I think i agree, except on the filtering by native / non native. As a newcomer, that’s not so important. As a experienced user, you would know. Or it being in an advanced filter tab.
What i would add is a package date so you know that, for example, redis package was made in 2014 and is has been 4years “as is”.
Actually, the package manager for developers (easy to find packages) vs for users (easy to find applications) is the more difficult topic. Even Linux Mint has 2 installed by default package managers for exactly these 2 use-cases:
Haikualready have 2 ( Depot and pkgman).
I really dont see the point to have more.
Adjust the Depot to the users needs, i dont care, just leave pkgman as is.
To be fair, this started out by me commenting that Featured Packages being checked by default makes no sense.
Then I suggested that filter be turned off by default and several others also be added.
Also when HaikuDepot is loading I think it would make sense to display repo status updated in either the status bar or the empty pane below the package list.
Global download status, displayed from every package manager would also be a nice to have perhaps implemented in a pop up drawer if you click on the barberpole/progress bar in the status bar.
The original idea AFAIK was that there’s a sort of welcome screen for the user that shows a selection of apps. Which apps are “featured” could change monthly, weekly, daily… but I suspect the curating is a bit difficult(?). I dunno how it’s done actually…
The presentation of those featured packages is also not to everyone’s taste, ask @PulkoMandy. Until this is improved, we have what we have…
As mentioned in a few other posts, there’s a ticket for that already.
I think something is just wrong with your install???
Haiku depot doesn’t take terribly long to display on even my ancient machines. PII-PIII class hardware.
Do you have a different locale set than english … apparently there is a known bug where some locales take ery very long to populate HaikuDepot. For instance I think english is like a couple seconds even on a slow machine, and Russian takes minutes.
You need to wait until haikudepot finishes refreshing , in order for the categories to show anything, it can take a few minutes if your connection is slow.
I am a big fan of having a “native app” tag, but I would not filter on it by default. You don’t want the list of available apps to seem smaller than it is, and also new users may not care about it - specifically if they are looking for some software they are used to on another platform. This is probably a feature that will appeal more to experienced Haiku / BeOS users or developers.
