Haiku 64bit running nicely on Fujitsu ESPRIMO FMVFR3
I installed Haiku 64bit to a Fujitsu ESPRIMO FH/R3 FMVFR3 all-in-one desktop PC.
Considering that this is a low spec home PC launched in 2010, and originally pre-installed with Windows 7 Home Premium, Haiku works pretty well and has given this PC a new lease of life!
One thing I noticed was that although Haiku performs better on my Thinkpad X230, the 20 inch 1600 x 600 pixel screen of the desktop makes the Haiku experience much better than on the 12.5 inch 1366 x 768 pixel screen of the laptop, which I suppose is to be expected!
Hardware List: Complete Systems
Hrev on which was tested: hrev57937+129
System Type: 64 bit.
Running from: Internal 500G 7,200rpm Serial ATA/300 HDD
Model: Fujitsu FMV Rakuraku Pasocom3 ESPRIMO FH/R3 FMVFR3
Manufacturer: Fujitsu
Rating: Pretty good. This home PC from fifteen years ago worked well with Haiku. Ethernet, wifi, keyboard and mouse work, and it was possible to play mp3 files in Audacious, YouTube videos ran smoothly in full screen mode in QMPlay2, and although booting up from the 7,200rpm HDD took a while, performance was acceptably reliable once Haiku was up and running. Having said this, neither the webcam or microphone would work, and I could not get music CDs or DVD video discs to play back satisfactorily.
Processor/Cores: Celeron T3300 2GHz Dual-core
Memory: 4 GB
Graphic cards/count: Intel Graphics Media Accelerator 4500MHD/Onboard
Vesa needed?: No.
Graphic card status: Watched the trailer for Brad Pitt’s F1 movie full screen, from YouTube using QPlay. There was some breakup with closeup shots with quick side to side movements such as on the driver’s head in the racing car cockpit, but overall both sound and video was watchable.
Sound cards: ?
Soundcard status: No success with enabling sound.
Networking cards: Broadcom 570x Gigabit Integrated Controller Driver
Network card status: Worked. Linkspeed 1 GBit, 1000BASE-T.
Wireless Networking cards: Qualcomm Atheros
Wireless Network card status: Connected successfully to the internet. Link speed 802.11n(g). Did seem to have some issues keeping a stable connection with the home router, cutting out and reconnecting regularly but since the ethernet connection was rock solid, I think I can ignore the flaky wifi quality for the time being.
USB types/count: 2 USB 3.2 Gen 1 Type-A Ports, 2 USB 3.2 Gen 1 Type-C Ports.
USB cards status: Ports are supported. Work with both flash drives and mice.
SD cards: n/a
SD cards status: n/a
Integrated Webcams: Webcam built into hardware. Haiku cannot find a video source.
Did you have to blacklist hardware?: Did not attempt. Was not necessary to get running.
Additional notes: Had to install Haiku BootManager and also re-format the HDD several times to get Haiku to actually boot.
As I wrote multiple here
for playing music CDs on Haiku only SMPlayer is recommended !
Drag and Drop the music CD icon from Desktop to SMPlayer window - this is the one recommended way to open music CDs in SMPlayer. Browsing/selecting from SMPlayer is useless.
For DVD playback – use VLC !!!
Also Drag and Drop the DVD icon from Desktop to VLC window - this is the one recommended way to DVDs in VLC. Browsing/selecting from VLC is useless.
VLC is not altered during port to be accomodated to Haiku device structure – /dev/dvd is a numb option to open a DVD here.
In SMPlayer the DVD menu doesn’t work - so VLC !
SMPlayer for music CDs.
VLC for DVD video discs.
Drag and Drop to play.
Gotcha!
These should be reported to haikuports.
If you copy the tracks from the audio CD (with internet connection, of course) with tracker, not only should the metadata be fetched from the internet, but you can play the files with any programs.
There is a bug with audio CD playback
PS
If someone has a link to a usb sound card working with haiku, leave below
This answer is OFF TOPIC
Indeed - I should report such issues.
However - I do not want to register yet another website to report application issues.
I understand Github is capable to report issues too - however I am not a developer, so for me a Github account is not a necessity. Besides - then should I create an account for Codeberg also ? Moreover on sourceforge.net ???
This inevitably logic is nonsense for me.
I would be happy to use a ticketing system like one exists for Haiku, the OS itself – due to more reasons.
  1. Most apps are coming from Github, however some apps comes with Haiku, so those can be reported there. Moreover there are developers who are store/share their stuff from Codeberg or Sourceforge.
  2. I would use a ticketing system for apps - not a site .. or more sites. I don’t wanna search where to report.
The best would be a webapp, where ‘the where to’ would be added behind and I could use on a one uniform interface. This way the developer also could add his actual issue page.
The problem here is that Haikuports simply is an independant project that isn’t Haiku itself, Haiku doesnt handle issues for Haikuports… It’s not nice that it is on github, but not much we can do about that if they don’t want to change that.
Not official I guess one could create an issue on my codeberg haikuports repository.
If this doesn’t flood I could then link the issue myself (for now) to the official GH issue tracker.
14 posts were split to a new topic: Difficulty of bug submissions
Wow! I had been thinking that the music file attributes would need to be populated manually in Haiku! Had no idea that the attributes would be pulled from some cloud database simply by copying the files over from an audio CD. Is this cool or what!?
One thing which puzzles me is why this only works when copying the music files off of a CD. I found that none of the music files that I copied into Haiku from my fileserver had the attributes automatically populated.
This specific tool identiifes the CD itself and uses that to find the corresponding names.
If you have already existing music files with ID3 tags, you can use ArmyKnife to convert those tags into filesystem attributes. That’s currently not shipped by default with Haiku, but you can install it from the depot.
Thanks for letting me know about ArmyKnife being able to populate the music files’ attributes from’ the files ID3 tags! I didn’t expect ArmyKnife as something which would allow me to do something like this, thinking mistakenly that it was there simply to allow attributes to be filled in laboriously by hand…
Now I’m wondering though whether there are any Haiku native music players which leverage these file attributes. Or perhaps there is a way to use Tracker to act like a playlist of sorts by saving queries there?
Look for BeTon in HaikuDepot. It’s a native music player that uses attributes. It’s really nice!
The default MediaPlayer also supports queries, you can drag and drop a query on it and it will turn it into a playlist.
But BeTon is probably more userfriendly (couldn’t try it as I still don’t have a working soundcard on my Haiku machine :sob:)
I am still searching for a supported USB Sound Card for Haiku, i tried 3 different ones, none worked.
If anybody can provide a link to a working one, it would help.
Maybe we should have a site listing for supported peripherals (scanner, printer, drawing tablet , webcam …)
Have you tried installing opensound?
We have one maintained by BeSly:
opensound does not support USB sound cards.
An alternative could be to get an USB headset that is supported.
