Video capture of web browsing with #Falkon in @haikuOS
Used BeScreenCapture app to create the video.
I managed to build qtwebengine under the 32-bit version of Haiku. I had to use the lld linker for this because there was not enough memory for ld.
Somehow the “Reply” button of this forum (https://discuss.haiku-os.org/) doesn’t work in Falkon. Am I the only one having this problem?
Got the same here, sometimes also in WebPositive, I have to write sometimes in one and confirm in the other browser. ![]()
Same issue here…
This is exactly what I do. Write it here on Haiku with Falkon, then go to my old laptop with macOS and send it. A bit inconvenient. ![]()
Got both browsers always open here on Haiku, so making a switch is fast enough. ![]()
For Haiku related services I suggest to use them in Webpositive.
Also, they are already bookmarked there. ;-))
Same here, write report and start WebPositive to send it!
fwiw, I have the same issue on other forums with the same software.
