We can disable some of these checks, but it could lead to more dangerous problems (memory and eventually filesystem corruption) later on.
So it’s safer to just crash hard and reboot in a clean state, however annoying. And, we are interested in getting a bugreport for these things (preferrably from a nightly, as they include more debugging information…)
Personally I am waiting for a bit longer until the real “official” .iso is out
there rather than the beta1 (my tinker days I am gone; I am no longer
a 20-years old curious person, sadly enough; and reallife also requires
of me that things have to work) - but I have a spare computer here and
I’d like to put Haiku on it eventually.
I have a Sager notebook and the only thing the x64 release does on boot is draw some colored retangles on the upper left corner of the screen then black out. This machine has a GTX 950M. No hope for my computer?
EDIT: I removed the HDMI cable from the port and I get the Haiku loading splash screen, but when it gets to launch it loses image again. How come? Any fix/hack I can apply or am I out of luck?
Probably the nvidia accelerant is broken there you can hold shift while booting to get to the debug menu and black list it or try failsafe video from there then continue booting.
Also you can enable logging to screen and siable paging to print out the syslog during boot it could be another device causing a hang.
Probably have to blacklist your graphics driver. To test whether this is the case and see if you can reach the desktop:
Reboot.
After your computer’s splash screen or logo screen goes away, but before you see any Haiku logo, either hold Shift key continuously, or very rapidly and repeatedly press Spacebar. If you see a Haiku logo, you probably missed the chance and need to try again.
From the bootmenu use the arrow keys to highlight “Select safe mode options”.
Press Enter key
Use arrow keys to highlight “Use fail-safe video mode”.
Press Spacebar
Highlight “Return to main menu” and press Enter.
Highlight “Continue booting” and press Enter.
This should enable you to see if only the graphics driver is the problem.
I think the minimum requirements haven’t been tested. I tried multiple times to start and install Haiku (32-bit) with 256MB RAM, but it’s just not enough.
I did that and I managed to get through. Working well with software graphics, I installed the bootloader and the OS on an empty partition to play around.
I have no idea how to blacklist the driver, though…
There are very low chances that someone does a fresh install and Haiku already has a swapfile available somewhere on the drive, so it can work with virtual memory. But my screenshots pretty much indicate the real problem: “Out of memory” in different stages of the install, so the data could be written.
I womder what is causing the increase in required ram… Does having all the packages activated use more ram…so could the installer stage just activate fewer?
