Both should be in sync.
I don’t know how so many ended up non-activated. As nielx said, it shouldn’t happen from an interrupted download.
When you install a package and so also when you run SoftwareUpdater, HaikuDepot makes a transaction-* folder in administrative subdirectory. Only once every package successfully downloaded, HaikuDepot proceeds to the real installation. So normally there shouldn’t be half-downloaded packages in the packages directory. But in administrative subdirectory, there’s probably a few transaction-* folders with one or several packages, last of these packages being not complete and so broken.
To solve your issue, I would find all packages that are not activated comparing lists, move these elsewhere in a new folder. Then, I would clean old transactions folders as they may take a lot of place. At this point, things are back in a clean state and there shouldn’t be errors anymore.
After that, I would examine the packages I removed to see what I need and what I don’t. I would reinstall those I really want through HaikuDepot (Since these packages were in packages directory, they are probably complete and not broken so you could also click on them or drop them back but our goal is to get out of trouble…) then I would delete the folder.
