Boost170_devel installed; boost_system not found
Random porting project I’ve been working on has this configure error:
~/src> ./configure
checking for boostlib >= 1.60.0... yes
ok
checking whether the Boost::System library is available... yes
configure: error: Could not find a version of the boost_system library!
Latest nightly and full-sync. boost170_devel and dependencies installed. Also tried various other versions of boostxxx_devel. Where should I start looking? Are there some already ported projects using Boost::System that I could compare notes with to track down the issue? I’m not asking for the solution. I’d like a pointer in the right direction to find the problem. This makes little sense to me as immediately after it says it is available, it then says it can’t find it.
Usually configure scripts create a config.log file with more details about what they are doing (commands they run, files they try to compile, etc). You can check there if there was a compilation error or some other hint about what went wrong.
You could however name it if it is not a top secret project, maybe somebody can check it.
Okay, I’ll let the doge out of the bag. :sweat_smile:
Seems to want an objective c++ compiler. One of their lead devs (dogecoin) suggested I should put this effort aside for now and refocused me on getting Bitcoin to build instead.
You can try to enable the objective c++ backend in the gcc recipe and rebuild it. Maybe boost will need also a rebuild.
