Hello, I am relatively new to Haiku, and I love the operating system so far.
However, one thing that has been bugging me is the DeskCalc app. A scientific mode with trigonometric functions and stuff like that would be wonderful. At the minimum, the app needs to have a square root button to be considered usable IMO.
IMO what it -really- needs is “Programmer mode” that supports hexadecimal, binary, and bit operations.
Another thing you might try is BeCalc. I brought it back to life a short while back and it looks pretty powerful, although the UI is a bit terrifying (and it’s not super stable).
Dropping a colur doesn’t generally work with the GUI of any app. The reason DeskCalc was coded to accept colours is that it can be used as a Replicant on the Desktop. To integrate better with your background, you can drop a colour on it.
Other replicatable apps that accept colours are: ActivityMonitor, the Desktop itself, DeskNote and Clipdinger’s clipboard monitor (both in HaikuDepot). There may be others.
Anyone wants to write a clone of Microsoft PowerToy Calculator?
Let’s be honest, I don’t use the onscreen keypad to do math, I have a keyboard. But an history view, a list of variables, and some simple graphing capabilities would be a lot more useful…
The one from Windows 7 was quite nice; it didn’t have graphing or these other things that PowerToys calculator has, but it had basically everything one would expect from a basic calculator, including history and the ability to type a full formula rather than just numbers. The one on Windows 10 replicates some of the functionality but also loses a bunch (you can’t just type a formula anymore), and others are hard to discover (bitwise mode in the programmer option.) A replication of that Calculator for Haiku might be a nice middle ground and worthy to have in the default install…
