear + 0x4
0x7f5b40ed6190 0x220ee62bf12 collect + 0x732
0x7f5b40ed61b0 0x220ee62c62e _PyGC_CollectNoFail + 0x3e
0x7f5b40ed6240 0x220ee61a186 _PyImport_Cleanup + 0x296
0x7f5b40ed6270 0x220ee621bb8 Py_FinalizeEx + 0x78
0x7f5b40ed6340 0x220ee62b013 Py_RunMain + 0x163
0x7f5b40ed6370 0x220ee62ad76 Py_BytesMain + 0x26
0x7f5b40ed63a0 0x11c89c0465a _start + 0x3a
0x7f5b40ed63d0 0x1c55eb43ae3 runtime_loader + 0x103
00000000 0x7ffffdab2258 commpage_thread_exit + 0
Registers:
rip: 0x000000005f414354
rsp: 0x00007f5b40ed5cb8
rbp: 0x00007f5b40ed5cd0
rax: 0x0000124a3081c950
rbx: 0x00000119330af7c8
rcx: 0x00007f5b40ed5d40
rdx: 0x000000005f414354
rsi: 0x0000124a3081c950
rdi: 0x0000124a3081c950
r8: 0x00007f5b40ed5d30
r9: 0x0000000000000002
r10: 0x0000000000000002
r11: 0x0000000000000002
r12: 0x0000011582b0ef80
r13: 0x000001193309ef60
r14: 0x000001190cb7f920
r15: 0x0000124a307dd3a0
cs: 0x002b
ds: 0x0000
es: 0x0000
fs: 0x0000
gs: 0x0000
ss: 0x0023
st0: 0
st1: 0
st2: 0
st3: 0
st4: 0
st5: 0.99
st6: 9.83e+04
st7: nan
mm0: {0x3c, 0, 0, 0}
mm1: {0x4, 0, 0, 0}
mm2: {0, 0, 0, 0}
mm3: {0, 0, 0, 0xc000}
mm4: {0, 0, 0, 0}
mm5: {0x7000, 0xa3d, 0xa3d7, 0xfd70}
mm6: {0, 0, 0, 0xc000}
mm7: {0, 0, 0, 0}
xmm0: {0, 0, 0, 0, 0, 0, 0, 0}
xmm1: {0xa670, 0xee94, 0x220, 0, 0, 0, 0, 0}
xmm2: {0x60e1, 0x40ed, 0x7f5b, 0, 0x7eb2, 0x3309, 0x119, 0}
xmm3: {0, 0x82b1, 0x115, 0, 0xa670, 0xee94, 0x220, 0}
xmm4: {0x2031, 0x3032, 0x3332, 0x202c, 0x3231, 0x333a, 0x3a39, 0x3731}
xmm5: {0x60b0, 0x40ed, 0x7f5b, 0, 0x60b0, 0x40ed, 0x7f5b, 0}
xmm6: {0x60b0, 0x40ed, 0x7f5b, 0, 0x60b0, 0x40ed, 0x7f5b, 0}
xmm7: {0x1, 0, 0, 0, 0x3f9, 0, 0, 0}
xmm8: {0xaa, 0, 0, 0, 0, 0, 0, 0}
xmm9: {0x1, 0, 0, 0, 0, 0, 0, 0}
xmm10: {0x4648, 0x3081, 0x124a, 0, 0x4648, 0x3081, 0x124a, 0}
xmm11: {0, 0, 0, 0, 0, 0, 0, 0}
xmm12: {0, 0, 0, 0, 0, 0, 0, 0}
xmm13: {0, 0, 0, 0, 0, 0, 0, 0}
xmm14: {0, 0, 0, 0, 0, 0, 0, 0}
xmm15: {0, 0, 0, 0, 0, 0, 0, 0}
Loaded Images:
ID Text Base Text End Data Base Data End Type Name
31028 0x13a0f08000 0x13a0f14000 0x13a1113000 0x13a1115000 lib /boot/system/lib/libicuio.so.66.1
31034 0x14f3b6b000 0x14f3b79000 0x14f3d79000 0x14f3d7a000 lib /boot/system/lib/python3.9/lib-dynload/math.cpython-39.so
31023 0x23c50c5000 0x23c52a5000 0x23c54a5000 0x23c54bb000 lib /boot/system/lib/libstdc++.so.6.0.29
31021 0x2b9aea7000 0x2b9aeb0000 0x2b9b0b0000 0x2b9b0b1000 lib /boot/system/lib/libbsd.so
31059 0x62d2609000 0x62d2614000 0x62d2813000 0x62d2815000 lib /boot/system/lib/python3.9/lib-dynload/_struct.cpython-39.so
31031 0x73edbd9000 0x73edbdc000 0x73edddb000 0x73edddc000 lib /boot/system/lib/python3.9/lib-dynload/grp.cpython-39.so
31066 0x8603a21000 0x8603c37000 0x8603e37000 0x8603e40000 lib /BeRepos/Haiku-PyAPI/bin/interface/InterfaceKit.so
31063 0xdd1b3fe000 0xdd1b4bc000 0xdd1b6bc000 0xdd1b6bd000 lib /boot/system/lib/libzstd.so.1.5.2
31030 0x11449f89000 0x11449f8d000 0x1144a18c000 0x1144a18d000 lib /boot/system/lib/python3.9/lib-dynload/_heapq.cpython-39.so
31029 0x11933abf000 0x11933c93000 0x11933e93000 0x11933ea9000 lib /boot/system/lib/libicuuc.so.66.1
31018 0x11c89c04000 0x11c89c05000 0x11c89e04000 0x11c89e05000 app /boot/system/bin/python3.9
31062 0x180e5c3f000 0x180e5c55000 0x180e5e54000 0x180e5e55000 lib /boot/system/lib/libz.so.1.2.13
31060 0x18574c06000 0x18574f11000 0x18575111000 0x1857511d000 lib /BeRepos/Haiku-PyAPI/bin/app/AppKit.so
31065 0x1aaea122000 0x1aaea12a000 0x1aaea329000 0x1aaea32a000 add-on /boot/system/add-ons/locale/catalogs/plaintext
31033 0x1b6d045c000 0x1b6d0460000 0x1b6d0660000 0x1b6d0661000 lib /boot/system/lib/python3.9/lib-dynload/select.cpython-39.so
31022 0x1b761fee000 0x1b762101000 0x1b762300000 0x1b762353000 lib /boot/system/lib/libroot.so
31061 0x1b8ce1dc000 0x1b8ce50b000 0x1b8ce70a000 0x1b8ce738000 lib /boot/system/lib/libbe.so
31024 0x1c36620b000 0x1c366221000 0x1c366421000 0x1c366422000 lib /boot/system/lib/libgcc_s.so.1
31017 0x1c55eb34000 0x1c55eb51000 0x1c55ed51000 0x1c55ed52000 lib /boot/system/runtime_loader
31032 0x1d3da4f4000 0x1d3da4f8000 0x1d3da6f7000 0x1d3da6f8000 lib /boot/system/lib/python3.9/lib-dynload/_posixsubprocess.cpython-39.so
31027 0x1d7041d0000 0x1d7044c7000 0x1d7046c6000 0x1d7046df000 lib /boot/system/lib/libicui18n.so.66.1
31026 0x1e30369b000 0x1e30369c000 0x1e30389b000 0x1e30389c000 lib /boot/system/lib/libicudata.so.66.1
31025 0x1edef049000 0x1edef05b000 0x1edef25b000 0x1edef25c000 lib /boot/system/lib/libroot-addon-icu.so
31020 0x2063deec000 0x2063df2d000 0x2063e12c000 0x2063e135000 lib /boot/system/lib/libnetwork.so
31019 0x220ee40c000 0x220ee72e000 0x220ee92e000 0x220ee98e000 lib /boot/system/lib/libpython3.9.so.1.0
31016 0x7ffffdab2000 0x7ffffdaba000 0x00000000 0x00000000 system commpage
Areas:
ID Base End Size (KiB) Protection Locking Name
120394 0x60000000 0x60001000 4 rw-cS none server_memory
120396 0x68000000 0x68020000 128 rw-cS none server_memory
120266 0x13a0f08000 0x13a0f14000 48 r-x none libicuio.so.66.1_seg0ro
120267 0x13a1113000 0x13a1115000 8 rw- none libicuio.so.66.1_seg1rw
120291 0x14f3b6b000 0x14f3b79000 56 r-x none math.cpython-39.so_seg0ro
120292 0x14f3d79000 0x14f3d7a000 4 rw- none math.cpython-39.so_seg1rw
120252 0x23c50c5000 0x23c52a5000 1920 r-x none libstdc++.so.6.0.29_seg0ro
120253 0x23c54a5000 0x23c54b3000 56 rw- none libstdc++.so.6.0.29_seg1rw
120254 0x23c54b3000 0x23c54bb000 32 rw- none libstdc++.so.6.0.29_seg2rw
120247 0x2b9aea7000 0x2b9aeb0000 36 r-x none libbsd.so_seg0ro
120248 0x2b9b0b0000 0x2b9b0b1000 4 rw- none libbsd.so_seg1rw
120237 0x3749d67000 0x3749d77000 64 rw- none rld heap
120370 0x62d2609000 0x62d2614000 44 r-x none _struct.cpython-39.so_seg0ro
120371 0x62d2813000 0x62d2815000 8 rw- none _struct.cpython-39.so_seg1rw
120285 0x73edbd9000 0x73edbdc000 12 r-x none grp.cpython-39.so_seg0ro
120286 0x73edddb000 0x73edddc000 4 rw- none grp.cpython-39.so_seg1rw
120238 0x7af74ac000 0x7af74ad000 4 rw-cS none _rld_debug_
120386 0x8603a21000 0x8603c37000 2136 r-x none InterfaceKit.so_seg0ro
120387 0x8603e37000 0x8603e3f000 32 rw- none InterfaceKit.so_seg1rw
120388 0x8603e3f000 0x8603e40000 4 rw- none InterfaceKit.so_seg2rw
120257 0x866fee7000 0x866fef7000 64 rw- none rld heap
120271 0xd1273ee000 0xd127406000 96 rw- none rld heap
120379 0xdd1b3fe000 0xdd1b4bc000 760 r-x none libzstd.so.1.5.2_seg0ro
120380 0xdd1b6bc000 0xdd1b6bd000 4 rw- none libzstd.so.1.5.2_seg1rw
120272 0xecb99bf000 0xecb99d7000 96 rw- none rld heap
120273 0x108d9b48000 0x108db603000 27372 r--S none libicuuc.so.66 mmap area
120274 0x1107d9f3000 0x1107da33000 256 rw- none libpython3.9.so.1.0 mmap area
120275 0x1138018c000 0x113801cc000 256 rw- none libpython3.9.so.1.0 mmap area
120276 0x113ee21c000 0x113ee25c000 256 rw- none libpython3.9.so.1.0 mmap area
120282 0x11449f89000 0x11449f8d000 16 r-x none _heapq.cpython-39.so_seg0ro
120283 0x1144a18c000 0x1144a18d000 4 rw- none _heapq.cpython-39.so_seg1rw
120277 0x11582ae4000 0x11582b24000 256 rw- none libpython3.9.so.1.0 mmap area
120278 0x1184e77d000 0x1184e7bd000 256 rw- none libpython3.9.so.1.0 mmap area
120279 0x1190cb7c000 0x1190cbbc000 256 rw- none libpython3.9.so.1.0 mmap area
120280 0x11919803000 0x11919843000 256 rw- none libpython3.9.so.1.0 mmap area
120281 0x1192ddf4000 0x1192de34000 256 rw- none libpython3.9.so.1.0 mmap area
120284 0x11933076000 0x119330b6000 256 rw- none libpython3.9.so.1.0 mmap area
120385 0x11933a76000 0x11933ab6000 256 rw- none libpython3.9.so.1.0 mmap area
120268 0x11933abf000 0x11933c93000 1872 r-x none libicuuc.so.66.1_seg0ro
120269 0x11933e93000 0x11933ea8000 84 rw- none libicuuc.so.66.1_seg1rw
120270 0x11933ea8000 0x11933ea9000 4 rw- none libicuuc.so.66.1_seg2rw
120389 0x11a53a73000 0x11a53ab3000 256 rw- none libpython3.9.so.1.0 mmap area
120239 0x11c89c04000 0x11c89c05000 4 r-x none python3.9_seg0ro
120240 0x11c89e04000 0x11c89e05000 4 rw- none python3.9_seg1rw
120377 0x180e5c3f000 0x180e5c55000 88 r-x none libz.so.1.2.13_seg0ro
120378 0x180e5e54000 0x180e5e55000 4 rw- none libz.so.1.2.13_seg1rw
120372 0x18574c06000 0x18574f11000 3116 r-x none AppKit.so_seg0ro
120373 0x18575111000 0x1857511c000 44 rw- none AppKit.so_seg1rw
120374 0x1857511c000 0x1857511d000 4 rw- none AppKit.so_seg2rw
120383 0x1aaea122000 0x1aaea12a000 32 r-x none plaintext_seg0ro
120384 0x1aaea329000 0x1aaea32a000 4 rw- none plaintext_seg1rw
120289 0x1b6d045c000 0x1b6d0460000 16 r-x none select.cpython-39.so_seg0ro
120290 0x1b6d0660000 0x1b6d0661000 4 rw- none select.cpython-39.so_seg1rw
120249 0x1b761fee000 0x1b762101000 1100 r-x none libroot.so_seg0ro
120250 0x1b762300000 0x1b76230e000 56 rw- none libroot.so_seg1rw
120251 0x1b76230e000 0x1b762353000 276 rw- none libroot.so_seg2rw
120375 0x1b8ce1dc000 0x1b8ce50b000 3260 r-x none libbe.so_seg0ro
120376 0x1b8ce70a000 0x1b8ce738000 184 rw- none libbe.so_seg1rw
120255 0x1c36620b000 0x1c366221000 88 r-x none libgcc_s.so.1_seg0ro
120256 0x1c366421000 0x1c366422000 4 rw- none libgcc_s.so.1_seg1rw
120235 0x1c55eb34000 0x1c55eb51000 116 r-x none runtime_loader_seg0ro
120236 0x1c55ed51000 0x1c55ed52000 4 rw- none runtime_loader_seg1rw
120287 0x1d3da4f4000 0x1d3da4f8000 16 r-x none _posixsubprocess.cpython-39.so_
120288 0x1d3da6f7000 0x1d3da6f8000 4 rw- none _posixsubprocess.cpython-39.so_
120263 0x1d7041d0000 0x1d7044c7000 3036 r-x none libicui18n.so.66.1_seg0ro
120264 0x1d7046c6000 0x1d7046de000 96 rw- none libicui18n.so.66.1_seg1rw
120265 0x1d7046de000 0x1d7046df000 4 rw- none libicui18n.so.66.1_seg2rw
120261 0x1e30369b000 0x1e30369c000 4 r-x none libicudata.so.66.1_seg0ro
120262 0x1e30389b000 0x1e30389c000 4 rw- none libicudata.so.66.1_seg1rw
120259 0x1edef049000 0x1edef05b000 72 r-x none libroot-addon-icu.so_seg0ro
120260 0x1edef25b000 0x1edef25c000 4 rw- none libroot-addon-icu.so_seg1rw
120244 0x2063deec000 0x2063df2d000 260 r-x none libnetwork.so_seg0ro
120245 0x2063e12c000 0x2063e130000 16 rw- none libnetwork.so_seg1rw
120246 0x2063e130000 0x2063e135000 20 rw- none libnetwork.so_seg2rw
120241 0x220ee40c000 0x220ee72e000 3208 r-x none libpython3.9.so.1.0_seg0ro
120242 0x220ee92e000 0x220ee96c000 248 rw- none libpython3.9.so.1.0_seg1rw
120243 0x220ee96c000 0x220ee98e000 136 rw- none libpython3.9.so.1.0_seg2rw
120258 0x124a307c1000 0x124a30aa1000 2944 rw- none heap
120233 0x7f5b3fed3000 0x7f5b40ed9000 16408 rw-s none python3_2232_stack
120232 0x7fd7b3dcb000 0x7fd7b3dcf000 16 rw-k full user area
120234 0x7ffffdab2000 0x7ffffdaba000 32 r-xSk full commpage
Protection Flags: r - read, w - write, x - execute, s - stack, o - overcommit, c - cloneable, S - shared, k - kernel
Semaphores:
ID Count Last Holder Name
1468341 0 2232 BLooperList lock
1468349 0 1574 Catalog
1468355 0 1574 LocaleRosterData
1468357 0 1572 some BLocker
1468358 0 1574 some BBlockCache lock
1468359 0 1572 some BLocker
1468361 0 1574 BMessageQueue Lock
1468362 0 1572 AppServerLink_sLock
1468364 0 1572 token space
1468366 0 1574 AppLooperPort
1468369 0 1572 width buffer
1468371 0 1572 some BLocker
1468382 0 1572 clipboard
1468389 0 1572 screen list
1468411 0 1572 tool tip manager
It seems your code is holding a BMessage inside an unique_ptr. What was this message used for? Quite often, the messages will be deleted for you, for example:
- Messages received in MessageReceived: the application kit takes care of deleting them
- Messages you add to a BControl or BInvoker: the object takes ownership of the message
So, you may easily end up with a double delete here.
I donât know if pybind allows enough control on allocations to manage this somewhat automatically.
Oh. Ownership mapping is the hardest part of language binding sometime GC helps, sometime not.
Often threre is some type of convention (e.g. child windows automatically freed by parent), but marking large API surface correctly is labor.
I changed it to:
py::class_<BMessage,std::unique_ptr<BMessage, py::nodelete>>(m, "BMessage")
and it has a different error.
Debug information for team /boot/system/bin/python3.9 (1072):
Memory: 3.00 GiB total, 569.41 MiB used
Active Threads:
thread 1079: team 1072 debug task
thread 1072: python3 (main)
state: Call (getNumAvailable() < getNumBlocks())
00000000 0x4a01f8f097 _kern_debugger + 0x7
Disassembly:
_kern_debugger:
0x0000004a01f8f090: 48c7c0e5000000 mov $0xe5, %rax
0x0000004a01f8f097: 0f05 syscall <--
0x7f8434d04a20 0x4a01f974e1 __assert_fail + 0x61
0x7f8434d04a70 0x4a0201953d BPrivate::hoardHeap::freeBlock(BPrivate::block*&, BPrivate::superblock*&, int, BPrivate::processHeap*) + 0x52d
0x7f8434d04ab0 0x4a0201992c BPrivate::processHeap::free(void*) + 0xfc
0x7f8434d04ae0 0x4a0201ab54 free + 0x44
0x7f8434d04b60 0x16d9c30eb0b pybind11::cpp_function::destruct(pybind11::detail::function_record*, bool) + 0x1e8
0x7f8434d04b80 0x16d9c30ce14 _ZZN8pybind1112cpp_function18initialize_genericEOSt10unique_ptrINS_6detail15function_recordENS0_33InitializingFunctionRecordDeleterEEPKcPKPKSt9type_infomENKUlPvE_clESE_ + 0x1c
0x7f8434d04ba0 0x16d9c30ce34 _ZZN8pybind1112cpp_function18initialize_genericEOSt10unique_ptrINS_6detail15function_recordENS0_33InitializingFunctionRecordDeleterEEPKcPKPKSt9type_infomENUlPvE_4_FUNESE_ + 0x18
0x7f8434d04bd0 0x16d9c30809a _ZZN8pybind117capsuleC4EPKvPFvPvEENKUlP7_objectE_clES7_ + 0x40
0x7f8434d04bf0 0x16d9c3080b7 _ZZN8pybind117capsuleC4EPKvPFvPvEENUlP7_objectE_4_FUNES7_ + 0x18
0x7f8434d04c10 0x1b90de68e21 capsule_dealloc.cold + 0xc
0x7f8434d04c30 0x1b90df46c08 meth_dealloc + 0x98
0x7f8434d04c50 0x1b90de69849 instancemethod_dealloc + 0x3d
0x7f8434d04c80 0x1b90df428af free_keys_object + 0x5f
0x7f8434d04ca0 0x1b90df59109 type_clear + 0x39
0x7f8434d04e20 0x1b90e00af12 collect + 0x732
0x7f8434d04e40 0x1b90e00b62e _PyGC_CollectNoFail + 0x3e
0x7f8434d04e70 0x1b90e000bb8 Py_FinalizeEx + 0x78
0x7f8434d04f40 0x1b90e00a013 Py_RunMain + 0x163
0x7f8434d04f70 0x1b90e009d76 Py_BytesMain + 0x26
0x7f8434d04fa0 0xffc004e65a _start + 0x3a
0x7f8434d04fd0 0x24cc50c9ae3 runtime_loader + 0x103
00000000 0x7ffff655a258 commpage_thread_exit + 0
Registers:
rip: 0x0000004a01f8f099
rsp: 0x00007f8434d049d8
rbp: 0x00007f8434d04a10
rax: 0x00000000000000e5
rbx: 0x00007f8434d04a78
rcx: 0x0000004a01f8f099
rdx: 0x00007f8434d044f3
rsi: 0x00007f8434d044f3
rdi: 0x0000004a020461d8
r8: 0x0000000000000430
r9: 0x00007f8434d04440
r10: 0x0000000000000000
r11: 0x0000000000000206
r12: 0x0000004a020461d8
r13: 0x000000000000000f
r14: 0x000010e36f7839a8
r15: 0x000000000000000f
cs: 0x002b
ds: 0x0000
es: 0x0000
fs: 0x0000
gs: 0x0000
ss: 0x0023
st0: 0
st1: 0
st2: 0
st3: 0
st4: 0
st5: 0
st6: 0
st7: 0
mm0: {0, 0, 0, 0}
mm1: {0, 0, 0, 0}
mm2: {0, 0, 0, 0}
mm3: {0, 0, 0, 0}
mm4: {0, 0, 0, 0}
mm5: {0, 0, 0, 0}
mm6: {0, 0, 0, 0}
mm7: {0, 0, 0, 0}
xmm1: {0, 0, 0, 0, 0, 0, 0, 0}
xmm2: {0, 0, 0, 0, 0, 0, 0, 0}
xmm3: {0, 0, 0, 0, 0, 0, 0, 0}
xmm4: {0, 0, 0, 0, 0, 0, 0, 0}
xmm5: {0, 0, 0, 0, 0, 0, 0, 0}
xmm6: {0, 0, 0, 0, 0, 0, 0, 0}
xmm7: {0, 0, 0, 0, 0, 0, 0, 0}
xmm8: {0, 0, 0, 0, 0, 0, 0, 0}
xmm9: {0, 0, 0, 0, 0, 0, 0, 0}
xmm10: {0, 0, 0, 0, 0, 0, 0, 0}
Loaded Images:
8735 0x45c3552000 0x45c3568000 0x45c3768000 0x45c3769000 lib /boot/system/lib/libgcc_s.so.1
8742 0x470f4b7000 0x470f4ba000 0x470f6b9000 0x470f6ba000 lib /boot/system/lib/python3.9/lib-dynload/grp.cpython-39.so
8733 0x4a01f4f000 0x4a02062000 0x4a02261000 0x4a022b4000 lib /boot/system/lib/libroot.so
8773 0x5ed218e000 0x5ed21a4000 0x5ed23a3000 0x5ed23a4000 lib /boot/system/lib/libz.so.1.2.13
8740 0x6040c66000 0x6040e3a000 0x604103a000 0x6041050000 lib /boot/system/lib/libicuuc.so.66.1
8736 0x641bfd3000 0x641bfe5000 0x641c1e5000 0x641c1e6000 lib /boot/system/lib/libroot-addon-icu.so
8745 0x69f1013000 0x69f1021000 0x69f1221000 0x69f1222000 lib /boot/system/lib/python3.9/lib-dynload/math.cpython-39.so
8739 0x6b0c7c2000 0x6b0c7ce000 0x6b0c9cd000 0x6b0c9cf000 lib /boot/system/lib/libicuio.so.66.1
8744 0x7890722000 0x7890726000 0x7890926000 0x7890927000 lib /boot/system/lib/python3.9/lib-dynload/select.cpython-39.so
8776 0x84483fa000 0x8448402000 0x8448601000 0x8448602000 add-on /boot/system/add-ons/locale/catalogs/plaintext
8731 0x85eb8ef000 0x85eb930000 0x85ebb2f000 0x85ebb38000 lib /boot/system/lib/libnetwork.so
8741 0xc6e3b3c000 0xc6e3b40000 0xc6e3d3f000 0xc6e3d40000 lib /boot/system/lib/python3.9/lib-dynload/_heapq.cpython-39.so
8734 0xc7e11a0000 0xc7e1380000 0xc7e1580000 0xc7e1596000 lib /boot/system/lib/libstdc++.so.6.0.29
8737 0xf013ad0000 0xf013ad1000 0xf013cd0000 0xf013cd1000 lib /boot/system/lib/libicudata.so.66.1
8729 0xffc004e000 0xffc004f000 0xffc024e000 0xffc024f000 app /boot/system/bin/python3.9
8743 0x13cafc48000 0x13cafc4c000 0x13cafe4b000 0x13cafe4c000 lib /boot/system/lib/python3.9/lib-dynload/_posixsubprocess.cpython-39.so
8772 0x140445e9000 0x14044918000 0x14044b17000 0x14044b45000 lib /boot/system/lib/libbe.so
8738 0x14a7f815000 0x14a7fb0c000 0x14a7fd0b000 0x14a7fd24000 lib /boot/system/lib/libicui18n.so.66.1
8777 0x16d9c2a2000 0x16d9c4b8000 0x16d9c6b8000 0x16d9c6c1000 lib /BeRepos/Haiku-PyAPI/bin/interface/InterfaceKit.so
8732 0x17fd41b9000 0x17fd41c2000 0x17fd43c2000 0x17fd43c3000 lib /boot/system/lib/libbsd.so
8774 0x1aa56fa0000 0x1aa5705e000 0x1aa5725e000 0x1aa5725f000 lib /boot/system/lib/libzstd.so.1.5.2
8730 0x1b90ddeb000 0x1b90e10d000 0x1b90e30d000 0x1b90e36d000 lib /boot/system/lib/libpython3.9.so.1.0
8771 0x1eddbc25000 0x1eddbf2f000 0x1eddc12e000 0x1eddc13a000 lib /BeRepos/Haiku-PyAPI/bin/app/AppKit.so
8770 0x233911cb000 0x233911d6000 0x233913d5000 0x233913d7000 lib /boot/system/lib/python3.9/lib-dynload/_struct.cpython-39.so
8728 0x24cc50ba000 0x24cc50d7000 0x24cc52d7000 0x24cc52d8000 lib /boot/system/runtime_loader
8727 0x7ffff655a000 0x7ffff6562000 0x00000000 0x00000000 system commpage
Areas:
29919 0x45c3552000 0x45c3568000 88 r-x none libgcc_s.so.1_seg0ro
29920 0x45c3768000 0x45c3769000 4 rw- none libgcc_s.so.1_seg1rw
29949 0x470f4b7000 0x470f4ba000 12 r-x none grp.cpython-39.so_seg0ro
29950 0x470f6b9000 0x470f6ba000 4 rw- none grp.cpython-39.so_seg1rw
29913 0x4a01f4f000 0x4a02062000 1100 r-x none libroot.so_seg0ro
29914 0x4a02261000 0x4a0226f000 56 rw- none libroot.so_seg1rw
29915 0x4a0226f000 0x4a022b4000 276 rw- none libroot.so_seg2rw
30041 0x5ed218e000 0x5ed21a4000 88 r-x none libz.so.1.2.13_seg0ro
30042 0x5ed23a3000 0x5ed23a4000 4 rw- none libz.so.1.2.13_seg1rw
29932 0x6040c66000 0x6040e3a000 1872 r-x none libicuuc.so.66.1_seg0ro
29933 0x604103a000 0x604104f000 84 rw- none libicuuc.so.66.1_seg1rw
29934 0x604104f000 0x6041050000 4 rw- none libicuuc.so.66.1_seg2rw
29923 0x641bfd3000 0x641bfe5000 72 r-x none libroot-addon-icu.so_seg0ro
29924 0x641c1e5000 0x641c1e6000 4 rw- none libroot-addon-icu.so_seg1rw
29901 0x64675f6000 0x6467606000 64 rw- none rld heap
29955 0x69f1013000 0x69f1021000 56 r-x none math.cpython-39.so_seg0ro
29956 0x69f1221000 0x69f1222000 4 rw- none math.cpython-39.so_seg1rw
29930 0x6b0c7c2000 0x6b0c7ce000 48 r-x none libicuio.so.66.1_seg0ro
29931 0x6b0c9cd000 0x6b0c9cf000 8 rw- none libicuio.so.66.1_seg1rw
29953 0x7890722000 0x7890726000 16 r-x none select.cpython-39.so_seg0ro
29954 0x7890926000 0x7890927000 4 rw- none select.cpython-39.so_seg1rw
30047 0x84483fa000 0x8448402000 32 r-x none plaintext_seg0ro
30048 0x8448601000 0x8448602000 4 rw- none plaintext_seg1rw
29908 0x85eb8ef000 0x85eb930000 260 r-x none libnetwork.so_seg0ro
29909 0x85ebb2f000 0x85ebb33000 16 rw- none libnetwork.so_seg1rw
29910 0x85ebb33000 0x85ebb38000 20 rw- none libnetwork.so_seg2rw
29902 0xaf43aec000 0xaf43aed000 4 rw-cS none _rld_debug_
29921 0xb1b3a21000 0xb1b3a31000 64 rw- none rld heap
29946 0xc6e3b3c000 0xc6e3b40000 16 r-x none _heapq.cpython-39.so_seg0ro
29947 0xc6e3d3f000 0xc6e3d40000 4 rw- none _heapq.cpython-39.so_seg1rw
29935 0xc6f0158000 0xc6f0170000 96 rw- none rld heap
29936 0xc730212000 0xc73022a000 96 rw- none rld heap
29937 0xc7d20c1000 0xc7d3b7c000 27372 r--S none libicuuc.so.66 mmap area
29938 0xc7d72b1000 0xc7d72f1000 256 rw- none libpython3.9.so.1.0 mmap area
29939 0xc7dd21c000 0xc7dd25c000 256 rw- none libpython3.9.so.1.0 mmap area
29940 0xc7df0af000 0xc7df0ef000 256 rw- none libpython3.9.so.1.0 mmap area
29941 0xc7dfb45000 0xc7dfb85000 256 rw- none libpython3.9.so.1.0 mmap area
29942 0xc7e0db7000 0xc7e0df7000 256 rw- none libpython3.9.so.1.0 mmap area
29943 0xc7e1081000 0xc7e10c1000 256 rw- none libpython3.9.so.1.0 mmap area
29944 0xc7e113c000 0xc7e117c000 256 rw- none libpython3.9.so.1.0 mmap area
29916 0xc7e11a0000 0xc7e1380000 1920 r-x none libstdc++.so.6.0.29_seg0ro
29917 0xc7e1580000 0xc7e158e000 56 rw- none libstdc++.so.6.0.29_seg1rw
29918 0xc7e158e000 0xc7e1596000 32 rw- none libstdc++.so.6.0.29_seg2rw
29945 0xe196b63000 0xe196ba3000 256 rw- none libpython3.9.so.1.0 mmap area
29948 0xe6df63b000 0xe6df67b000 256 rw- none libpython3.9.so.1.0 mmap area
30049 0xe856fe0000 0xe857020000 256 rw- none libpython3.9.so.1.0 mmap area
30053 0xee7972e000 0xee7976e000 256 rw- none libpython3.9.so.1.0 mmap area
29925 0xf013ad0000 0xf013ad1000 4 r-x none libicudata.so.66.1_seg0ro
29926 0xf013cd0000 0xf013cd1000 4 rw- none libicudata.so.66.1_seg1rw
29903 0xffc004e000 0xffc004f000 4 r-x none python3.9_seg0ro
29904 0xffc024e000 0xffc024f000 4 rw- none python3.9_seg1rw
29951 0x13cafc48000 0x13cafc4c000 16 r-x none _posixsubprocess.cpython-39.so_
29952 0x13cafe4b000 0x13cafe4c000 4 rw- none _posixsubprocess.cpython-39.so_
30039 0x140445e9000 0x14044918000 3260 r-x none libbe.so_seg0ro
30040 0x14044b17000 0x14044b45000 184 rw- none libbe.so_seg1rw
29927 0x14a7f815000 0x14a7fb0c000 3036 r-x none libicui18n.so.66.1_seg0ro
29928 0x14a7fd0b000 0x14a7fd23000 96 rw- none libicui18n.so.66.1_seg1rw
29929 0x14a7fd23000 0x14a7fd24000 4 rw- none libicui18n.so.66.1_seg2rw
30050 0x16d9c2a2000 0x16d9c4b8000 2136 r-x none InterfaceKit.so_seg0ro
30051 0x16d9c6b8000 0x16d9c6c0000 32 rw- none InterfaceKit.so_seg1rw
30052 0x16d9c6c0000 0x16d9c6c1000 4 rw- none InterfaceKit.so_seg2rw
29911 0x17fd41b9000 0x17fd41c2000 36 r-x none libbsd.so_seg0ro
29912 0x17fd43c2000 0x17fd43c3000 4 rw- none libbsd.so_seg1rw
30043 0x1aa56fa0000 0x1aa5705e000 760 r-x none libzstd.so.1.5.2_seg0ro
30044 0x1aa5725e000 0x1aa5725f000 4 rw- none libzstd.so.1.5.2_seg1rw
29905 0x1b90ddeb000 0x1b90e10d000 3208 r-x none libpython3.9.so.1.0_seg0ro
29906 0x1b90e30d000 0x1b90e34b000 248 rw- none libpython3.9.so.1.0_seg1rw
29907 0x1b90e34b000 0x1b90e36d000 136 rw- none libpython3.9.so.1.0_seg2rw
30036 0x1eddbc25000 0x1eddbf2f000 3112 r-x none AppKit.so_seg0ro
30037 0x1eddc12e000 0x1eddc139000 44 rw- none AppKit.so_seg1rw
30038 0x1eddc139000 0x1eddc13a000 4 rw- none AppKit.so_seg2rw
30034 0x233911cb000 0x233911d6000 44 r-x none _struct.cpython-39.so_seg0ro
30035 0x233913d5000 0x233913d7000 8 rw- none _struct.cpython-39.so_seg1rw
29899 0x24cc50ba000 0x24cc50d7000 116 r-x none runtime_loader_seg0ro
29900 0x24cc52d7000 0x24cc52d8000 4 rw- none runtime_loader_seg1rw
29922 0x10e36f781000 0x10e36fa41000 2816 rw- none heap
29897 0x7f8433d01000 0x7f8434d07000 16408 rw-s none python3_1072_stack
29894 0x7fff967ab000 0x7fff967af000 16 rw-k full user area
29898 0x7ffff655a000 0x7ffff6562000 32 r-xSk full commpage
Semaphores:
69412 0 750 some BBlockCache lock
69415 0 750 token space
69416 0 1072 BLooperList lock
69417 0 752 Catalog
69418 0 750 AppServerLink_sLock
69419 0 750 some BLocker
69420 0 750 some BLocker
69421 0 750 some BLocker
69422 0 752 LocaleRosterData
69443 0 750 screen list
69444 0 750 clipboard
69447 0 752 width buffer
You have a heap corruption. To debug these it may be easier to run your application with libroot_debug
See this article explaining it: Using malloc_debug to Find Memory Related Bugs | Haiku Project
