BeOS on modern-ish hardware
Brings back lovely memories :slight_smile: :heart:
Amazing! thanks so much for this detailed breakdown, super helpful.
I definitely recommend getting a Matrox G400/500/550 to have a card with more features (dual head for instance), more video modes and better 2D acceleration; if you can find one cheap
The G550 is useful because they made PCI-E versions; but you obviously have normal PCI slots too. I believe the G550 is barely any faster than a G400
The on-board SATA works?
yes. ide emulation mode in the BIOS
There are literally no legacy options in my Dell BIOS. I haven’t given up hope yet though. Going to try one last suggestion of trying to run the install CD from an external USB drive. But after that, I am seriously considering attaching BlueSCSI to my Adaptec PCI card, as I am pretty sure the SATA is what it doesn’t like.
external USB won’t work, the bootloader won’t find the image. Even with the (shaky) USB mass storage drivers for R5.
When you get a chance, can you test the speed of the drive? I’m curious if it is faster than a CF-IDE-Promise Ultra TX2
Hmm, how would I benchmark in Be?
I have haiku x32 installed , but the test would not be accurate for a test of performance under Be
Unsure. I think I used Berometer. I’ve been moving a lot of stuff so my BeOS machines aren’t set up at the moment.
BeRometer is pretty much the only option. You may need to turn the graphics tests off to stop it crashing.
On BeShare/HiShare I found BeBench this had a CLI tool called “iostone” this did the trick
2.56 mbps?! Lightning fast. I wonder what the promise card gets. I’ll have to hook everything back up.
This brings back fond memories of running BeOS on my PII and PIII. I even bought the physical boxed editions of BeOS R5 and Gobe Productive. And of course relied on the trusty BeOS Bible book. Maybe I should setup a “retro” build… too bad I don’t still have my Voodoo3 graphics card.
Maybe the Motion Computing tablet would be a good candidate with Core 2 Duo, but I do not know the Mobile Intel 945 Express Chipset GPU how would work under BeOS or even Haiku.
https://www.youtube.com/watch?v=_lnjecaTfGE
I could never get R5 working on a tc1100, which I think is the HP tablet in that video; but it was an absolute nightmare to even try - R5 didn’t boot off USB. As far as I remember I had to open it to get the HDD out, install R5 on a normal laptop with a CD drive, and put it back in.
I assume you tried that with a USB flash drive, but did you try a USB optical drive?
That won’t help much if that system cannot boot from a USB device at all, but might get around it not wanting to boot from a USB “hard disk”.
This might be a situation where the Plop boot manager could be of use, by assisting you in booting off a device that the system cannot boot from by itself. Of course you would still have to get that onto bootable media.
This was an optical drive - huge Freecom CD-RW. There is no USB storage support in the BeOS bootloader at all.
If a BIOS or something else provides emulation of a conventional IDE drive, that would work around it.
