GSoC 2021 Progress Update 2: Coding style checker bot for Gerrit | Haiku Project
Link to Introductory blog Link to Progress 1
This is a companion discussion topic for the original entry at https://www.haiku-os.org/blog/ritz/2021-06-27_gsoc_2021_progress_update_2_coding_style_checker_bot_for_gerrit/
Doesn’t the current build pipeline face a similar problem? It needs the toolchain and (if I’m not wrong) uses a container with it that is generated in another pipeline when there are changes in the toolchain repo.
That’s how you would normally do it, yes. Have a pre-built Docker container somewhere and use that to run the builds inside it. We can update the container when there is a new release of haiku-format.
