After update R1Beta6 59866+60 to 59866+65 driver broken.
Driver not load.
Driver Nebula-0.0.2 broken on hrev59866+65, +73,+77 …
comment:8 by waddlesplash, 3 hours ago
Remaining ABI problem fixed in hrev60013, thanks to X512 for sending me a backtrace. However the driver will still need to be rebuilt.
Hi,
I have an old computer with an nvidia qaudro card, will that one work?
Do you know what model it is? It has to be based on the Turing or Ampere architectures to work with the current version of the driver. Turing was announced in August 2018 so if the card was made after that it might be compatible.
No, I don’t know what model it is, I will just try it …
Actually just found the model number Quadro FX580, guess that is too old
Can someone please confirm the T600 card is really supported, @brunobastardi states it is, yet an earlier poster @cocobean says only the T400 is supported. I ask, because one has come available and I would like to try it ..
Looking at the specs of it at this page (NVIDIA T600 Specs | TechPowerUp GPU Database), it should work. It’s based on the Turing architecture and has the same TU117 GPU that the GTX 1650 I’m running fine with the Nebula driver uses.
The only issue I see currently with those cards, the T400 and the T600 is they only have Mini DisplayPort outputs and the current release of the driver only supports HDMI out. When X512 releases a new version of the driver it should support DisplayPort, including Mini Displayport, going by his previous posts.
Better wait for an User who tried it actually!
I just checked the list!
Confirmed. :face_with_peeking_eye:
  • NVIDIA Turing T400/T600/T1000 graphic cards
  • Can use Haiku hrev60069 x86-64 to test latest driver snapshot.
Tested again on my Asus : system stuck during the boot on R1beta6 :confused:
I was not aware of the « Select boot volume/state » in the bootloader (space): I then select the state one day before and then boot the system again then desinstall the 2 hpkg.
Tada system works again ! Learning every day :wink:
I will wait for a version when available.
So even with a mDP->HDMI adapter, it won’t work at present?
Ehem ehem. But if driver can’t send image from gpu on mDP how adapter can help you?
…so true, brain freeze, it’s early havn’t had my coffee :slight_smile:
As mentioned an adaptor like that won’t work as the Mini DisplayPorts on the card would not be sending an output to be able to convert to HDMI. Until a new release of the driver comes out, only supported cards with a HDMI port will work.
Hi,
Great work on the driver. Just bought a T600 (has mDP ports) in preparation for when you release the DisplayPort version … no pressure :innocent:
