Deskbar redesign
I’ve been playing with a mockup for the deskbar and maybe it’s a good topic to share it. I’ve been trying to «move» the different parts of the deskbar in a way that make more sense to me. I’ll upload more designs for the various menus shortly.
Good day !
I like the aesthetic (colors, fonts, shape of buttons), but to me the top-left layout does note make sense with Haiku tabbed windows.
``Fonts looks very good what is its name, in what program did you make the mockup?
I tink the crucial issue is to have subcategories under Applications, which would work in any layout.We already have subcategories in HaikuDepot, no need to invent new ones. It’s just a case of moving the symlink. A bit of work, but it only has to be done once.
Another one, more in line with the current style. Yes categories is a must have under applications. The general idea of the mockup is to bypass the blueleaf menu by «extracting what’s inside and putting it front and center.The query, Haiku superpower should be immediatly accessible from the deskbar also. The bottom part works quite well already in my opinion displaying the currently launched apps.
It’s done in Inkscape and the font is the defaut one.
This look reminds me more of tablet operation or CNC machine operation; I like the current Haiku icons much better. i.e. operation of simple touch screens.
but beauty is always in the eye of the beholder
they are just mockups, the icons are basic and not meant to be the actual icons for the os they are there for visual representation.
I wasn’t exactly going for a “flat” look I would say minimalist and clean.
the taskbar isn’t even finished.
The point of the thread is just to throw out ideas for how Haiku could look in the future, everyone has a style they like, I always believed having choice and themes would be available in the future.
The whole Desktbar on top is just wasted space! (On blioberis mock-up!)
What is it good for if you only need your tabbed app-tabs on top?
That’s window style and I don’t like it at all!
For me all apps should remember its last position and tab-position only to make me happy!
It is not only me… but who knows and who cares!
Even if those mockups are not up to my taste (call me old-fashion), it’s not bad others have another view of it, getting anything done (and approved/changed) is another thing, long live freedom! :slight_smile:
Im slowly getting into Haiku under the hood, … maybe I will look at it :smiley: It wont be hard for first commit :slight_smile:
I may be sick on eyes, but what gradient do you use for menus and bar?
A suprise to be sure but a wellcome one
No you’re right there is a gradient. I picked the defaut menubar gradient : eeeeeeff to dcdcdcff.
I quite like the defaut top right deskbar as well, it’s very distinctive and unique to Haiku. And you get so much space on the screen. The option to move it around suits every taste as it is. My main point with these mockups is to address certain usability issues of the deskbar, after a thorough survey of, well, my usage. I realised that I don’t use it to launch apps (list to long and not organised = quicklaunch instead), I regularly forget that I can use the query (tiny «find…» in the menu), I’d like to be able to access my recents documents and folders directly from the main menu and pin some favorites too. And I think the deskbar preferences should be under the preferences entry. Sadly I lack the coding skills to make it happen so it certainly will stay the same but who knows ! The deskbar need some love in the (distant?) future and brainstorming about it might one day be useful :grinning:.
New examples more compact and tidy
The Deskbar preferences are under Preferences already…
So maybe the Desbar preferences in the the blue leaf menu should be removed ?
IMHO that whole section above the Shutdown menu is quite chaotic. There is search, there are mounts, there’s Show Replicants toggle, the Deskbar preferences and at the very top there is the menu item most of the users use exactly once: About this System. Some reorganization and improvements are definitely needed, but then there’s always someone who would argue that they got used to it, it’s perfect, and changes will make it worse, so I better not start that discussion.
