Good day,
Recently I ended up with some sort of mess in my test ground box, Bare Metal Haiku. While this BMH is for testing things, trying to develop some stuff, and I don’t mind that much to do a clean install again now and then (Haiku installs quite fast), I certainly did enjoy Fedora’s Toolbox approach, which is, if I understand correctly, some sort of containerized system within the system, isolated from the main OS, based on podman.
Inside the Toolbox I could install anything, mess anything, and when things got messy, just remove the toolbox, create a new one and start again anew. All this without messing the base OS.
So two questions arise:
1- Is it possible to have such thing (toolbox/podman style thing) on Haiku?
2- How can I set things in my test BMH so I can do testing without messing with the OS and not using VM?
Thanks in advance.
Regards,
RR
