Is there a way to recover a build when this happens? It has happened a couple times now while restarting builds after crashes.
DetermineHaikuRevision1 build/haiku-revision
error: bad signature
fatal: index file corrupt
Error: you are using a Haiku clone without tags, please set
the revision tag to use (e.g. HAIKU_REVISION=hrev43210)
../build/scripts/determine_haiku_revision .. build/haiku-revision
...failed DetermineHaikuRevision1 build/haiku-revision ...
BUILD FAILURE:
...failed updating 1 target(s)...
...skipped 5 target(s)...
...updated 13 target(s)...
