Hi All,
(Old) New App for Haiku 32bit x86_gcc2 platform
This is an old BeOS app I used to use for web serving and ftp.
I lost the source code but have managed to make a hpkg and it works on Haiku x86_gcc2
Xitami is free software and comes with ABSOLUTELY NO WARRANTY.
You may redistribute this software under certain conditions;
read the file LICENSE.TXT for details. Run 'xitami -h' for help.
Syntax: xitami [options...]
Options:
-w directory Working directory for server
-r directory Root directory for web pages (webpages)
-c directory Directory for CGI programs (cgi-bin)
-b portbase Shift HTTP port 80 by this value. E.g. to run
Xitami on port 5080, do 'xitami -b 5000'
-f directory Root directory for FTP files (webpages)
-q Quiet mode: no messages
-s Server mode: run as background job
-S Console mode: run as foreground job
-t Trace all socket i/o operations to log file
-v Show Xitami version information
-h Show summary of command-line options
The order of arguments is not important. Switches and filenames
are case sensitive. See documentation for detailed information.
