BeOS on modern-ish hardware
Well I would’ve hoped to have my masterpiece finished to share with you all, so that will be excited. Since the hardware will probably stay the same, I will share my experience for those who are interested in having something old enough for BeOS, yet new enough to have a modern experience with Haiku.
Abit IP35 Pro
Core 2 Quad Q6700
2GB Memory
Radeon x700/X300 (info below)
Promise Ultra TX2 IDE card.
Soundblaster 16 soundcard.
This CF-IDE adapter.
1 SATA & 1 IDE CD drive.
1TB SATA ssd and 64GB CF card.
I think plenty of P35 and P965 chipsets will work, even though manufacturers may implements MPS differently and that will require some research. I even think P43 chipsets work but I’ve not tested them.
The storage controller though is likely not to work. The promise card has a driver here that works just fine. I think ther eis also an ide replacement driver that may work too.
In my case, I just couldn’t get the CD drive to boot the BeOS CD. I think that may have been the drives fault, but I just don’t know. I used my BeOS laptop drive to install from.
GPU issues:
  • Terminal kept saying “BShell: can’t open pty”. I eventually found out that the x700 video card was at fault. I had no issues with the x300 card, or the Nvidia Geforce 710 I tested. I think now it is a memory issue, where if the GPU driver is installed, it counts the VRAM, but I don’t know.
  • Some modern-ish cards work, lots of older radeons are supported with the Radeon driver. The Geforce 710 with fail-safe is really slow. (Laggy window movement and slow teapots). Will test more cards as I come across them.
  • BeOS can see 1GB of memory without problems (ram-limiting boot loader). Still, I can’t install 4GB because for some reason BeOS won’t boot.
I got a lot of helpful information from this guide and from fellow Haiku/BeOS communuity members.
When I finish my BeOS/Haiku hybrid machine, I will give more information on the software side of things, for now, all the hardware is set up, unless I decide to add ethernet to the BeOS side of things.
Looking forward to some pictures / screenshots.
  • BeOS Pro 5.0.3
    Certain home-oriented/SOHO-oriented OSes, like Windows Me and Mac OS 9.2.2, at that time had a limit of <=1.5GB addressable memory. Also, 4GB RAM was unrealistically unaffordable on home desktop computers until after Y2000. Windows NT 4.0 high-end workstations with 4GB RAM were not common to most home desktop users and even most enthusiasts. Some Oses won’t boot on the higher RAM specs due to limits in memory management or soft settings in the kernel (i.e. by grand design of the developers).
I may end up doing a screen capture for the sake of the bigger part of what I was working on, but we will see.
Yes. I used the ram-limiting boot loader to drop it to 1GB. I might try the 768MB one to see if it works then.
beOS , it only run 32bit , if i do not mistake.
32bit is not so modern now.
directly Haiku is better.
I was referring to the hardware being modern. It’s good bridge hardware, that I can use modern Haiku and BeOS on at the same time.
It’s depends on your definition of “better”. :wink:
And 32-bit or not doesn’t matter for modern-ness, since I’m using 32 bit Haiku right now anyway.
You might have better luck with some things using one of the “modded” versions of BeOS, either ones that incorporated Haiku components replacing certain system ones, or just with some binary patches to work around some of the problems.
I haven’t tried any of those directly on hardware. I tried a couple in a virtual machine, but one was really hideous, and another is hideous and all French. R5.03 has been rock-solid on my Thinkpad and with limited issues on the desktop. I’ll probably experiment more with those, but have been focused on the other issues I’m working on.
At the time, my most favorite BeOS machine was a dual PIII 800mhz on a Tyan Tiger 100 S1832DL. It was stupid fast and extremely stable. Way ahead of the curve at that point in time. My current machine (not counting various resuscitated mongrel rescue pc’s and laptops) is a i5-10600K on an Asus Z490E with 16GB. It’s fast and all but I still think I had more fun on the Be machine.
I think a lot of us are dreaming to have a Supermicro or a Tyan motherboard once. It’s not that other MB are bad, it’s just another level of quality.
  • ATI Radeon X700 PRO and ATI Radeon X800 PRO
Memory allocation system requirements for 128MB VRAM. BeOS 5.0.3 should boot to desktop if allocated 512MB RAM vs. 768MB->1GB RAM w/ graphics cards using 128MB VRAM.
Does anyone know/remember whether Rudolf Cornelissen’s Nvidia driver worked with any PCIe graphics cards or with integrated graphics of that generation (up to 7xxx)? I don’t mean in vesa mode (I mean 2D/3D acceleration.).
Like the nforce3, the integrated GPU had an AGP interface — like these?
What about Haiku with these GPUs?
…I’m trying to build a newer (less old) BeOS/Haiku PC. BeOS 5 bone with Zeta kernel and drivers.
I’m fairly sure the list on Rudolf’s site is exhaustive, but the site is down now, so off to the archives:
https://web.archive.org/web/20080513034149/http://web.inter.nl.net/users/be-hold/BeOS/NVdriver/index.html
TNT up to 6x000; that includes a few first gen PCIE cards that have a PCI-AGP bridge on board and that’s about it; no 3D on those, and no IGPs after the nForce 2; but the mobile versions are supported - very occasionally got motherboards with those onboard as far as I can remember.
Maybe someone has experience with these motherboards (the latest ones that had AGP):
ASRock 4CoreDual-SATA2 (intel, LGA775)
ASRock 775Dual-VSTA (intel, LGA775)
ECS P4M800PRO-M2 (intel, LGA775)
ASRock ALiveDual-eSATA2 (AMD, am2(+))
ASRock AM2NF3-VSTA (AMD, am2)
ECS K8T890-A (AMD, 939)
Nvidia GeForce 7600 Go
Nvidia GeForce 7800 GTX
Nvidia Quadro FX 5500
These work under the Nvidia driver for Haiku x86_gcc2., PhOS. and Zeta.
BeOS Pro 5.0.3 - the Nvidia driver works there.
Those are pcie boards! and do they work in 2d and 3d in BeOS/Zeta/PhOS?
… with PCIe GPU with HSI bridge? or are these just AGP variants of those boards?
…What is the maximum resolution they support with BeOS/Zeta drivers?
I’ve heard that the first nvidia graphics cards for the pcie slot worked with Rudolf’s nvidia drivers for the BeOS system. Does anyone have experience with this?
These graphics cards (?):
NVIDIA PCX GPUs (pcie slot)
GeForce PCX 4300
Feb 19th, 2004
NV18C
PCIe 1.0 x16 64 MB / DDR / 64 bit
GeForce PCX 5300
Feb 17th, 2004
NV37
PCIe 1.0 x16 128 MB / DDR / 128 bit
GeForce PCX 5750
Feb 17th, 2004
NV39
GeForce PCX 5900
Mar 17th, 2003
NV35
PCIe 1.0 x16 128 MB / DDR / 256 bit
GeForce PCX 5950
Feb 17th, 2004
NV38
PCIe 1.0 x16 256 MB / GDDR3 / 256 bit
3D is only for Geforce 2 based cards and below. This includes some Geforce 4 MX cards that are Geforce 2 internally.
No PCIE versions of these exist.
