Hi, i’ve installed a 64bit version of haiku on a usb stick today. i have adjusted the font size & installed a couple of app’s. something that i don’t quite understand is the write permissions on the usb stick. i’m under the impression that it is read only by default.
though haiku can obviously write to it. i installed yt-dlp via the terminal using:
~> pkgman install cmd:yt_dlp
when i tested it this happened?
~> yt-dlp -U
Current version: stable@2024.04.09 from yt-dlp/yt-dlp
Latest version: stable@2024.05.27 from yt-dlp/yt-dlp
Current Build Hash: 7f12092fb95ffa2c8947c855298c94c612c9c0e969e132d7eca5502981955c99
Updating to stable@2024.05.27 from yt-dlp/yt-dlp ...
ERROR: Unable to write to /boot/system/bin/yt-dlp; try running as administrator
So, that makes me wonder whether this is caused by write protection of the stick? Or do i need to use sudo or su prior to yt-dlp on haiku? you don’t have to on linux.
-U command just checks if it is the latest version & updates itself from their home repo. so it was likely breaking the convention that caused the error.
After a sleep i’ll download a vid & verify that it is working properly.
That IS good news. Thanks. I just have to learn all this stuff about haiku again, i haven’t been using it for quite some time. what is available, how to install what, & from where. & on it goes.
I’m using haiku now, it is being pretty well behaved. some tearing in the browser, but it isn’t hard to live with at this point.
ty again for help (to all). I just did a search on the web & came up with a page of mine in this forum from oct 2022 when i was looking at haiku again. i was told to use the pkgman command. so i just did & am installing yt_dlp as i type this.
