there will be some changes regarding yab.
the buildfactory is currently defect and cannot be used (and this is not based on yab 1.7.8, it is a bug before)
for this reason and the addition of some new functions and bug fixes, we will share the individual yab components.
this means that there will be more packages than before. this happened for various reasons. on the one hand, e.g. the yabIDE is not installed if you want to use the BuildFactory in your own IDE. The same applies to documentation, yab lib and source.
We were shocked to find that the current package contained the source code in part twice. Probably as a result of trying to keep yab up to date and keep everything functional in a short time.
We hope that we have clean packages with different possibilities of use. This also makes updates easier.
The current status of the work can be seen on our BUG tracker.
