Listing content with right-click mouse
Hello, sorry the offtopic, what control look are you using there? love the rounded direction bar.
Itâs a Qt app, written that way.
Amazing!
Thanks for testing.
I wasnât able to test much due to my system limitations so its nice to see basic read support working.
You can report issues on our Bug Tracker, maybe uploading file which caused crash which will help me a lot to debug ![]()
Letâs see if I can find some way to fix Tracker issue as well.
Cool⌠Can xfs fully usable as befs alternative someday?
Well that depends how much development we will see for XFS in upcoming time and how stable it will be, currently this project is developed by GSoC students ( I am current GSoC student as well).
I am planning on importing xfs-tests from linux after my GSoC period which contains torture tests for major file systems on linux like xfs, btrfs, ext4 etcâŚ
So if our xfs code passes those tests one day it will be very stable.
But I donât think there is going to be bfs alternative in Haiku in future anyway, we are successor of BeOS isnât it
⌠yes i think you right about BeOs successor thingâŚ
@khallebal - which Qt file manager is it? is it your own port or is it available on HaikuPorts / HaikuDepot etc?
Edit: I guess itâs Dolphin which is in the HaikuDepot
No itâ not Dolphin, you can get it from the link bellow.
Create a recipe for it and add it to haikuports?
well, i wanât sure if it was good idea to write a recipe for it 'coz itâs a bit rough around the edges, but i guess itâs alright if i do ,we"re used to rough edges around here anyway
No. It doesnât support queries. No filesystem other than befs does. Why would we replace befs anyways? Do you have problems with it?
The goalof this project is only to make it easier to share data with other OS (for example Linux) that would be installed on the same machine.
Thanks for the explanation,
Sometime i just feel hard to deal with befs when i need to enlarge itâŚ
Hello!
Just tested xattrs for XFS
As directories xattrs are stored in several formats :
- Short attributes.
- Leaf attributes.
- Node attributes.
- B+Tree attributes.
I completed and tested shortform attributes, now I will be working on remaining attributes format support
I donât have a need for it here, but nice progress!
Ah yesâŚ
Actually there is another thread I created for posting progress on xfs, looks like itâs way down to scroll so just posted here lol
